Topic: Please Need Help to combine two codes (Read 4356 times) previous topic - next topic
zajebiscie
HEllo eveyone, i am still a newbie in arduino programming, and i need your help. I m trying to merge two codes together, IDLE MODE CODE_FSR interrupt, and FingerScanner&Step motorCODE. My general idea for this code is, while holding a FSR sensor, the arduino will be awake , and then a finger will be scan with fingerprint scanner.If the finger is correspond with the finger image stored in the data sheet, it will move the stepmotor backward and continue waiting until FSR is release, But immediately the FSR sensor is release, the stepmotor will move back to its inital state and then arduino system will go back to idle mode to save battery. PLEASE PLEASE NEED YOUR HELP.
FYI....When my Arduino Uno is gone to IDLE mode for power save, i m using FSR sensor at pin 2 as means of interruping to wakeup the system.
FIRST CODE IS FOR SAVE POWER_IDLE MODE_CODE_FSR interrupt
#include <avr/interrupt.h>
#include <avr/power.h>
#include <avr/sleep.h>
#include <avr/io.h>
void setup(void)
DDRD &= B00000011; // set Arduino pins 2 to 7 as inputs, leaves 0 & 1 (RX & TX) as is
DDRB = B00000000; // set pins 8 to 13 as inputs
PORTD |= B11111100; // enable pullups on pins 2 to 7
PORTB |= B11111111; // enable pullups on pins 8 to 13
pinMode(13,OUTPUT); // set pin 13 as an output so we can use LED to monitor
pinMode(11,OUTPUT);
digitalWrite(13,HIGH); // turn pin 13 LED on
digitalWrite(11,HIGH);
void loop(void)
// Stay awake for 1 second, then sleep.
// LED turns off when sleeping, then back on upon wake.
delay(100);
sleepNow();
void sleepNow(void)
 while(digitalRead(2)==LOW);
   /* Now is the time to set the sleep mode. In the Atmega8 datasheet
    * http://www.atmel.com/dyn/resources/prod_documents/doc2486.pdf on page 35
    * there is a list of sleep modes which explains which clocks and
    * wake up sources are available in which sleep modus.
    * In the avr/sleep.h file, the call names of these sleep modus are to be found:
    * The 5 different modes are:
    *     SLEEP_MODE_IDLE         -the least power savings
    *     SLEEP_MODE_ADC
    *     SLEEP_MODE_PWR_SAVE
    *     SLEEP_MODE_STANDBY
    *     SLEEP_MODE_PWR_DOWN     -the most power savings
    *  the power reduction management <avr/power.h>  is described in
    *  http://www.nongnu.org/avr-libc/user-manual/group__avr__power.html
// Set pin 2 as interrupt and attach handler:
attachInterrupt(0, pinInterrupt, LOW);
delay(100);
// Choose our preferred sleep mode:
set_sleep_mode(SLEEP_MODE_IDLE);
// Set sleep enable (SE) bit:
sleep_enable();
 power_adc_disable();
 power_spi_disable();
 power_timer0_disable();
 power_timer1_disable();
 power_timer2_disable();
 power_twi_disable();
// Put the device to sleep:
digitalWrite(13,LOW); // turn LED off to indicate sleep
sleep_mode();
// Upon waking up, sketch continues from this point.
sleep_disable();
digitalWrite(13,HIGH); // turn LED on to indicate awake
digitalWrite(11,LOW);
power_all_enable();
void pinInterrupt(void)
sleep_disable();
detachInterrupt(0);
The SECOND CODE is for FINGERPRINT SCANNER&STEPMOTOR
#include <Stepper.h>
#include <Adafruit_Fingerprint.h>
#if ARDUINO >= 100
#include <SoftwareSerial.h>
#else
#include <NewSoftSerial.h>
#endif
const int stepsPerRevolution = 200;  // change this to fit the number of steps per revolution
                                    // for your motor
boolean lock_state;
// initialize the stepper library on pins 8 through 11:
Stepper myStepper(stepsPerRevolution, 8,9,10,11);
int getFingerprintIDez();
void lock_motor();
// pin #2 is IN from sensor (GREEN wire)
// pin #3 is OUT from arduino  (WHITE wire)
#if ARDUINO >= 100
SoftwareSerial mySerial(2, 3);
#else
NewSoftSerial mySerial(2, 3);
#endif
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
 lock_state = HIGH;
   // set the speed at 60 rpm:
 myStepper.setSpeed(60);
 // initialize the serial port:
 //Serial.begin(9600);
 Serial.println("fingertest");
 // set the data rate for the sensor serial port
 finger.begin(57600);
 if (finger.verifyPassword()) {
   Serial.println("Found fingerprint sensor!");
   Serial.println("Did not find fingerprint sensor :(");
   while (1);
 Serial.println("Waiting for valid finger...");
void loop()                     // run over and over again
//    // step one revolution  in one direction:
//   Serial.println("clockwise");
//  myStepper.step(stepsPerRevolution);
//  delay(500);
//   // step one revolution in the other direction:
//  Serial.println("counterclockwise");
//  myStepper.step(-stepsPerRevolution);
//  delay(500);
uint8_t getFingerprintID() {
 uint8_t p = finger.getImage();
 switch (p) {
   case FINGERPRINT_OK:
     Serial.println("Image taken");
     break;
   case FINGERPRINT_NOFINGER:
     Serial.println("No finger detected");
     return p;
   case FINGERPRINT_PACKETRECIEVEERR:
     Serial.println("Communication error");
     return p;
   case FINGERPRINT_IMAGEFAIL:
     Serial.println("Imaging error");
     return p;
   default:
     Serial.println("Unknown error");
     return p;
 // OK success!
 p = finger.image2Tz();
 switch (p) {
     Serial.println("Image converted");
     break;
   case FINGERPRINT_IMAGEMESS:
     Serial.println("Image too messy");
     return p;
     return p;
   case FINGERPRINT_FEATUREFAIL:
     Serial.println("Could not find fingerprint features");
     return p;
   case FINGERPRINT_INVALIDIMAGE:
     return p;
   default:
     return p;
 // OK converted!
 p = finger.fingerFastSearch();
 if (p == FINGERPRINT_OK) {
   Serial.println("Found a print match!");
 } else if (p == FINGERPRINT_PACKETRECIEVEERR) {
   return p;
 } else if (p == FINGERPRINT_NOTFOUND) {
   Serial.println("Did not find a match");
   return p;
   return p;
 // found a match!
 Serial.print("Found ID #"); Serial.print(finger.fingerID);
 Serial.print(" with confidence of "); Serial.println(finger.confidence);
// returns -1 if failed, otherwise returns ID #
int getFingerprintIDez() {
 if (p != FINGERPRINT_OK)  {
   lock_motor();
   return -1;
   lock_motor();
   return -1;
   lock_motor();
   return -1;
 // found a match!
 if (lock_state == HIGH){
     //This is for the motor
 lock_state = LOW;
 return finger.fingerID;
void lock_motor(){
 if (lock_state == LOW){
   // Is for the motor step one revolution in the other direction:
 lock_state = HIGH;
PaulS
How are you powering the stepper motor? Those thing require a LOT of current. No dinky battery is going to power a stepper motor for any useful period of time.
zajebiscie
Thanks for your quick reply. Yes i am going to use 9V battery for stepper motor, and it is really a small stepper motor....
HazardsMind
#3
Jan 31, 2013, 05:49 pm Last Edit: Jan 31, 2013, 05:51 pm by HazardsMind Reason: 1
9V battery
Do you mean a regular store bought 9V? If so, dont bother, that battery will last you maybe 20 - 30 minutes of continious use, maybe. Unless you plan on getting 4 or 5 of them and putting them in parallel. Get a 9V rechargeable battery pack, like the ones used in Hobby RC cars. Those have a LOT of current, and can be reused.
Time wise, depends on the battery's mAh's.
My GitHub:
https://github.com/AndrewMascolo?tab=repositories
zajebiscie
9V battery
thanks for your help
zajebiscie
Please i still need help to combine my two codes...thanks
HazardsMind
It should just a simple drag and drop, but you have both codes using pins 11 and 2, so those will have to be changed. Another thing to watch out for is delays. The first one has two active delays but they are only 200 ms, which is not bad, but the second code also has two active delays that add up to 1 second, that might be bad. I dont know if time is an issue for you, but in total you have 1.2 seconds of delay. That 1.2 seconds it what it will take until the code is looped again.
My GitHub:
zajebiscie
Thanks for your help, please can you help me put them together. I do not mind if you assign the pins 11 and 2 to different pins number so they would not interfere with other, but it would be good if pin 2 still be the interrupt pin for wakeup (FSR).For the time, it matters a lot, because the whole idea for the system work faster, which ever time you think will be the best, i m willing to work with it...please help me.
HazardsMind
Try to do it on your own first, that way you get an idea of what is happening with the codes. Try to combine them then, come back and post the combined code along with any and all errors. Now if you have no idea of even where to start and are willing to pay someone to do it for you, then check out the Gigs and Collaboration page.
  http://arduino.cc/forum/index.php/board,26.0.html
My GitHub:
zajebiscie
I combined these codes but it is not working for me..Please help me look into this code.
#if ARDUINO >= 100
#else
#endif
#include <avr/io.h>
                                     // for your motor
boolean lock_state;
void lock_motor();
#if ARDUINO >= 100
#else
#endif
//bbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbb
pinMode(11,OUTPUT);
  lock_state = HIGH;
    while (1);
delay(100);
sleepNow();
void sleepNow(void)
delay(100);
sleep_enable();
sleep_mode();
sleep_disable();
power_all_enable();
  switch (p) {
      break;
      return p;
      return p;
      return p;
    default:
      return p;
  // OK success!
  switch (p) {
      break;
      return p;
      return p;
      return p;
      return p;
    default:
      return p;
  // OK converted!
    return p;
    return p;
    return p;
  // found a match!
    lock_motor();
    return -1;
    lock_motor();
    return -1;
    lock_motor();
    return -1;
  // found a match!
  lock_state = LOW;
void lock_motor(){
  lock_state = HIGH;
sleep_disable();
detachInterrupt(0);
zajebiscie
I merged two codes but not sure i m doing it correct. Please can someone looking into my program and see i m doing it correct because i am not good in programming...thanks
#if ARDUINO >= 100
#else
#endif
#include <avr/io.h>
                                     // for your motor
boolean lock_state;
void lock_motor();
// pin #4 is IN from sensor (GREEN wire)
#if ARDUINO >= 100
SoftwareSerial mySerial(4, 3);
#else
NewSoftSerial mySerial(4, 3);
#endif
pinMode(11,OUTPUT);
  lock_state = HIGH;
    while (1);
delay(100);
sleepNow();
void sleepNow(void)
delay(100);
sleep_enable();
digitalWrite(6,HIGH);
sleep_mode();
sleep_disable();
digitalWrite(6,LOW);
power_all_enable();
  switch (p) {
      break;
      return p;
      return p;
      return p;
    default:
      return p;
  // OK success!
  switch (p) {
      break;
      return p;
      return p;
      return p;
      return p;
    default:
      return p;
  // OK converted!
    return p;
    return p;
    return p;
  // found a match!
    lock_motor();
    return -1;
    lock_motor();
    return -1;
    lock_motor();
    return -1;
  // found a match!
  lock_state = LOW;
void lock_motor(){
  lock_state = HIGH;
sleep_disable();
detachInterrupt(0);
HazardsMind
What are you getting as opposed to what your not getting?
From what I see, your getting some confliction here.
pinMode(13,OUTPUT);
pinMode(11,OUTPUT);
I can't look at all of if right now, myself, but just skimming through it, there are a few mistakes.
You know both codes work indepently, so try some debugging with the serial monitor.
Post any and all errors.
My GitHub:
zajebiscie
pinMode(13,OUTPUT);
pinMode(11,OUTPUT);
I tried to combine it, there was a problem saying UNDIFINED REFRENCE TO 'SETUP'
#include <avr/io.h>
#include <VirtualWire.h>
#if ARDUINO >= 100
#else
#endif
                                    // for your motor
boolean lock_state;
void lock_motor();
// pin #6 is IN from sensor (GREEN wire)
// pin #7 is OUT from arduino  (WHITE wire)
#if ARDUINO >= 100
SoftwareSerial mySerial(6, 7);
#else
NewSoftSerial mySerial(6, 7);
#endif
void sleepsetup(void)
pinMode(5,OUTPUT); // set pin 13 as an output so we can use LED to monitor
pinMode(12,OUTPUT);
digitalWrite(5,HIGH); // turn pin 13 LED on
digitalWrite(12,HIGH);
void fingersetup()
 lock_state = HIGH;
   while (1);
void Recieversetup()
   Serial.begin(9600); // Debugging only
   Serial.println("RECEIVER");
   // Initialise the IO and ISR
   vw_set_ptt_inverted(true); // Required for DR3100
   vw_setup(2000); // Bits per sec
   vw_set_rx_pin(4);
   vw_rx_start();
   pinMode(13, OUTPUT);
void loop(void)
 delay(100);               //execute loop 10 times/second
 if (HIGH == digitalRead(2))      // if the FSR is not pressed
   sleepNow();               // then go to sleep.  Stays asleep until FSR is pressed.
delay(100);
  int msg_status = vw_have_message();
  uint8_t buf[VW_MAX_MESSAGE_LEN];
  uint8_t buflen = VW_MAX_MESSAGE_LEN;
  if (vw_get_message(buf, &buflen)); // Non-blocking [to reset the vw_rx_done flag]
  if(msg_status==1)
       Serial.println("Something");
       digitalWrite(13, HIGH);
       delay(100);
    Serial.println("Nothing");
    delay(100);
  digitalWrite(13, LOW);
void fingerloop()                     // run over and over again
 switch (p) {
     break;
     return p;
     return p;
     return p;
   default:
     return p;
 // OK success!
 switch (p) {
     break;
     return p;
     return p;
     return p;
     return p;
   default:
     return p;
 // OK converted!
   return p;
   return p;
   return p;
 // found a match!
   lock_motor();
   return -1;
   lock_motor();
   return -1;
   lock_motor();
   return -1;
 // found a match!
 lock_state = LOW;
void lock_motor(){
 lock_state = HIGH;
void sleeploop(void)
void sleepNow(void) {
 sleep_enable();
 delay(100);
 digitalWrite(5,LOW); // turn LED off to indicate sleep
 sleep_mode();
 digitalWrite(5,HIGH); // turn LED on to indicate awake
power_all_enable();
void pinInterrupt(void) {
 sleep_disable();
 detachInterrupt(0);
HazardsMind
You don't have a setup() function.
My GitHub:
zajebiscie
I thought if i rename my setup() fuctions, that will prevent it from interfering with other functions... Please can you take a look at my code..
