Topic: [HELP] Set the speed of 2 DC motors with H-Bridge (Read 3762 times) previous topic - next topic
Mats2006
Jan 31, 2013, 09:12 am Last Edit: Jan 31, 2013, 01:09 pm by Mats2006 Reason: 1
Hey,
I have a problem.
I want to set the two motors to different speed.
I'm using an H-Bridge.
Here's my sketch:
Code: [Select]
#define STATE_IDLE 0
#define STATE_INIT 1
#define STATE_RUNNING        2
#define STATE_EXITING        3
const int in1Pin = 5;  // H-Brücken-Eingangspins
const int in2Pin = 4;
const int in3Pin = 3;  // H-Brücken-Eingangspins
const int in4Pin = 2;
const int en1Pin = 6;
const int en2Pin = 7;
const int buttonPin = 8;
int buttonState = 0;
int Zustand;
 Zustand = STATE_IDLE;
 pinMode(buttonPin, INPUT);
 pinMode(in1Pin, OUTPUT);
 pinMode(in2Pin, OUTPUT);
 pinMode(in3Pin, OUTPUT);
 pinMode(in4Pin, OUTPUT);
 switch( Zustand )
   case STATE_IDLE: Idle();
   case STATE_INIT: Init();
   case STATE_RUNNING: Run();
   case STATE_EXITING: Exiting();
void Idle()
 buttonState = digitalRead(buttonPin);
 if (buttonState == HIGH) {
   Zustand = STATE_INIT;
void Init()
 Zustand = STATE_RUNNING;
void Run()
 analogWrite(en1Pin,70);
 analogWrite(en2Pin,100);
 digitalWrite(in1Pin,LOW);
 digitalWrite(in2Pin,HIGH);
 delay(1500);
 digitalWrite(in2Pin,LOW);
 digitalWrite(in3Pin,HIGH);
 digitalWrite(in4Pin,LOW);
 delay(5000);
 digitalWrite(in3Pin,LOW);
 digitalWrite(in1Pin,HIGH);
 delay(1500);
 Zustand = STATE_EXITING;
void Exiting()
But when I press the button, just one motor runs in the speed, given with 'en1Pin'.
Without trying to set the speed, the motors run correctly.
Hope you can help and sorry for my bad English.
Greets,
Mathis
UKHeliBob
Your code looks OK
Code: [Select]
  analogWrite(en1Pin,70);    //speed A
  analogWrite(en2Pin,100);    //speed B
  digitalWrite(in1Pin,LOW);  //1-2 run at speed A
  delay(1500);
  digitalWrite(in1Pin,LOW);  //1-2 stop
  digitalWrite(in3Pin,HIGH); //3-4 run at speed B
  delay(5000);
  digitalWrite(in3Pin,LOW);  //3-4 stop
  digitalWrite(in2Pin,LOW);  //1-2 run at speed A
  delay(1500);
I have annotated it to help me understand what I think you are trying to do
Can you confirm that the names you have given the pins correspond to the actual inputs on the H bridges ?
Please do not send me PMs asking for help.  Post in the forum then everyone will benefit from seeing the questions and answers.
michinyon
Do you have two H bridges, or are you somehow trying to use one ?
Mats2006
First, thanks for your replies.
I've connected the en1Pin to the ENB and the en2Pin to the ENA, the INPUT pins are correctly connected.
And yes I try to use one H-Bridge. And without trying to regular the speed, it works well.
UKHeliBob
What H bridge are you using ?   Can you provide a link to what you are using ?
If it has ENA and ENB inputs then it is almost certainly 2 H bridges, even if they are in 1 chip, possibly an L293 or similar.
UKHeliBob
Did you build the circuit yourself or buy it ready made ?
If you built it yourself what is the circuit ?
If ready made is there a link to the product ?
Mats2006
#7
Jan 31, 2013, 12:00 pm Last Edit: Jan 31, 2013, 12:24 pm by Mats2006 Reason: 1
I buyed it, here's a link:
http://my.safaribooksonline.com/getfile?item=ODMvZDlpY3B0L20vZ2VzOTg4Mzk5NjI1c2FzcjdhaWxjZW90dC9odHBvdG9tcmxjdW1zeW9yb2Vyc2VhZ2VwZTNlaWx5Z3JpYW55bXMzNjcwMTIuZ24ubGFtanBn
Evrything the same, except that I connected the ENB to Pin6 and added a second motor.
ash901226
for this kind of h bridge i would like to use functions actually
Code: [Select]
void Motor(boolean Dir, int Speed)
  int Stop;
  if (Dir ==Stop)
    digitalWrite(Pin1,LOW);
    digitalWrite(Pin2,LOW);
    digitalWrite(Pin1,Dir);
    digitalWrite(Pin2,!Dir);
    analogWrite(EnPin,Speed);
for dir you could specify HIGH and LOW,
AWOL
Code: [Select]
  int Stop;
  if (Dir ==Stop)
Really bad idea. Please rethink.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
ash901226
your write AWOL, Its should be and int instead of a  Boolean
Mats2006
UKHeliBob
I am all in favour of using functions but unless the inline code works when the inputs to the H bridge are set correctly then a function is not going to help.
To make things even easier to understand I have written a small class to control a motor attached to an H bridge but that does depend on the basic code working, of course.
AWOL
Quote
No, think again.
What is the value of "Stop"?
ash901226
ok How about this
Code: [Select]
void Motor1(boolean Pin1, boolean Pin2, int Speed)
  digitalWrite(in1Pin,Pin1);
  digitalWrite(in2Pin,Pin2);
  analogWrite(en1Pin,Speed);
void Motor2(boolean Pin1, boolean Pin2, int Speed)
  digitalWrite(in3Pin,Pin1);
  digitalWrite(in4Pin,Pin2);
  analogWrite(en2Pin,Speed);
