Author Topic: [HELP NEEDED] Controlling 3-wheel omniwheel robot  (Read 131 times)
Hi, I am making a 3-wheels Omniwheel robot to move in a certain pattern.
Below is my code for controlling the robot:
#define motor1A 3
#define motor1C 5
#define motor2A 6
#define motor2C 9
#define motor3A 10
#define motor3C 11
#define clkwise 0
#define anticlkwise 1
#define M1
#define M2
#define M3
int halt = 0; // how bright the LED is
int incAmount = 5; // how many points to fade the LED by
String inputString = ""; // a string to hold incoming data
boolean stringComplete = false; // whether the string is complete
pinMode(motor1A, OUTPUT);
pinMode(motor1C, OUTPUT);
pinMode(motor2A, OUTPUT);
pinMode(motor2C, OUTPUT);
pinMode(motor3A, OUTPUT);
pinMode(motor3C, OUTPUT);
// reserve 200 bytes for the inputString:
inputString.reserve(20);
forward(200, 1000);
Below is the code for controlling the individual motor speed and direction:
#define cos60 0.5
#define sin60 0.866
float a1_sp;
float a2_sp;
float a3_sp;
char a1_speed;
char a2_speed;
char a3_speed;
void control(char robospeed, float roboangle, char roborotate )  {
  // assign the correct output pin for motor_num
  a1_sp= cos60*robospeed*cos(roboangle)- sin60*robospeed*sin(roboangle);
  a2_sp= 1*robospeed*cos(roboangle);
  a3_sp= cos60*robospeed*cos(roboangle)+ sin60*robospeed*sin(roboangle);
#ifdef M1
if (a1_sp > 0) {
    a1_speed = a1_sp+roborotate;
    motor(1, a1_speed, anticlkwise);
    else {
    a1_sp *=-1;
    motor(1, a1_speed, clkwise);
#endif
#ifdef M2
if (a2_sp > 0) {
    a2_speed = a2_sp+roborotate;
    motor(2, a2_speed, anticlkwise);
    else {
    a2_sp *=-1;
    motor(2, a2_speed, clkwise);
#endif
#ifdef M3
  if (a3_sp > 0) {
    a3_speed = a3_sp+roborotate;
    motor(3, a3_speed, anticlkwise);
    else {
    a3_sp *=-1;
    motor(3, a3_speed, clkwise);
#endif
 Below is the code for setting the speed and direct control of a specific motor
void motor(char motor_num, char speed_val, boolean direct )  {
  char motorLA;
  char motorLC;
  switch(motor_num) {
    case 1:
      motorLA = motor1A;
      motorLC = motor1C;
      break;
   case 2:
      motorLA = motor2A;
      motorLC = motor2C;
      break;
   case 3:
      motorLA = motor3A;
      motorLC = motor3C;
      break;
  if (direct) { // direct = 0:clockwise  direct = 1:anti-clockwise
    analogWrite(motorLA, 0);
    analogWrite(motorLC, speed_val);
  else {
     analogWrite(motorLC, 0);
     analogWrite(motorLA, speed_val);
Below is the code for moving the robot forward:
void forward(int speedval, int time)
  control (speedval, 3.141*0.5, 0);
  delay(time);
So, the above codes will be run together and allows the robot to move forward. But how do I move the robot to move in triangular waveform for 10 seconds?
Thank you.
« Last Edit: January 31, 2013, 10:18:21 am by newbie1 » Logged
Seattle, WA USA
Seattle, WA USA
Program it properly.
Malaysia
lol
UK
Do you mean it has to follow a sawtooth-like path, or it has to describe the perimeter of a triangle?
A sawtooth-like pattern. Example like this:
East Anglia (UK)
May all of your blinks be without delay
Questions :
Have you made the robot move forward for a fixed time at a fixed speed then stop ?
Have you made the robot turn 90 degrees right or left then stop ?
If you have then you know how to move it in the pattern that you describe
move forward
stop
spin right
stop
move forward
stop
spin left
stop
go back and do it over again
If not, then start by getting it to move forward a fixed amount and stop.  Write the code to do it, try it out and if it does not work post it here for help.
HINT - the forward(), control() and motor() functions need to be in your script.  They are not there in the script you posted although you did post them separately.
Seattle, WA USA
Seattle, WA USA
Keep in mind that just running the motor(s) for some amount of time does not equate to moving a fixed distance. If you don't have feedback for the distance moved, you will just be guessing as to the distance.
East Anglia (UK)
"Close enough for Jazz"
Worth bearing in mind, certainly, but refinements can come later.
