Loading...
Pages: 1 2 [3]   Go Down
Author Topic: Rotary potentiometer with steps/positions  (Read 825 times)
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
Quote
and detent positioning that doesn't always seem to line up with the electrical signal transition positions.
Most I have used only pass through the transition electrically when passing through it mechanically. When the control is sitting at rest the output is always the same.
Logged
United Kingdom
Offline Offline
Faraday Member
View Profile
WWW
What inputs will you be providing on the submenus? When using a rotary encoder, I generally use the built-in push button to cycle between different parameters or submenus, and the rotary motion to adjust the selected parameter.
Logged
Formal verification of safety-critical software, software development, and electronic design and prototyping. http://www.eschertech.com
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Quote
I found that I could force encoder steps just by applying slight pressure against the encoder knob without having to go through a detent click. Not at all positions and not all the time, but it just didn't have the precision feel and operation of the optical encoder I have. Like I said it could be made usable but I found them to be rather flimsy in actual operation.
Lefty
Logged
Offline Offline
Brattain Member
View Profile
The same, either a switch with a built in momentary push switch or a separate momentary switch to select the displayed menu option.
Lefty
Logged
United Kingdom
Offline Offline
Faraday Member
View Profile
WWW
I have one encoder in which one of the transitions occurs more or less at the same position as the detent. My rotary encoder driver software has a 1-state hyteresis to make it insensitive to this. Every encoder I have purchased since has the state transitions away from the detent. The problem encoder has 16 detents/rev, whereas now I go for 8 or 12.
Logged
Pages: 1 2 [3]   Go Up
Print
Jump to:
