Topic: SainSmart LCD Shield (Read 2814 times) previous topic - next topic
BFG42
Hello all I am new to the arduino world and I am having a terrible time with this code any input would be great! I am just trying to make a simple quiz and I have the LCD working the way I want it to the only problem I am having is on the sheild there are 6 buttons all mapped to analog pin 0. I am wanting the if statement to use the left button for yes and the right button for no all other buttons give a funny error message. What i am having issues with is when I press the left button the display shows Q1? and then immediately moves to YAY! when I have not pushed the left button a second time yet. any help would be much appreciated!
//Sample using LiquidCrystal library
#include <LiquidCrystal.h>
// select the pins used on the LCD panel
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
// define some values used by the panel and buttons
int lcd_key     = 0;
int adc_key_in  = 0;
#define btnRIGHT  0
#define btnUP     1
#define btnDOWN   2
#define btnLEFT   3
#define btnSELECT 4
#define btnNONE   5
// read the buttons
int read_LCD_buttons()
adc_key_in = analogRead(0);      // read the value from the sensor
// my buttons when read are centered at these valies: 0, 144, 329, 504, 741
// we add approx 50 to those values and check to see if we are close
if (adc_key_in > 1000) return btnNONE; //
if (adc_key_in < 50)   return btnRIGHT;
if (adc_key_in < 195)  return btnUP;
if (adc_key_in < 380)  return btnDOWN;
if (adc_key_in < 555)  return btnLEFT;
if (adc_key_in < 790)  return btnSELECT;
return btnNONE;
lcd.begin(16, 2);              // start the library
lcd.setCursor(0,0);
lcd.print("greetings"); // print a simple message
delay (2000);
lcd.clear();
lcd.print ("Q0?");
lcd.setCursor(9,1);            // move cursor to second line "1" and 9 spaces over
lcd.setCursor(0,1);            // move to the begining of the second line
lcd_key = read_LCD_buttons();  // read the buttons
   if (lcd_key == btnLEFT)
     lcd.clear();
     lcd.setCursor(0,0);
     lcd.print("Q1?");
         if (lcd_key==btnLEFT)
            lcd.clear();
            lcd.setCursor(0,0);
           lcd.print("YAY!");
pYro_65
You have not changed the value of lcd_key, so you cannot expect it to be any different.
Have a look how lcd_key is initialised, then what you compare it with in the if statements.
Sorry I can't elaborate, I have to head back to work.
Forum Mod anyone?
https://arduino.land/Moduino/
Nick Gammon
     lcd.print("Q1?");
         if (lcd_key==btnLEFT)   // which it WILL be
           lcd.print("YAY!");
More info:
BFG42
I guess what im asking is how do I reset the button so that I can have the left button used again for the nested if statement. I want the left button to equal yes and the right button to equal no.
Nick Gammon
You need a state machine. They won't hit the next button in the few microseconds those instructions take to execute.
http://en.wikipedia.org/wiki/State_machine
More info:
BFG42
Im not sure why i did not think of using a finite state machine. I learned how to implement them last semester in my digital logic class. Thank you for pointing my mind in the right direction!
BFG42
Just in case someone else wants to make a quiz using analog pin for the buttons I found this for help!
http://playground.arduino.cc/code/FiniteStateMachine
