Pages: [1] 2   Go Down
Author Topic: What next? Mega2560r3 ATmega16U2 DFU Win8 USB  (Read 1478 times)
The short version:  www.arduino.cc is out-of-date, Mega 2560 Rev 3 info is spread across creation, RESET does not blink LED "L", Blink won't upload, and I'm stuck.
_________________
The TL;DR version:
I'm writing this out of frustration with hope that it might save others some time, and that someone (hint, hint) will review and update the "official" web pages that are supposed to "help."
Here's what I have:
  • Windows 8 OS (yucch)
  • GIGABYTE GA-B75M-D3H motherboard (8 USB 2.0 and 4 USB 3.0)
  • Arduino Mega 2560 rev 3
Before plugging anything in, I went to the Official Getting Started page.  Read the whole thing top-to-bottom.  I noticed that Step 4, Installing Drivers does not mention Mega.  Hmmm.   And it does not mention Windows 8.  Double Hmmm.
Here's what I recall to the best of my frazzled ability:
1) Follow steps 1, 2 and 3.  After I plugged the board in, green LED comes on... good.  It's labelled ON, not PWR, but I can cope with that.  What's this yellow LED by the ATmega16u2 chip, though?  Labelled "L".  Schematic isn't much help: PWM 13 is low?  Thanks for that info. (see step 11)
2) Reading Step 4, I expected a driver installation process to begin, and a port to appear called "Arduino UNO (COMxx)".  Ok, maybe it would say "Arduino Mega (COMxx)" instead.  Nada.  No dialogs, no nothin'.
A peek at Device Manager shows "ATMega16U2 DFU" in "Other Devices", with yellow exclamation.  Properties shows no device drivers. Okay...
3) I tried to load the 2560 drivers in the 1.0.3 distribution, from the "drivers" subdirectory.  (right click -> Update Drivers -> Specific Location -> Have Disk -> Browse).  Oh, the driver isn't signed.  Read this.
4)  Booted with "Install unsigned drivers" allowed, and the wizard reports the driver "Could not start (Code 10)".  Really?  Now there's an entry in Ports for "Arduino Mega 2560 R3" with a yellow exclamation mark.
5) google, google, google, google... read Troubleshooting guide.  Could be cable?  Swapped.  Uninstall, reinstall, No change.
6) Could it be the FTDI drivers?  Step 4 said "not the 'FTDI USB Drivers' sub-directory", but I think that meant don't use them for the main processor.  They're for the FTDI USB interface.  Ooo, the VCP drivers from FTDI (CDM 2.08.24 WHQL Certified) are nice and signed.  They install successfully, and Device manager shows a new entry "ATmega16U2" under a new class "Atmel USB Devices".  No yellow exclamation mark, and its properties look good.  (I think...  it may have had "DFU" in the name.  Also, that entry in Device Manager disappeared when I successfully installed the 2560 driver in step 11 below.)
7) Tried installing the 2560 driver again.  No joy.  The 2560 entry has the same yellow exclamation mark, and no COM assignment.  google, read, google, read...
8 ) Here's an excerpt from the Programming section from the Official 2560 Description:
The ATmega16U2 (or 8U2 in the rev1 and rev2 boards) firmware source code is available in the Arduino repository. The ATmega16U2/8U2 is loaded with a DFU bootloader, which can be activated by:
  • On Rev1 boards: connecting the solder jumper on the back of the board (near the map of Italy) and then resetting the 8U2.
  • On Rev2 or later boards: there is a resistor that pulling the 8U2/16U2 HWB line to ground, making it easier to put into DFU mode. You can then use Atmel's FLIP software (Windows) or the DFU programmer (Mac OS X and Linux) to load a new firmware. Or you can use the ISP header with an external programmer (overwriting the DFU bootloader). See this user-contributed tutorial for more information.
I wonder if the ATmega16u2 chip is in DFU mode?  Why would a new board be in DFU mode?  Whatev.  I'll reload it with FLIP as suggested.  What exactly should I reload into the ATmega16u2 chip?  google, read, read... Obviously the firmwares from the dist down in the firmwares subdirectory.  According to the README, I should load MEGA-dfu_and_usbserial_combined.hex, although Arduino-COMBINED-dfu-usbserial-atmega16u2-Mega2560-Rev3.hex is notable.
9 )  In FLIP 3.4.7, I choose ATmega16u2 from the Select Device, choose USB from Communications, then load MEGA...hex.  I seem to recall having some "invalid address" errors pop up.  I tried to Read the device and got all FFs.  After that, I think I was able load the hex file.
10) In FLIP, I press Run and it performs the Erase, but fails to Program.  (I forget the error.)  I decide to try the steps manually: Erase, OK.  Run again (maybe Erase unchecked).  It works.  Whaaaat?  After that, I think the entry in Device Manager changed slightly, maybe to add the COM3 port assignment.  I seem to remember a "Device protect is on." error at some point.  Sorry.
11) Back in Device Manager, I try to load the 2560 again, and it works!  In Device Manager, there is a new Port entry called "Arduino Mega 2560 R3 (COM4)".  Finally!  However, I had forgotton to delete the bad 2560 device, so I do it now.  I also notice that the Device Manager entry for "ATmega16u2" has disappeared!
12) Back to the "Getting Started" guide, I perform step 5, Launch the Arduino app.  Under Tools, I select COM4 and 2560 board.  Under File, I load Examples -> 01.Basics -> Blink.  The infamous Blink.  From the code, I see a comment that "Pin 13 has an LED connected on most Arduino boards".   So... I guess that would be the yellow LED labelled "L" attached to PWM13.  Gotcha.  (Do I hear a collective "duh" in the force?  As if a thousand facepalms happened at once?)
13) I press Upload, and it compiles and says
Binary sketch size: 1,632 bytes (of a 258,048 byte maximum)
Then it begins to upload.  I notice the "RX" light blinks ON for 5 or 6 times, then the Arduino app status box says:
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
If I hold the SHIFT key down when I press Upload, I only get one error message:
avrdude: usbdev_open(): did not find any USB device "usb"
Hmph.  I expected more from a verbose mode.  google, read, google, read...
14) Perhaps the auto-reset isn't working for my board.  I'll try connecting pins 5 & 6 on the ICSP connector to do a reset.  As the Troubleshooting Guide says, "[press the reset button at]  different intervals of time between the two, up to 10 seconds or more."
With an interval of 4 seconds (too late?) I got this message:
avrdude: ser_send(): write error: sorry no info avail
I notice that I can't upload again, because there is no COM4 port any more.  Resetting the board removed the 2560 COM port from Device Manager?!?  Oh, the "ATmega16U2" reappeared in Device Manager under "Atmel USB Devices".  Unplugging the USB and plugging it back removes the 16U2 and restores the 2560 COM4 entries in Device Manager.  What?
15) The Troubleshooting Guide says
"Make sure there's a bootloader burned on your Arduino board. To check, reset the board. The built-in L LED (which is connected to pin 13) should blink. If it doesn't, there may not be a bootloader on your board."
When I connect pins 5 & 6, LED "L" does not blink.  I guess I don't have a bootloader, but danged if I know why not.
Final Questions:
Q1:  In the menus for Arduino.exe, I see there's a choice for programmer.  Mine is currently set to "avrisp mkii".  Is that correct?
Q2: I wonder if I need to force the HWB line to ground before going back to step 8 and re-loading MEGA...hex?  Incidentally, this is what my RESET-EN trace looks like:
Is the trace under the mask?  It doesn't look like it has been cut, but I'm not sure it was there to begin with.
(14) I'll connect those two during an upload... Oh well, no difference.
(15) This seems to suggest that an old avrdude may be the solution...  However, the old avrdude complains about programmer id "wiring".
Perhaps I'm stuck (like many others) at the "timeout" issue.  I just got to experience all the problems in one sitting.  smiley-cry  I'm most suspicious of its reset behavior: "L" doesn't blink and the entries change in Device Manager.   smiley-eek
Thanks in advance for any clarifications or suggestions,
/dev
« Last Edit: January 31, 2013, 10:23:00 am by /dev » Logged
Austin, TX
CMiYC
There is no FTDI chip on the Mega2560 (any version).
That's why there is a ATmega16u2.  It replaced the FTDI FT232.
www.cmiyc.com - A guide to being an Enginerd
Melbourne, Australia
Shannon Member
Lua rocks!
Only if you are using "Upload Using Programmer" which you don't normally have to do. And if you have that particular programmer.
I wonder if the FTDI chip is in DFU mode?  Why would a new board be in DFU mode?  Whatev.  I'll reload it with FLIP as suggested.
What FTDI chip? To be honest, I would have asked here before you started erasing the code on the USB interface chip.
Why are you connecting pins 5 and 6?
Isn't there a reset button?
I'm bemused by this post. They ship thousands of these boards. You shouldn't have to go through all this rather complex process.
Where did you buy this board from?
Shannon Member
Lua rocks!
This page:
http://www.arduino.cc/en/Guide/Troubleshooting#upload
says:
The Arduino Uno and Mega 2560 use standard drivers (USB CDC) provided by the operating system to communicate with the ATmega8U2 on the board.
Duh, in loading "FTDI" drivers on win8 to communicate with the ATmega16u2, I incorrectly associated FTDI with what's on the board.   smiley-red  FTDI is on the PC.  ATmega16u2 is on the Mega 2560.  Thanks for that!
I edited the OP to keep from cornfusing any other readers.  "Stupid" can't be fixed, while "ignorance" can.  I hope I'm the latter; my OP certainly is.  smiley-wink
Cheers,
/dev
Austin, TX
carpe diem
See this post for DFU mode:
http://arduino.cc/forum/index.php/topic,141407.msg1062815.html#msg1062815
The short answer is that if your 16U2 came un-programmed, there is a good chance the 2560 is un-programmed as well.
So even if you are able to reprogram the 16U2, you still need to figure out a way to program the 2560.
I would take it back and see if you can get a replacement.
Thanks, I wondered when I saw the two Upload choices in the File menu.
Right, see reply to James above.   smiley-red  The Device Manager originally said "ATmega16u2 DFU", but now it just says "ATmega16u2".
This page says:
This is actually an example of the mish-mash of product references in the Guide.  A different chip is on Rev 3.  And if the chip is in DFU mode, Windows won't see it as a COM port device.
Correct me if I'm wrong, but I think that the (unsigned) Mega 2560 driver for Windows expects to find an "appropriate" board plugged into one of the COM ports.  And the COM ports are controlled the standard drivers.  However, if the ATmega16u2 is in DFU mode, you'll need the FTDIchip.com drivers in order to load the ATmega16u2.  Then the board will be recognized as a COM port device, and you can load the 2560 driver.
Umm... er... is this the reset button?   smiley-red  I thought that was just hooked to one of the digital inputs, because when I pressed it, nothing blinked.  The screened "RESET" is partially obscured by the button case.  Yeah.  Plenty of facepalms goin' on out there...
Digi-Key.  I'm starting to wonder if this unit was returned from someone more ignorant than me.  Is that even possible?  smiley-grin
This experience certainly wasn't what I expected.  I'm not new to the field, but I am totally new to the Arduino product line.  At the risk of looking foolish, I decided to document what an newb might go through.  After all, I'll never be a first-time Arduino user again.  Maybe it will help clarify something in some other newb's mind.
I do think that the Windows VCP drivers from FTDIchip.com and the Arduino.cc driver signatures under Windows 8 ought to be addressed in the official pages, though.  It would have been nice if the official pages were duplicated and tailored for each board, rather than having to skip sections and go to other pages for all the info.
So.  I still have a board that doesn't blink "L" when reset.  Any opinions on what to try next?  I'm leaning towards making sure the ATmega16u2 is properly loaded.  The FLIP process was fraught with oddness.  Other suggestions, anybody?
Thanks again,
/dev
Austin, TX
CMiYC
Yes but FTDIchip drivers only talk to FTDI chips.  So I fail to see how this changed anything in your situation.
Although I'm clueless as to why, I can only tell you how it changed my situation: After installing the drivers, the board showed up (enumerated?) in Device Manager as "Ports -> ATmega16u2 DFU".
At the time, I guessed that out-of-date (plain vanilla? non-VCP?) drivers for my PC's FTDI chips originally made the board show up in Device Manager as "Other Devices -> ATmega16u2 DFU".  I don't think it was a PC/FTDI-to-Arduino/FTDI fix, because, as you note, there is no FTDI chip on the board.  I'm guessing it was more of a PC/FTDI VCP or device enumeration fix.  Is there something about VCP that is USB protocol-oriented rather than chip-oriented?  I could be remembering wrong, but that was the first step of progress after hours of flailing.
Still clueless,
/dev
« Last Edit: January 31, 2013, 02:25:29 pm by /dev » Logged
See this post for DFU mode.
Thanks, Louis!  I see that you posted while I was editing my previous reply.  I'm sure many people appreciate the time you take on many different forums.
Aaaand this is another example of an official page that can be used for Rev 3, if you know it's safe (thanks!).  Even the Hacking Home Page omits 16u2 and Rev 3.  Here's what the DFUProgramming8u2 page says:
choose the version suitable for your board, either arduino-usbserial/Arduino-usbserial-uno.hex or arduino-usbserial/Arduino-usbserial-mega.hex
Previously, I had read the README one directory up, in atmegaxxu2, which says to use MEGA-dfu_and_usbserial_combined.hex.  I suspected Arduino-COMBINED-dfu-usbserial-atmega16u2-Mega2560-Rev3.hex was the correct one, and that the README just didn't have a section for Mega 2560 Rev 3.  It kinda worked.  The "DFU" part of the device name went away, anyhow.
Per your suggestion, I'll use arduino-usbserial/Arduino-usbserial-atmega16u2-Mega2560-Rev3.hex...
...Ok, I feel better, because the FLIP load went flawlessly.  Nothing else has changed, though: "L" doesn't blink in reset, and uploading Blink fails.  Which probably means I'm back to this:
Yeah, it's been too long for me to return it... but I didn't expect this kind of problem.  Oh well, programming the 2560 from scratch is something I should probably know how to do anyway.  Is the only way to do this with an ICSP programmer?  Or is there some approach with the COMBINED hex files (hinted at here), which seem to contain both 2560 bits and 16u2 bits?  Or maybe a 2560 bootstrapper for the 16u2?
Cheers,
/dev
Correct me if I'm wrong, but I think I just found the answer on the official Hacking Bootloader page:
To burn the bootloader, you'll need to buy an AVR-ISP (in-system programmer), USBtinyISP or build a ParallelProgrammer. The programmer should be connected to the ICSP pins
Cheers,
/dev
Shannon Member
Lua rocks!
What I would do is get a Uno (or similar), or at least a second board. They are extremely useful to have around.
See my post here about programming a bootloader using one: http://www.gammon.com.au/forum/?id=11635
This shows how to detect what is loaded onto your main chip (ie. bootloader or not): http://www.gammon.com.au/forum/?id=11633
With a little extra hardware (an SD card board) you can upload sketches or bootloaders without using avrdude: http://www.gammon.com.au/forum/?id=11638
Or you can just set it up as an Arduino as ISP and program using the IDE.
This lets you rule in/out things like fuse settings, missing bootloader, etc.
Shannon Member
Lua rocks!
As for the documentation, so many different Arduinos are being released that the site may be lagging behind a bit in places regarding that. You have the Leonardo (completely different main chip), the Mega (different chip from the Uno), and the different USB interface chips they have been using. And now they are releasing the Due. It is exciting and interesting stuff, but updating all of the "getting started" pages may perhaps not always be the highest priority of the developers.
Also they support Windows, Mac, Linux. Plus you have the confusion of the different versions of Windows OS, Mac OS, and different flavours of Linux.
Generally this forum will be able so assist as there are likely to be people with a similar setup to yours, who can help you.
Here's a quick follow-up to all the great suggestions:
I now have extra boards (there will be several in my project) and an AVRISP mkii.  I decided to start with the mkii to see if I could read what, if anything, is on the 2560 rev3 board.  A few days ago, I downloaded and installed Atmel Studio 6, which installs Atmel USB.  According to the Atmel documentation, the next step is simply to plug in the mkii and wait for the magic to happen.
Nothin'.   smiley-mad  The green USB LED flicks on when I plug it in, then goes off.
A check of Device Manager showed "Jungo -> WinDriver".  I also saw an entry for "Other Devices -> AVRISP mkii" with the dreaded yellow exclamation mark.    @#$&!!!  Suspecting another Win8/x64 problem, I did a little digging around, but I didn't see anything conclusive for Atmel Studio 6.  I will have to investigate that later, unless somebody has a suggestion.
However, I remembered reading some of your (Nick's) posts about similiar "missing bootloader" problems, and you had asked about getting a dump with avrdude.  Of course, that requires a different USB driver, which also has the digital signature problem.  Sigh.  Long story short: I have successfully installed the libusb0 drivers and used the avrdude included in WinAVR to get a dump:
avrdude: Version 5.10, compiled on Jan 19 2010 at 10:45:23
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "D:\Program Files\WinAVR\bin\avrdude.conf"
         Using Port                    : usb
         Using Programmer              : avrispmkII
avrdude: usbdev_open(): Found AVRISP mkII, serno: 000200151366
         AVR Part                      : ATMEGA2560
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    10     8    0 no       4096    8      0  9000  9000 0x00 0x00
           flash         65    10   256    0 yes    262144  256   1024  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500V2
         Description     : Atmel AVR ISP mkII
         Programmer Model: AVRISP mkII
         Hardware Version: 1
         Firmware Version Master : 1.10
         Vtarget         : 5.0 V
         SCK period      : 8.00 us
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e9801
avrdude: safemode: lfuse reads as 62
avrdude: safemode: hfuse reads as 99
avrdude: safemode: efuse reads as FF
avrdude: safemode: Fuses OK
avrdude done.  Thank you.
Using the -U switch, it looks like the EEPROM is all 0xFF, but the flash dump only shows one S-record: S9030000FC.  Anything else I should try with avrdude?
BTW, when I open the Arduino IDE, it seems to correctly select the mkii programmer, so I was hoping that I will be able to choose the "Burn Bootloader" item and get this baby running again.  If that doesn't work, I'll try your suggestions for reading/programming the board with another Arduino.
Cheers,
/dev
« Last Edit: February 13, 2013, 09:07:08 pm by /dev » Logged
Shannon Member
Lua rocks!
Since the default state of EEPROM (and flash) is 0xFF they may well be not saving any bytes that are just that.
Pages: [1] 2   Go Up
