Loading...
Pages: [1]   Go Down
Author Topic: How to invert serial polarity  (Read 135 times)
Offline Offline
Newbie
View Profile
On the Arduino Uno, I would like to invert the polarity of the serial tx signal. The default setting is logic high = 5V. I would like to invert it to logic high = 0V.
I am able to do this using SoftwareSerial using the argument, true:
SoftwareSerial mySerial(10,11,true);
However, the SoftwareSerial's maximum speed is 115200 and I would like to run faster than that.
Is there a way to invert the serial polarity?
Logged
Norfolk UK
Offline Offline
Edison Member
View Profile
I'm not sure if the on chip USART supports inverted logic so you will probably need to run the signal(s) through a NOT gate like a 7404 (Expect to be told this is not suitable here)
« Last Edit: January 31, 2013, 12:43:47 pm by Riva » Logged
Global Moderator
Boston area, metrowest
Online Online
Brattain Member
Available for Design & Build services
View Profile
WWW
Run the line thru a transistor inverter with open collector (OC) output.
2N2222A or similar NPN transistor , 2 resistors.
When Tx is high, OC is low; when TX is low, OC is high.
Hardware serial can do up to 1Mbps rates. Don't know if the serial libary supports that directly.
I think I tested as high as 250000 with just small burts of data.
See Section 20 of the datasheet for hardware discussion.  Table 20-7 for supported speeds with 16 MHz system clock.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Offline Offline
Newbie
View Profile
That works perfectly. Thank you!
Logged
Pages: [1]   Go Up
Print
Jump to:
