Author Topic: [SOLVED many thanks] Tick Tock Still Hacking Away At My Binary Clock  (Read 257 times)
South Uk
Ok so i took a bit of a break from my project over christmas and thought i better finish it off but im having a bit of problem with some programming strangely enough being in the programming section!
I have used some code found on the forum to include my RTC clock DS3231, (not DS1307 as stated in my code but they work the same) the problem is im getting some "invalid conversion from 'int*' to 'uint8_t'" errors and wondered if someone could point me in the right direction? Many thanks
// Lilypad binary clock - Set using RTC
#include <Time.h>
#include <Wire.h>
#include <DS1307RTC.h>  // a basic DS1307 library that returns time as a time_t
int hourLEDs[] = {1, 2, 3, 4}; // Hours LED (Digital Pin 1-4)
int minuteLEDs[] = {10, 9, 8, 7, 6, 5}; // Minutes Led (Digital Pin 10-5)
int secondLEDs[] = {16, 15, 14, 13, 12, 11}; // Seconds Led (Digital Pin 12-11 Analog Pin 2-0)
int loopLEDs[] = {16, 15, 14, 13, 12, 11, 10, 9, 8, 7, 6, 5, 4, 3, 2, 1}; // Spin Led In this order
int switchPin = 17 ; // Used for setting time, hold to advance. (to be used for interupt once RTC is avalible)
  for (int i = 0; i < 4; i++)
     pinMode(hourLEDs, OUTPUT);
  for (int i = 0; i < 6; i++)
     pinMode(minuteLEDs, OUTPUT);
     pinMode(secondLEDs, OUTPUT);
  time_t t = now();
  setSyncProvider(RTC.get);   // the function to get the time from the RTC
  if (digitalRead(switchPin))
    adjustTime(60-second());  // Move the clock forward to the next minute
    RTC.set(now());  // Set the RTC to the new time
  else if (minute() == 0 && second() == 0)
    spin(hour());
  updateDisplay();
  delay(1);
void updateDisplay()
  time_t t = now();
  setOutput(hourLEDs, 4, hourFormat12(t));
  setOutput(minuteLEDs, 6, minute(t));
  setOutput(secondLEDs, 6, second(t));
  Serial.print(hour());
  printDigits(minute());
  printDigits(second());
  Serial.println();
void printDigits(int digits){
  // utility function for digital clock display: prints preceding colon and leading 0
  Serial.print(":");
  if(digits < 10)
  Serial.print('0');
  Serial.print(digits);
void setOutput(int *ledArray, int numLEDs, int value)
    for (int i = 0; i < numLEDs; i++)
     digitalWrite(ledArray, bitRead(value, i));
void spin(int count)
  for (int i = 0; i < count; i++)
      for (int j = 0; j < 16; j++)
         digitalWrite(loopLEDs[j], HIGH);
         delay(50);
         digitalWrite(loopLEDs[j], LOW);
Errors
round_Clock_v1_4.ino: In function 'void setup()':
round_Clock_v1_4:21: error: invalid conversion from 'int*' to 'uint8_t'
round_Clock_v1_4:21: error: initializing argument 1 of 'void pinMode(uint8_t, uint8_t)'
round_Clock_v1_4:25: error: invalid conversion from 'int*' to 'uint8_t'
round_Clock_v1_4:25: error: initializing argument 1 of 'void pinMode(uint8_t, uint8_t)'
round_Clock_v1_4:29: error: invalid conversion from 'int*' to 'uint8_t'
round_Clock_v1_4:29: error: initializing argument 1 of 'void pinMode(uint8_t, uint8_t)'
round_Clock_v1_4:32: error: 'RTC' was not declared in this scope
round_Clock_v1_4.ino: In function 'void loop()':
round_Clock_v1_4:43: error: 'RTC' was not declared in this scope
round_Clock_v1_4.ino: In function 'void updateDisplay()':
round_Clock_v1_4:57: error: 'RTC' was not declared in this scope
round_Clock_v1_4.ino: In function 'void setOutput(int*, int, int)':
round_Clock_v1_4:83: error: invalid conversion from 'int*' to 'uint8_t'
round_Clock_v1_4:83: error: initializing argument 1 of 'void digitalWrite(uint8_t, uint8_t)'
« Last Edit: January 30, 2013, 03:24:47 pm by monsteryeti » Logged
Help Help Help
UK
No subscript for array.
Seattle, WA USA
Seattle, WA USA
You can't initialize a whole array of pins at once. Doing so in a loop wouldn't make sense, if you could. You are missing the [ and ] and the index value.
South Uk
Thanks for the fast replies, this was my original code before adding in the RTC part of it and it compile just fine, now i know that means what ever im adding is the problem but im not sure where the conflict is as this works fine without the RTC code and the time is displayed.
// binary clock code V1.2
#include <Time.h>
     pinMode(hourLEDs[i], OUTPUT);
     pinMode(minuteLEDs[i], OUTPUT);
     pinMode(secondLEDs[i], OUTPUT);
  setTime(0);
     adjustTime(1);
    spin(hour());
  updateDisplay();
  delay(1);
  time_t t = now();
     digitalWrite(ledArray[i], bitRead(value, i));
         delay(50);
Help Help Help
Seattle, WA USA
Seattle, WA USA
Look at the pinMode statements in setup() in the old code and the new code:
old:      pinMode(hourLEDs[i], OUTPUT);
new:     pinMode(hourLEDs, OUTPUT);
South Uk
I have Been a prize plum, thanks for pointing out the obvious! Too long looking at the same thing over and over.
I will try go through the rest of my errors, Thanks PaulS
Help Help Help
South Uk
Im down to my last problem.
I dont really understand what its trying to say by "invalid conversion"? on this part of the code
Help Help Help
Seattle, WA USA
Seattle, WA USA
Doesn't the name ledArray tell you anything? It's an array. Arrays need indexes.
South Uk
Thanks again PaulS for putting up with my learner questions, only at the start of my learning but im sure i will get there (im half way through my first tutorial book). As for my Clock it is now taking good time from the RTC and working as desired, Your a star buddy.
Cheers Again.
Help Help Help
