Topic: Problem : Sim900 V1.2 (seeedstudio) (Read 1 time) previous topic - next topic
kentuch
I'm a french student ,I have a project that will be noted for my tank. But I do not go ..
I bought a map R3 and Arduino shield gprs SeeedStudio (SIM900 V1.2), I plugged it like on their wiki: http://www.seeedstudio.com/wiki/GPRS_Shield_V1.0.
The ultimate goal is to control a servo motor thanks to sending a sms.
I use the arduino software 1.0, I'' ve installed the gogprs library. The examples of the style: Getimei, isReady work but not those related to network usage. The green green LED flashes every 800ms, which signifit that the card can not find the network ..
Is a power problem? Should I put a battery (cr1220 3V) which is under the SIM900 card? and then connect the Arduino board to the area with 5 or 9 V? or is it a problem of program? or configuration?
I'm lost I do not know what to do, and the date of examenarrive quickly ..
Please help me ..
thank you.
matjaz1973
Kentuch, have you succeded to solve the problem?
I have the same problem, googling around for days but no progress.
Plz inform us, if you found the solution!
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
