Loading...
Pages: 1 2 [3]   Go Down
Author Topic: Question about my Sketch.  (Read 605 times)
NJ, USA
Offline Offline
Newbie
View Profile
WWW
I would recommend removing the indicated *** lines in setup,  Compile and run, the motor should go on 4 seconds and then off 4 seconds, on 4, off 4.  Then in loop() just change the leftMotors()s to rightMotor().  You're just making sure the motor works here.
Also see if you can add the lines in the loop, to test the reverse:
   right fwd full
   delay
   right fwd 0    (stop)
   delay
   right reverse full
   delay
Modify for both motors fwd, 1 fwd 1 reverse, half speed (128), etc.
Make sure you understand the concept that setup runs once, first-- and loop then runs forever, over and over.
Cheers,
John
Okay, I did all that and got the motors working, not both at the same time, but I got each motor to go forward and backward, and switching back and forth.
Logged
Pittsburgh, PA, USA
Offline Offline
Faraday Member
I only know some basic electricity....
View Profile
You could bury a powered cable under the lawn and use a magnetic field sensor or two on the mower to follow that like a toy line-follower robot. You'd get a perfect path every time regardless of wheel slip, etc. No map or mapping required, just one long piece of single conductor wire and some time making and filling very thin, shallow trenches.
Could probably run something like that with a Tiny.
Logged
Examples can be found at Learning in the Main Site and at the Playground
NJ, USA
Offline Offline
Newbie
View Profile
WWW
This is more or less the plan eventually. Right now I am just going to use it in my backyard, which is fully fenced in, so I don't need sensors yet, just bumpers to make it turn around should it run into anything.
Logged
NJ, USA
Offline Offline
Newbie
View Profile
WWW
here are links to a couple pictures of what it looks like so far
http://sdrv.ms/14EWuxa
http://sdrv.ms/14EWqxI
http://sdrv.ms/14EWyNz
I have to properly mount the Board and give it some paint...but overall that is it, minus it's covers
Logged
East Anglia (UK)
Online Online
Edison Member
May all of your blinks be without delay
View Profile
Did they fail to run at the same time or was that how you programmed it ?
Logged
NJ, USA
Offline Offline
Newbie
View Profile
WWW
That was just how I programmed it to test. I tried adding the other motor in after and got both working.
Logged
Temple, Texas
Offline Offline
Sr. Member
View Profile
Now that you know both motors are working you could do something like this to test the bumper switches:
Code:
/* Bumpers */
const int LEFT_BUMP = A2, RIGHT_BUMP = A3;
boolean bump(int pin) {
// there's fancier ways but for now you will understand this ...
if (digitalRead(pin) == LOW)    // switches are wired to ground
return true;
return false;
and in loop do something like
Code:
// test the bumper switches
if (bump(LEFT_BUMP)){
leftMotor(FORWARD, FULLSPEED);  // left motor on
rightMotor(FORWARD, 0);         // right off
else if (bump( RIGHT_BUMP)){
// right motor on, left off
Remember to set INPUT_PULLUP in setup()...
Cheers,
John
Logged
NJ, USA
Offline Offline
Newbie
View Profile
WWW
Okay guys here is my final sketch smiley I have a video of it working too, but it is still uploading. I will link to it later when it is done. I need to head to work soon.
EDIT: here is a link to the video on my Skydrive. http://sdrv.ms/VQMzDs
and on youtube
Code:
   Mowbot Sketch
const int RIGHT_MOTOR=13, RIGHT_BRAKE=8, RIGHT_SPINNER=11;
const int LEFT_MOTOR=12, LEFT_BRAKE=9, LEFT_SPINNER=3;
const int FORWARD=HIGH, REVERSE=LOW;
const int FULLSPEED=255;
void leftMotor( int direction, int speed)
  digitalWrite( LEFT_MOTOR, direction); //Establishes direction of Channel A
  digitalWrite( LEFT_BRAKE , LOW);      //Disengage the Brake
  digitalWrite( LEFT_SPINNER, speed);   //Spins the motor
void rightMotor( int direction, int speed)
  digitalWrite( RIGHT_MOTOR, direction); //Establishes direction of Channel B
  digitalWrite( RIGHT_BRAKE , LOW);      //Disengage the Brake
  digitalWrite( RIGHT_SPINNER, speed);   //Spins the motor
/* Bumpers */
const int LEFT_BUMP = A2;
const int RIGHT_BUMP = A3;
  // there's fancier ways but for now ...
    return true;
    return false;
  pinMode(LEFT_MOTOR, OUTPUT);
  pinMode(LEFT_BRAKE, OUTPUT);
  pinMode(RIGHT_MOTOR, OUTPUT);
  pinMode(RIGHT_BRAKE, OUTPUT);
  pinMode(LEFT_BUMP, INPUT_PULLUP);
  pinMode(RIGHT_BUMP, INPUT_PULLUP);
  int randNumber = random(900, 2500);
  if (bump(LEFT_BUMP))            // left bumper hit
    leftMotor(REVERSE, FULLSPEED);  // backup
    rightMotor(REVERSE, FULLSPEED);
    delay(1500);
    leftMotor(REVERSE, FULLSPEED);  // turn
    rightMotor(FORWARD, FULLSPEED);
    delay(randNumber);       // a random amount
  else if (bump(RIGHT_BUMP))
    delay(1500);
    delay(randNumber);
}  // then back to loop(), over and over
« Last Edit: February 12, 2013, 08:38:24 am by OmegaRa » Logged
East Anglia (UK)
Online Online
Edison Member
View Profile
Congratulations on getting it working.  Your code is fairly easy to read but I would suggest making each of the sets of motor controls into a function, each with a meaningful name.  Some of the functions, such as  the ones for forward and reverse would be called more than once and using functions would make it easier to understand the flow of the code.  A function to make the mower spin in a random direction could also help to mix up the movement a little too.
Another point, it is not very kind to the motors to go from full speed forward to full speed backwards without a period of time when they are stopped.  It would be even kinder to the motors to bring them up to full speed over a period of time rather than instantaneously, but that can be added to your present code.  You could do this inside the functions that I have suggested using as there would then only be one place to implement the changes.
Have you tried the mower on grass yet ?  The motor driving the blade looks too small to deliver much power, but maybe not.
Logged
NJ, USA
Offline Offline
Newbie
View Profile
WWW
as it is winter, there is no grass to cut sadly. But once the snow melts and it warms up a bit I will try it out on the grass. The blade I made is pretty lite and it spins very quickly on the motor, we'll see what happens when there is a little resistance with grass. As for your other points, they make sense, but I don't really know anything about coding to be able to properly implement them. It is something I can work on in the future, but for now I Am just glad I got it working.
Logged
East Anglia (UK)
Online Online
Edison Member
View Profile
You are right to be pleased that it works but I am fairly sure that it won't cut the grass, but we shall see.
As to my suggestion to use functions, here is a modified portion of your code that illustrates the idea
Code:
    backup(FULLSPEED);
    delay(1500);
    spinRight(FULLSPEED);
    delay(randNumber);
    forward(FULLSPEED);
void forward(int speed)
  leftMotor(FORWARD, speed);
  rightMotor(FORWARD, speed);
void backup(int speed)
  leftMotor(REVERSE, speed);
  rightMotor(REVERSE, speed);
void spinRight(int speed)
To my mind it is easier to understand what is going and make the loop() function less cluttered.  You could take the idea even further and combine these lines
Code:
    backup(FULLSPEED);
    delay(1500);
    delay(randNumber);
into a function called, perhaps avoidRight(), and call it when you want to back up and spin right.  How far you take it is up to you.
Creating functions like these also allows you to copy them to other programs without the need to write the code again.
What next ?
A robot vacuum cleaner perhaps.  Yes, I do know that they are already available !
Logged
NJ, USA
Offline Offline
Newbie
View Profile
WWW
I Can give that a try at some point, as for the robot vacuum, I already own a roomba 550 and an older 400 series. The 400 series has non-functional brush motor, but other than that it works, was thinking of converting it into something.
Logged
Pages: 1 2 [3]   Go Up
Print
Jump to:
