Pages: 1 [2] 3   Go Down
Author Topic: Question about my Sketch.  (Read 587 times)
Temple, Texas
An input pin when nothing is connected (or an open switch in your case) is indeterminate, neither low nor high (i.e. bouncing in between).  A pull-up resistor holds it gently but distinctly high, but allows a switch to ground to easily pull it distinctly low.  The INPUT_PULLUP enables a built-in pullup resistor.
A pull-down resistor addresses the same problem in the opposite way, but there is no built-in (you would have to provide externally)....
Cheers,
John
NJ, USA
so my next question would be, instead of A2 and A3, should I use the current sensing pins A0 and A1? or would that not make a difference?
East Anglia (UK)
May all of your blinks be without delay
The first thing that strikes me is that motor controllers usually need 3 inputs to control each motor.
The first sketch from the OP defines 4 pins (8, 9, 10 and 11) as outputs
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  pinMode(10,OUTPUT);
  pinMode(11,OUTPUT);
In the first sketch posted the 4 outputs are used as follows
  digitalWrite(8,LOW);   // motor A back
  digitalWrite(9, HIGH);   // motor A back
  digitalWrite(10, LOW);    // motor B back
  digitalWrite(11, HIGH);    // motor B back
In the next sketch 4 pins (8, 9, 12, 13) have been defined as outputs
  pinMode(12, OUTPUT);
  pinMode(9, OUTPUT);
  pinMode(13,OUTPUT);
  pinMode(8,OUTPUT);
and used in the sketch
    digitalWrite(12, HIGH); //Establishes forward direction of Channel A
    digitalWrite(9, LOW);   //Disengage the Brake for Channel A
    digitalWrite(3, 255);   //Spins the motor on Channel A at full speed
    digitalWrite(13, HIGH); //Establishes forward direction of Channel B
    digitalWrite(8, LOW);   //Disengage the Brake for Channel B
    digitalWrite(11, 255);   //Spins the motor on Channel B at full speed
but pins 3 and 11 are not defined as outputs so will default to being inputs so will not behave as outputs
At no time are 6 pins (3 per motor) defined as outputs and used in the sketch.
One useful thing to do would be to give the pins meaningful names which would make reading the code easier.
I am in agreement with John that the full sketch be put aside for now and that a start should be made with small steps.
NJ, USA
The second sketch was merely to show the sketch that I was basing mine off of. It is not actually the one I am using. The guy who did that one used a different shield,
East Anglia (UK)
The fact remains that neither sketch uses 3 pins defined as outputs to control the shield.
Motor channel A uses pin 12 to control direction, pin 9 for braking and pin 3 to control speed whilst motor channel B uses pin 13 to control direction, pin 8 for braking and pin 11 to control speed.  Pins A0 and A1 are used for current sensing if required, but are not necessary unless current sensing is needed.
There are a number of things wrong with your sketch such as reading an analog value from the bump pins then testing whether the value(s) are HIGH.  This could work but it would be more normal to read the digital value and test it for HIGH/LOW.
In this snippet
  pinMode(9, OUTPUT);
  pinMode(13,OUTPUT);
  pinMode(8,OUTPUT);
  pinMode(A2, INPUT);
  pinMode(A3, INPUT);
  val = analogRead(bumpPin1);
  randNumber = random(600, 1500);
  if (val == HIGH) { // if no objects detected on bump sensor right
pins 3 and 11 are used as outputs but are not defined as such.
You need to start with simple sketches that run the motor(s) and work from there
Try this
int motorA_dir = 12;    //direction
int motorA_brake = 9;   //brake
int motorA_speed = 3;   //speed
  pinMode (motorA_dir, OUTPUT);    //set 3 pins to be outputs
  pinMode (motorA_brake, OUTPUT);
  pinMode (motorA_speed, OUTPUT);
  digitalWrite(motorA_dir,HIGH);  //direction 1
  digitalWrite(motorA_brake,LOW);  //brake off
  for (int motorSpeed = 0;motorSpeed <=255 ;motorSpeed++)
    analogWrite(motorA_speed, motorSpeed);  //set the motor speed
    delay(100);                             //slow down the for loop a little
  analogWrite(motorA_speed, 0);  //let the motor coast to a stop
One motor should run up from its slowest speed to its highest then stop.  Note how giving the Arduino pins names helps to make the code more readable.
Temple, Texas
OmegaRA,
Have you been able to get your motor to even turn on, using the code I posted in reply #11 or UKHeliBobs in #20?
This would confirm whether your shield is working and your wiring is valid...
John
NJ, USA
OmegaRA,
John
I was at work all day and didn't get to tinker. Just got home and finished dinner and a grocery shop will attempt the tinker now. Have to go downstairs and load your sketch to the UNO and hook it up to see.
NJ, USA
The fact remains that neither sketch uses 3 pins defined as outputs to control the shield...
...You need to start with simple sketches that run the motor(s) and work from there
Try this
I see what you are saying. I will give that a go as well, so obviously the sketch you provided is for a single motor, but once I get at least one working then it is a matter of adding the second..
NJ, USA
OmegaRA,
John
okay, yes, your sketch gets the one motor spinning smiley
Temple, Texas
That's great-- your shield and wiring is working!
void leftMotor( int direction, int speed)
    digitalWrite( LEFT_MOTOR, direction); //Establishes direction fwd/back
    digitalWrite( LEFT_BRAKE , LOW);      //Disengage the Brake
    digitalWrite( LEFT_SPINNER, speed);   //Spins the motor
Can you see how you would add a rightMotor() ?
Cheers,
John
NJ, USA
void rightMotor( int direction, int speed)
    digitalWrite( RIGHT_MOTOR, direction); //Establishes direction fwd/back
    digitalWrite( RIGHT_BRAKE , LOW);      //Disengage the Brake
    digitalWrite( RIGHT_SPINNER, speed);   //Spins the motor
Cheers,
John
seem right for this section of code?
Here is a quick attempt at adding the Right pins and void setup, a little confused as to where to put stuff in the loop...
   Mowbot Test Sketch 1 -- Motor
const int RIGHT_MOTOR=13, RIGHT_BRAKE=8, RIGHT_SPINNER=11;
const int LEFT_MOTOR=12, LEFT_BRAKE=9, LEFT_SPINNER=3;
const int FORWARD=HIGH, REVERSE=LOW;
const int FULLSPEED=255;
  digitalWrite( LEFT_MOTOR, direction); //Establishes direction of Channel A
  digitalWrite( RIGHT_MOTOR, direction); //Establishes direction of Channel B
  pinMode(LEFT_MOTOR, OUTPUT);
  pinMode(LEFT_BRAKE, OUTPUT);
  leftMotor( FORWARD, FULLSPEED);
  pinMode(RIGHT_MOTOR, OUTPUT);
  pinMode(RIGHT_BRAKE, OUTPUT);
  rightMotor( FORWARD, FULLSPEED);
  delay( 4000);    // on and off every 4 seconds
  leftMotor( FORWARD, 0 );
  delay( 4000);
« Last Edit: January 31, 2013, 09:05:10 pm by OmegaRa » Logged
Temple, Texas
void setup()   // This runs once when you power up or reset
  leftMotor( FORWARD, FULLSPEED);   // *** don't need this here
  rightMotor( FORWARD, FULLSPEED);  // *** don't need this here
void loop()   // This one loops over and over
  delay( 4000);
}  // it goes from here back to the start of loop *instantly*
I would recommend removing the indicated *** lines in setup,  Compile and run, the motor should go on 4 seconds and then off 4 seconds, on 4, off 4.  Then in loop() just change the leftMotors()s to rightMotor().  You're just making sure the motor works here.
Also see if you can add the lines in the loop, to test the reverse:
   right fwd full
   delay
   right fwd 0    (stop)
   delay
   right reverse full
   delay
Modify for both motors fwd, 1 fwd 1 reverse, half speed (128), etc.
Make sure you understand the concept that setup runs once, first-- and loop then runs forever, over and over.
Cheers,
John
« Last Edit: January 31, 2013, 09:58:17 pm by johncc » Logged
NJ, USA
Okay, I will test that out when I get home from work.
Pittsburgh, PA, USA
I only know some basic electricity....
I am making a Robot Lawnmower and it is very basic.
Does any of this seem wrong?
Besides learning with a first sketch that runs something that could seriously hurt someone?
What could seem wrong?
Examples can be found at Learning in the Main Site and at the Playground
NJ, USA
I built it with a blade cover, and it is low to the ground, small chance of it hurting someone, but I hear you.
Pages: 1 [2] 3   Go Up
