Topic: Stop - before Loop? (Read 2029 times) previous topic - next topic
mrfunk
is it possible to stop the loop from runnning.
Im using an ethernet shield, and if it fails to obtain a local LAN Ip, I want to stop the loop from running.. can I do this?
so In void setup I have this line..
if (Ethernet.begin(mac) == 0) {
   { Serial.println("Failed to configure Ethernet using DHCP");
    lcd.setCursor(0,0);
lcd.print("LAN FAILURE !");
delay(1000);}
/// I want this to stop the loop from running from here . HOW?
do I create a else comment in loop and do nothing if (Ethernet.begin(mac) == 0)
any help would be appreciated...
David
billroy
Wouldn't it be more stylish to loop retrying the DHCP connection than simply to stop?
Anyway, you can just write a forever loop: "while (1) {;}" to stop execution.
-br
mrfunk
-br
Yes it would, but as it is even if my LAN is down, the loop begins..
GoForSmoke
You could check the LAN in setup().
Either way, while (1); ( save yer fingers, you don't need the { } ) will hang the code instantly. It's budget error-handling.
Nick Gammon on multitasking Arduinos:
1) http://gammon.com.au/blink
2) http://gammon.com.au/serial
MarkT
You can always set a flag if initialization fails and test that in loop...  Perhaps you want something else to happen in that case
mrfunk
That was easy.. many thanks !-)
nickgammon
   lcd.setCursor(0,0);
delay(1000);}
Use exit();
And indent better.
 if (Ethernet.begin (mac) == 0)
    Serial.println ("Failed to configure Ethernet using DHCP");
   lcd.setCursor (0,0);
   lcd.print ("LAN FAILURE !");
    delay (1000);
   exit (1);     // give up
Don't be shy to hit the space bar. You don't get charged extra for spaces.
GoForSmoke
Oh yeah.. exit(). I haven't used it with Arduino because for years it means exit to O/S to me!
Please for review, does exit stop any clocks and cut power use?
nickgammon
I have to resist making humorous suggestions here ...
No, it turns interrupts off and goes into an infinite loop. That's all.
