Loading...
Pages: 1 [2]   Go Down
Author Topic: Please Need Help to combine two codes  (Read 335 times)
East Anglia (UK)
Online Online
Edison Member
May all of your blinks be without delay
View Profile
You MUST have a setup() function, that is what the error message is telling you.  Copy the statements from both setup() functions into setup() in the new combined code.  Look out for conflicts such as the same pin being used for different purposes in each original program.
If you are still stuck after combining the 2 setup() functions post your whole code here again.  There is no point looking at your code as it is now because there is no setup() function.
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
Or, better yet, call the two setupxxxx() functions that you do have from the new setup() function.
Logged
East Anglia (UK)
Online Online
Edison Member
View Profile
Good idea. although I think it would be easier to spot conflicts, especially in the use of pins, if the setup was in one function rather than two.
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
Agreed. Though, the code should probably be moved, then, not copied.
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
