Loading...
Pages: [1]   Go Down
Author Topic: Stop - before Loop?  (Read 238 times)
Offline Offline
Jr. Member
View Profile
is it possible to stop the loop from runnning.
Im using an ethernet shield, and if it fails to obtain a local LAN Ip, I want to stop the loop from running.. can I do this?
so In void setup I have this line..
Code:
if (Ethernet.begin(mac) == 0) {
   { Serial.println("Failed to configure Ethernet using DHCP");
    lcd.setCursor(0,0);
lcd.print("LAN FAILURE !");
delay(1000);}
/// I want this to stop the loop from running from here . HOW?
do I create a else comment in loop and do nothing if (Ethernet.begin(mac) == 0)
any help would be appreciated...
David
Logged
0
Offline Offline
God Member
Get Bitlash: http://bitlash.net
View Profile
Wouldn't it be more stylish to loop retrying the DHCP connection than simply to stop?
Anyway, you can just write a forever loop: "while (1) {;}" to stop execution.
-br
Logged
Offline Offline
Jr. Member
View Profile
-br
Yes it would, but as it is even if my LAN is down, the loop begins..
Logged
Pittsburgh, PA, USA
Offline Offline
Faraday Member
I only know some basic electricity....
View Profile
You could check the LAN in setup().
Either way, while (1); ( save yer fingers, you don't need the { } ) will hang the code instantly. It's budget error-handling.
Logged
Examples can be found at Learning in the Main Site and at the Playground
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
You can always set a flag if initialization fails and test that in loop...  Perhaps you want something else to happen in that case
Logged
Offline Offline
Jr. Member
View Profile
That was easy.. many thanks !-)
Logged
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Code:
    lcd.setCursor(0,0);
delay(1000);}
Use exit();
And indent better.
Code:
 if (Ethernet.begin (mac) == 0)
    Serial.println ("Failed to configure Ethernet using DHCP");
    lcd.setCursor (0,0);
    lcd.print ("LAN FAILURE !");
    delay (1000);
    exit (1);     // give up
Don't be shy to hit the space bar. You don't get charged extra for spaces.
Logged
Pittsburgh, PA, USA
Offline Offline
Faraday Member
View Profile
Oh yeah.. exit(). I haven't used it with Arduino because for years it means exit to O/S to me!
Please for review, does exit stop any clocks and cut power use?
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
I have to resist making humorous suggestions here ...
No, it turns interrupts off and goes into an infinite loop. That's all.
Logged
Pages: [1]   Go Up
Print
Jump to:
