Loading...
Pages: 1 [2]   Go Down
Author Topic: The 0.1uF capacitors when using FTDI programmer  (Read 879 times)
Offline Offline
Full Member
View Profile
Great ! How about CTS? What's that ?
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Not required in this application and can be left disconnected.
Lefty
Logged
Offline Offline
Full Member
View Profile
When will CTS being used ?
Logged
Offline Offline
Brattain Member
View Profile
If the PC com link was set-up with the 'hardware handshacking' enabled, the CTS (clear to send) would be how the device would tell the PC it was ready to receive data if any is waiting to be sent. The comm port as used by arduino (and most all PC serial applications) use the 'no handshake' option choice to run the link at. There is also a 'software handshake' option where the two sides of a comm link send the ascii Xon and Xoff control characters to tell the other side to stop or start sending data. That is also not used in most PC applications. But both options are available for interfacing with such thing a older modems and other data communication devices.
Lefty
« Last Edit: February 01, 2013, 09:14:01 pm by retrolefty » Logged
vermont
Offline Offline
Full Member
View Profile
cts, dsr, ri, etc are inputs to the pc and therefor can never be used as arduino control bits.
Logged
Offline Offline
Full Member
View Profile
But the timing has to be right, hold down the reset, select the program from the IDE, when it says loading, count one two three, and release the reset.
I have tried this ! It's really do work well ! But the timing really have to be correct. Have to release the RESET button once the IDE shows 'uploading..'
Thanks ! Finally I understand why is there a cap there- to bring the RESET High and LOW. smiley
When I want to upload a new sketch, the we should RESET our microcontroller so that the previous sketch is deleted and pull the RESET HIGH to allow the new program to load into ?
Am I correct ?
Thanks !
Logged
Offline Offline
Brattain Member
View Profile
Quote
Well actually that should read 'to bring the reset Low then High'.  smiley-wink
Lefty
Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Resetting the processor does not delete the old sketch.
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
