Loading...
Pages: [1]   Go Down
Author Topic: Real-time bus information  (Read 203 times)
Offline Offline
Newbie
View Profile
Hey guys,
i'm working on a real-time information about bus departures.
I use an Arduino with Ethernet Shield and 4 led matrices.
Displaying the text works - as you can see in the attachment (The first letter on the left side is the bus line, the next is the direction and the last is departure time).
The code looks like this:
Code:
#include "HT1632.h"
#define DATA 2
#define WR   3
#define CS   4
#define CS2  5
#define CS3  6
#define CS4  7
HT1632LEDMatrix matrix = HT1632LEDMatrix(DATA, WR, CS, CS2, CS3, CS4);
  matrix.begin(HT1632_COMMON_16NMOS);
  delay(0);
  matrix.clearScreen();
  matrix.setTextSize(1);
  matrix.setTextColor(1);
  if (matrix.width() <= 24) {
    matrix.setCursor(0, 0);
    matrix.print("");
    matrix.setCursor(0, 8);
    matrix.print("");
    matrix.writeScreen();
  } else if (matrix.width() > 24) {
    matrix.setCursor(0, 0);   // First left
    matrix.print("D  K");
    matrix.setCursor(0, 8);   // Second left
    matrix.print("E  F");
    matrix.setCursor(48, 0);  // Third left
    matrix.print("DE K");
    matrix.setCursor(48, 8);  // Fourth left
    matrix.print("DE H");
    matrix.setCursor(24, 0);  // First right
    matrix.print("  7'");
    matrix.setCursor(24, 8);  // Second right
    matrix.print("  9'");
    matrix.setCursor(72, 0);  // Third right
    matrix.print("1749");
    matrix.setCursor(72, 8);  // Fourth right
    matrix.print("1820");
  delay(1000000);
To get the real-time, I want to use the source-code of my transport authority, it displays 4 departures and all the information you need:
http://www.ivb.at/smartinfo/ivb_smartinfo_kernel.php?olifServerId=84&autorefresh=20&default_autorefresh=20&routeId=&stopId=Absam%20Dorf&optDir=-1&nRows=4&showArrivals=n&optTime=now&time=&allLines=y&app=sionline
There is no API available. Has anyone an idea how to load the information from the source code to my led matrices?
I've looked up some tutorials, but no one really solved this problem..
Thanks for your help!
Max
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
How did you get all the right arguments, then?
Do you have an Ethernet shield? Have you made a GET request that contains the same script and arguments, or the same server? Did you get a reply?
Logged
Offline Offline
Newbie
View Profile
Thanks for your answer!
All the departures are just random - at this moment, there is no connection to the server!
I have an Ethernet shield - the problem is, how to programm the Arduino to copy the data from the server into the script...
Logged
Offline Offline
Newbie
View Profile
I solved the problem now - I just added the 'host'  smiley
Logged
Pages: [1]   Go Up
Print
Jump to:
