Loading...
Pages: [1]   Go Down
Author Topic: Disconnect client from Server/EthernetServer.  (Read 204 times)
Singapore
Offline Offline
Newbie
Arduino rocks
View Profile
From the docs http://arduino.cc/en/Reference/Ethernet, EthernetServer class doesn't seem to have a disconnect method for disconnecting connected clients. If there are more than 4 clients connected, EthernetServer would froze until one or two of the clients disconnect. This is a limitation of the shield:
Quote
The Arduino Ethernet Shield allows an Arduino board to connect to the internet. It is based on the Wiznet W5100 ethernet chip (datasheet). The Wiznet W5100 provides a network (IP) stack capable of both TCP and UDP. It supports up to four simultaneous socket connections. Use the Ethernet library to write sketches which connect to the internet using the shield. The ethernet shield connects to an Arduino board using long wire-wrap headers which extend through the shield. This keeps the pin layout intact and allows another shield to be stacked on top.
- http://arduino.cc/en/Main/ArduinoEthernetShield
Is there a way to disconnect clients from the EthernetServer once they're done doing their stuff?
Logged
Miramar Beach, Florida
Offline Offline
Faraday Member
View Profile
You should be using the client functions after the server.available() call. Take a look at my server code.
http://playground.arduino.cc/Code/WebServerST
This gets the client.
Code:
After that, use the client calls.
Code:
client.print();
client.println();
client.write();
//and when you are finished sending packets
client.stop();
edit: client.stop() is the "disconnect".
« Last Edit: January 31, 2013, 06:45:50 am by SurferTim » Logged
Singapore
Offline Offline
Newbie
Arduino rocks
View Profile
Thank you!
 smiley-sweat What was on my mind!?  smiley-lol
Logged
Pages: [1]   Go Up
Print
Jump to:
