NJ, USA
« on: January 30, 2013, 07:48:03 pm » |
I am making a Robot Lawnmower and it is very basic. I am using an UNO with the arduino Motor Shield. This is my first attempt at a sketch and using someone elses sketch as a guide (he used a different motor shield) along with a motor shield tutorial I found online, I came up with this. /* Mowbot software version 2f with random number turning */int bumpPin1 = 2; int bumpPin2 = 3; int val; int randNumber;
void setup() { // initialize the digital pins as an outputs. // Pins to control motor shield
pinMode(12, OUTPUT); pinMode(9, OUTPUT); pinMode(13,OUTPUT); pinMode(8,OUTPUT);
void loop() { val = analogRead(bumpPin1); randNumber = random(600, 1500); if (val == HIGH) { // if no objects detected on bump sensor right digitalWrite(12, HIGH); //Establishes forward direction of Channel A digitalWrite(9, LOW); //Disengage the Brake for Channel A analogWrite(3, 255); //Spins the motor on Channel A at full speed digitalWrite(13, HIGH); //Establishes forward direction of Channel B digitalWrite(8, LOW); //Disengage the Brake for Channel B analogWrite(11, 255); //Spins the motor on Channel B at full speed } else { // if objects detected on right sensor digitalWrite(12, LOW); //Establishes backward direction of Channel B digitalWrite(9, LOW); //Disengage the Brake for Channel B analogWrite(3, 123); //Spins the motor on Channel B at half speed digitalWrite(13, LOW); //Establishes backward direction of Channel B digitalWrite(8, LOW); //Disengage the Brake for Channel B analogWrite(11, 123); //Spins the motor on Channel B at half speed delay(1500); digitalWrite(13, LOW);// keep motor b running to turn digitalWrite(8, LOW); delay(randNumber); analogWrite(11, 123); //Spins the motor on Channel B at half speed } val = analogRead(bumpPin2); randNumber = random(600, 1500); if (val == HIGH) { // if no objects detected on bump sensor right digitalWrite(12, HIGH); //Establishes forward direction of Channel A digitalWrite(9, LOW); //Disengage the Brake for Channel A analogWrite(3, 255); //Spins the motor on Channel A at full speed digitalWrite(13, HIGH); //Establishes forward direction of Channel B digitalWrite(8, LOW); //Disengage the Brake for Channel B analogWrite(11, 255); //Spins the motor on Channel B at full speed } else { // if objects detected on right sensor digitalWrite(12, LOW); //Establishes backward direction of Channel B digitalWrite(9, LOW); //Disengage the Brake for Channel B analogWrite(3, 123); //Spins the motor on Channel B at half speed digitalWrite(13, LOW); //Establishes backward direction of Channel B digitalWrite(8, LOW); //Disengage the Brake for Channel B analogWrite(11, 123); //Spins the motor on Channel B at half speed delay(1500); digitalWrite(13, LOW);// keep motor b running to turn digitalWrite(8, LOW); analogWrite(11, 123); //Spins the motor on Channel B at half speed delay(randNumber); } }
Basically all I need it to do is go forward at full speed and if it bumps into something, back up, randomly turn and go forward again. I am using two micro switches for the bumpers. I have a 12VDC acid battery from an APC powering the Motor shield/motors, and a rechargable 9.6V (9v sized) battery powering the board. The Vin Connect pin I removed per suggestion from the Main site. The wiring goes from the battery, splits off to the blade motor and goes to the microswitches, then out of the switch to the motor shield, the other terminal on the micro switch will go to A2 and A3 but I haven't tried them connected yet. The ground connects to the ground for the blade motor, which connects to the battery. Does any of this seem wrong? Any help would be appreciated.
« Last Edit: January 30, 2013, 07:52:18 pm by OmegaRa »
Temple, Texas
« Reply #1 on: January 30, 2013, 08:06:37 pm » |
If I were you I'd start with the two microswitches. Get them working.... with very simple sketch ... play with it if ( bump( LEFT_SWITCH ) ) Serial.println("Left Bump"); if ( bump( RIGHT_SWITCH ) ) Serial.println("Right Bump");
Then add 1 motor Get it working, forward and reverse. Very simple sketch... play with it motorSpeed( LEFT_MOTOR, FORWARD, FULL); ... motorSpeed( RIGHT_MOTOR, REVERSE, HALF);
Then the other motor Then the "master control program"
NJ, USA
« Reply #2 on: January 30, 2013, 08:17:04 pm » |
I am going to have to watch some more tutorials. I was just trying to use the sketch someone else gave me /* Mowbot software version 2f with random number turning
*/ int infPin1 = 12; int infPin2 = 7; int bumpPin1 = 6; int bumpPin2 = 5; int val; int randNumber;
void setup() { // initialize the digital pins as an outputs. // Pins to control motor shield pinMode(8, OUTPUT); pinMode(9, OUTPUT); pinMode(10,OUTPUT); pinMode(11,OUTPUT); pinMode(infPin1, INPUT); pinMode(infPin2, INPUT); }
void loop() { val = digitalRead(infPin1); randNumber = random(600, 1500); // random number between 800 and 1500 if (val == HIGH) { // if no objects detected on left sensor digitalWrite(8, HIGH); // motor A forward digitalWrite(9, LOW); // motor A forward digitalWrite(10, HIGH); // motor B forward digitalWrite(11, LOW); // motor B forward } else { // if objects detected on left sensor delay(50); // wait for motor stop digitalWrite(8,LOW); // motor A back digitalWrite(9, HIGH); // motor A back digitalWrite(10, LOW); // motor B back digitalWrite(11, HIGH); // motor B back delay(1500); digitalWrite(8,HIGH); // Keep motor AB running to turn digitalWrite(9,LOW); delay(randNumber); //generate random number for turn } val = digitalRead(infPin2); randNumber = random(600, 1500); if (val == HIGH) { // if no objects detected on right sensor digitalWrite(8, HIGH); // motor A forward digitalWrite(9, LOW); // motor A forward digitalWrite(10, HIGH); // motor B forward digitalWrite(11, LOW); // motor B forward } else { // if objects detected on right sensor delay(50); // wait for motor stop digitalWrite(8,LOW); // motor A back digitalWrite(9, HIGH); // motor A back digitalWrite(10, LOW); // motor B back digitalWrite(11, HIGH); // motor B back delay(1500); digitalWrite(10, HIGH);// keep motor B running to turn digitalWrite(11,LOW); delay(randNumber); } val = digitalRead(bumpPin1); randNumber = random(600, 1500); if (val == HIGH) { // if no objects detected on bump sensor right digitalWrite(8, HIGH); // motor a forward digitalWrite(9, LOW); // motor a forward digitalWrite(10, HIGH); // motor b forward digitalWrite(11, LOW); // motor b forward } else { // if objects detected on right sensor digitalWrite(8,LOW); // motor a back digitalWrite(9, HIGH); // motor a back digitalWrite(10, LOW); // motor b back digitalWrite(11, HIGH); // motor b back delay(1500); digitalWrite(10, HIGH);// keep motor b running to turn digitalWrite(11,LOW); delay(randNumber); } val = digitalRead(bumpPin2); randNumber = random(600, 1500); if (val == HIGH) { // if no objects detected on bump sensor left digitalWrite(8, HIGH); // motor a forward digitalWrite(9, LOW); // motor a forward digitalWrite(10, HIGH); // motor b forward digitalWrite(11, LOW); // motor b forward } else { // if objects detected on left sensor digitalWrite(8,LOW); // motor a back digitalWrite(9, HIGH); // motor a back digitalWrite(10, LOW); // motor b back digitalWrite(11, HIGH); // motor b back delay(1500); digitalWrite(10, HIGH);// keep motor b running to turn digitalWrite(11,LOW); delay(randNumber); } }
Which worked for him ( I saw a video of it working) but as I didn't have IR sensors I removed that part, and because he used a different motor shield the pins were different. So back to the drawing board, time to learn some coding...
Left Coast, CA (USA)
Measurement changes behavior
« Reply #3 on: January 30, 2013, 08:30:33 pm » |
So back to the drawing board, time to learn some coding... Arduinos are not the best at plug-and-play, too much variation in board types and shields. They are much better when one bites the bullet and learns the programming language and make your own great sketches and projects. Lefty
NJ, USA
« Reply #4 on: January 30, 2013, 08:40:25 pm » |
yeah, I was just hoping, since it was a simple program, that I would be able to quickly get it going without having to get too heavily into learning C++, since right now I am also studying for my CCNA and trying to find a new job as a net admin. Learning a programming language at this point in time doesn't seem conducive. Just out of curiosity though, could you guys point me in the general direction of where I went wrong? I made one or two modifications that I think might help but I don't really know. This is just from looking at a couple on the in IDE and on the site examples. /* Mowbot software version 2f with random number turning */int bumpPin1 = A2; int bumpPin2 = A3; int val; int randNumber;
pinMode(12, OUTPUT); pinMode(9, OUTPUT); pinMode(13,OUTPUT); pinMode(8,OUTPUT); pinMode(A2, INPUT); pinMode(A3, INPUT);
void loop() { val = analogRead(bumpPin1); randNumber = random(600, 1500); if (val == HIGH) { // if no objects detected on bump sensor right digitalWrite(12, HIGH); //Establishes forward direction of Channel A digitalWrite(9, LOW); //Disengage the Brake for Channel A digitalWrite(3, 255); //Spins the motor on Channel A at full speed digitalWrite(13, HIGH); //Establishes forward direction of Channel B digitalWrite(8, LOW); //Disengage the Brake for Channel B digitalWrite(11, 255); //Spins the motor on Channel B at full speed } else { // if objects detected on right sensor digitalWrite(12, LOW); //Establishes backward direction of Channel B digitalWrite(9, LOW); //Disengage the Brake for Channel B digitalWrite(3, 123); //Spins the motor on Channel B at half speed digitalWrite(13, LOW); //Establishes backward direction of Channel B digitalWrite(8, LOW); //Disengage the Brake for Channel B digitalWrite(11, 123); //Spins the motor on Channel B at half speed delay(1500); digitalWrite(13, LOW);// keep motor b running to turn digitalWrite(8, LOW); delay(randNumber); analogWrite(11, 123); //Spins the motor on Channel B at half speed } val = analogRead(bumpPin2); randNumber = random(600, 1500); if (val == HIGH) { // if no objects detected on bump sensor right digitalWrite(12, HIGH); //Establishes forward direction of Channel A digitalWrite(9, LOW); //Disengage the Brake for Channel A digitalWrite(3, 255); //Spins the motor on Channel A at full speed digitalWrite(13, HIGH); //Establishes forward direction of Channel B digitalWrite(8, LOW); //Disengage the Brake for Channel B digitalWrite(11, 255); //Spins the motor on Channel B at full speed } else { // if objects detected on right sensor digitalWrite(12, LOW); //Establishes backward direction of Channel B digitalWrite(9, LOW); //Disengage the Brake for Channel B digitalWrite(3, 123); //Spins the motor on Channel B at half speed digitalWrite(13, LOW); //Establishes backward direction of Channel B digitalWrite(8, LOW); //Disengage the Brake for Channel B digitalWrite(11, 123); //Spins the motor on Channel B at half speed delay(1500); digitalWrite(13, LOW);// keep motor b running to turn digitalWrite(8, LOW); digitalWrite(11, 123); //Spins the motor on Channel B at half speed delay(randNumber); } }
Temple, Texas
« Reply #5 on: January 30, 2013, 08:45:29 pm » |
Just out of curiosity though, could you guys point me in the general direction of where I went wrong? Oh I didn't realize you have already hooked it all up? What is it doing wrong? I can't simulate all that code in my head, the way it's written...
Temple, Texas
« Reply #6 on: January 30, 2013, 08:48:39 pm » |
You mention providing power to a blade, are you really planning that? (or simulated) I don't see anything in the program that suggests turning on and off the blade mower. (Anyway, I'd recommend simulated  ) Cheers, John
NJ, USA
« Reply #7 on: January 30, 2013, 08:49:25 pm » |
it's not doing anything, the blade motor starts to spin (since it just gets direct power off the battery). The lights come on on the board and shield, but it doesn't move.
NJ, USA
« Reply #8 on: January 30, 2013, 08:50:36 pm » |
You mention providing power to a blade, are you really planning that? (or simulated) I don't see anything in the program that suggests turning on and off the blade mower. (Anyway, I'd recommend simulated  ) Cheers, John the blade motor is not controlled by the board, it just comes on when I flip the switch. edit: I actually first tried this bot with a homemade circuit using relays, I was able to get it to go forward, bump, back up, but I couldn't get it to turn (could figure out the caps). So I wanted to switch it to an Arduino.
« Last Edit: January 30, 2013, 08:52:26 pm by OmegaRa »
Temple, Texas
« Reply #9 on: January 30, 2013, 09:53:27 pm » |
Can you check the voltages on the pins e.g. 12, 9, and 3? I think the writes to pins 3 and 11 should be analogWrites. There may be other issues with that code... hard to tell
NJ, USA
« Reply #10 on: January 30, 2013, 09:57:50 pm » |
they were analog writes when I tried, nothing. So I tried switching it to digital, haven't actually tried it since changing the code. Last time I tried it it was the code from my first post.
Temple, Texas
« Reply #11 on: January 30, 2013, 10:07:24 pm » |
So... If it's just "nothing happens", we're back to what I said, test some pieces /* Mowbot Test Sketch 1 -- Motor */ const int LEFT_MOTOR=12, LEFT_BRAKE=9, LEFT_SPINNER=3; const int FORWARD=HIGH, REVERSE=LOW; const int FULLSPEED=255;
void leftMotor( int direction, int speed) { digitalWrite( LEFT_MOTOR, direction); //Establishes direction digitalWrite( LEFT_BRAKE , LOW); //Disengage the Brake digitalWrite( LEFT_SPINNER, speed); //Spins the motor }
void setup() { pinMode(LEFT_MOTOR, OUTPUT); pinMode(LEFT_BRAKE, OUTPUT); }
void loop() { leftMotor( FORWARD, FULLSPEED); delay( 4000); // on and off every 4 seconds leftMotor( FORWARD, 0 ); delay( 4000); }
« Last Edit: January 30, 2013, 10:23:17 pm by johncc »
NJ, USA
« Reply #12 on: January 30, 2013, 10:16:56 pm » |
Okay, I copied that sketch, but it is getting late and I need to call it quits for the night. I will test it out tomorrow and report back. Thanks for all the help so far
Temple, Texas
« Reply #13 on: January 30, 2013, 10:34:16 pm » |
Ok. We will get to the switches later, but if you continue with your code you will probably need to change your setup() to: pinMode(A2, INPUT_PULLUP); pinMode(A3, INPUT_PULLUP);
John
NJ, USA
« Reply #14 on: January 31, 2013, 09:48:17 am » |
John I will do that  just for informational purposes what does INPUT_PULLUP do?
