nice. i have added your libs to the xml.
(it is easy if every lib have the same directory structure inside the zip-file)
The only bad is that you do not have a description for every lib.
Of course it would be nice if this feature would be added to the IDE.
Currently missing is a lib-uninstall feature in the application. Will look into this if i have time.
This kind of third-party repository interface has been around for many years and in several different communities. I'm wondering if there's even software already to manage the infrastructure.
In hindsight it's amazing that something like this doesn't already exist for Arduino! I guess you can say the Wiki/Playground is there but it's time for The Next Generation.
The Gadget Shield: accelerometer, RGB LED, IR transmit/receive, light sensor, potentiometers, pushbuttons
Completely agree!
We should get a centralized third-party repository up and running soon.
[edit]Might rewrite the client for Java? Easier cross-platform and maintainable for the Arduino developers (as the IDE is java). Sorry to OP is this is the stupidest idea ever presented.[/edit]
I already thought about a posibility to post librarys.
And i would also host it on my server. I can configure it so it can also mirror it on your server.
the application might be able to load an xml from a repository like that already.
But some things need to be looked at if we do this.
At the moment everyone is compressing his own lib differently with different folder structures and different manual steps to install.
when we make a repository like that. Every library.zip should have the same structure and the structure should be checked by the upload script.
I do not know if i am allowed to host every library or what to do with librarys where the creator does not upload them on theyr own or the author is not longer aviable.
the cmd part in the xml should be removed so no one can post a malicious command in the xml. (for this every lib.zip needs the same structure to make it easier)
Doesnt need every lib checked before publishing in a repository like this?
as you see. I think the hardest part might be to get every lib-structure to be the same.
Most of them look the same but not all.
//Edit: yes. Sorry that this is not java but i can not write in java.
It is already cross platform except the 7zip exe i used.
And i know this part needs a rewrite.
I think we need to model the 'structure' after how the official team does it, and that is to zip the archive which the files resides in. That is, so one extracts within the libraries archive (this way one does not have to create a new folder before extracting).
Reference: http://www.arduino.cc/en/Hacking/LibraryTutorial
I think the community should be the 'check' so that we could have a flag for 'does not work' for instance. And maybe also a vote up/down.
We could add categories to the libraries. Math, Data Structures, Timing, Processing, Hardware Abstraction etc etc etc.
Will look to change my application as soon as the XML format is right.
There's probably several things missing. But, because I would want to keep track of versions, the 'upload a library' (which will actually be 'provide an URL to your zip archive) will be an action that has to do with a library version. So I think it's best to have a separate form for adding a new version of a library.
Feel free to have a look at the XML and rewrite it as you would like it to be. The most important features for me is:
any number of authors
a short library descriptions
any number of library versions, with a version number, a .zip and a short description
So i will change it that every uploaded zip needs only 1 folder with the libraryname and inside that the library cpp files with examples.
That is brilliant.
@AlphaBeta´s Edit:
I don't really understand what idea you mean that is stupid. :-?
If you thought I was an ass for suggesting a rewrite, I'd like to apologize. That's all.
Keeping this project a separate endeavor is probably not a problem at all. It is the service which is in focus, and when we get used to being able to easily download libraries, and have an XML and a backing website in place, adding a downloader to the IDE won't be hard at all.
I for one would ask why the Arduino IDE is Not! in C++.
It's because the Arduino team used an already developed multiplatform/open sourced IDE used in the Processing project. This allowed the Arduino project to come to light much quicker then if they had to create the IDE from scratch. Nothing to do with language wars.
I use something similar into a GIS open source program: QGIS. It has a similar tool to download scripts and tools from the official repository, but also from three-part repositories... It also show an advise when new version from a library is available. Other interesting option: it allows you to install libraries and also remove them. Just only some ideas that could be interesting for this library download tool for Arduino IDE.
I am really interested if my tool even works for anyone.
I just tested it on a different PC and the application didn't start at all. :-/
Now switching the development tools and will see if it works better.
Nice side effect is a Development environment where i am more comfortable with.
Just solving the last problems.
Of course i am not thinking someone is an ass just for suggesting something. Even a rewrite.
Maybe when i am more comfortable with building GUIs with wxWidget i might be able to make a small C++ IDE for Arduino. :-?
I know the argument for JAVA for the IDE comes with the understanding that it is what is required for cross platform development... but C++ with WxWidgets seems to be well supported on multiple platforms... so... good choice.
It seems that a WxWidgets solution should be able to work for Linux and Apple in additional to Windows. Good Luck.
so i got my development environment working yesterday.
i compiled it and it also works now on the PC where the application didn't started before.
So i think this is a good sign.
i also got some code running to extract the library zips directly with the zip library. Just need code the folder structure creation from the zip. (currently only in the SVN)
when that code works some library zips might no longer be supported because of different folder structures but i think the advantages outweigh the disadvantages in the long term and it will be easier to compile on different platforms without the need of 7zip.
After that i will look to parse the XML from AlphaBeta. It would be nice if i could get a working example from this XML with at least 1 working testentry.
If someone wants to help in programming this, i can create him a SVN login with write access of course.
I hope i do not Spam here or we should talk outside of this forum.
I reckon a public upload of libraries, with a mandatory structure check as proposed, would be the easiest for all to work with. I know I won't contribute if it takes effort.. (I mainly specialise libraries for my own needs).
It should be a trivial matter of making two lists, one for 'tried&tested' and one for 'new and/or experimental'.
When a library gets X 'works flawlessly' marks, it gets moved to the 'tried&tested' list. This should make it easier to navigate for both newbies and veterans.
I'd also like to suggest the ability to include a link to another library with an entry. For instance, there is a LCD library. There is a specialised 4bit LCD library (I know this can be done with the current version of the LCD library, but the LCD shield from DFRobot for instance also includes 5 buttons on an analog pin) and then there is the shift register powered LCD display library.
This would make it easy to see which libraries are specialised, derivatives or alternatives of a particular library.
