Topic: Please explain why Pin13 and Serial.write misbehaving (Read 999 times) previous topic - next topic
memotick
I stripped my code to the minimum and I just don't understand why I am getting pin 13 toggling and Serial.write not working in one case but not in the other.
I have three files: Debug the arduino sketch, Debug.h (the library header file) and Debug.cpp (the C++ library file)
With Debug.cpp as is shown below, I get pin 13 toggling on an UNO board and nothing is printed to serial out.
If I replace the "array[halfarraySize];" with "float array[halfarraySize];" in Debug.cpp, pin13 and the serial print behave properly.  Can you please explain what I am doing wrong and/or what is going on?
Thanks in advance!
Debug sketch:
#include <Debug.h>
const int arraySize=118;
debugClass debug_object(arraySize);
 Serial.write("test");
Debug.h:
#ifndef Debug_h
#define Debug_h
#include "Arduino.h"
class debugClass{
public:
debugClass(const int arraySize);
   // Keep as many variables private as possible
private:
   int halfarraySize;
   float array[];
#endif
Debug.cpp:
#include "Debug.h"
debugClass::debugClass(const int arraySize){
const int halfarraySize = arraySize/2;
   // This needs to be declared or prints have issues
for(int i = 0; i < halfarraySize; i++){
array[i] = 0;
UKHeliBob
Just as a matter of interest, what is the code supposed to do apart from filling up half the array ?
memotick
I'm trying to implement a circular buffer for some experiments
PeterH
Would you expect to be able to define an array member field of unspecified size just by putting 'array[size];' in the body of the constructor? I would have thought you'd need to use a template to enable the size to be defined at instantiation time, or allocate the array dynamically. Perhaps what you're doing is legitimate, but it doesn't look that way to me; I suspect what you're actually doing is trampling over initialised memory that will be needed by the Arduino runtime later one.
I only provide help via the forum - please do not contact me for private consultancy.
HazardsMind
I believe Peter is correct, look at this link, http://www.cplusplus.com/doc/tutorial/templates/ under Non-type parameters for templates
My GitHub:
https://github.com/AndrewMascolo?tab=repositories
memotick
I think you are referring to the Debug.h private declaration "float array[];" no?
You make a good point, and suspect your theory is correct.  However, shouldn't the variable be declared in the header file?  Perhaps my assumptions are incorrect (completely possible as I'm learning this as I go).
When you say the array size should be enabled at instantiation time, where would this be located?
Thanks for the help
lloyddean
template<int N>
class debugClass
private:
    const int   array_length;
    float       array[N];
public:
    debugClass() : array_length(N)
        for ( int i = array_length; i--; )
            array[i] = 0;
debugClass <12>    debug;
memotick
template<int N>
class debugClass
private:
    float       array[N];
public:
            array[i] = 0;
First of all, thank you for kindly writing this.  Would this code be placed in Debug.h?
I'm reading up on Templates, I was not aware of them.
lloyddean
Except for that last line yes as the last line instantiates and instance with an array length of 12 named 'debug' - place that in an implementation file where used.  Adjust array length as necessary.
memotick
Sorry but I can't wrap my head around this yet.  I'm still studying templates and dynamic memory to understand what is needed.I tried using templates but am getting errors
Debug sketch:
#include <Debug.h>
//debugClass debug_object(arraySize);
debugClass <arraySize> debug_object;
Debug.h:
#ifndef Debug_h
#define Debug_h
template<int N>
class debugClass
private:
    float       array[N];
public:
        for ( int i < array_length/2; i--; )
            array[i] = 0;
#endif
Debug.cpp:
#include "Debug.h"
debugClass::debugClass(){
Errors:
In file included from Debug.ino:1:
/Applications/Arduino.app/Contents/Resources/Java/libraries/Debug/Debug.h: In constructor 'debugClass<N>::debugClass()':
/Applications/Arduino.app/Contents/Resources/Java/libraries/Debug/Debug.h:16: error: expected initializer before '<' token
/Applications/Arduino.app/Contents/Resources/Java/libraries/Debug/Debug.h:16: error: 'i' was not declared in this scope
lloyddean
#10
Feb 05, 2013, 02:14 am Last Edit: Feb 05, 2013, 02:18 am by lloyddean Reason: 1
Sorry I hadn't seen your question earlier -
template<int N>
class debugClass
   const int   halfarraySize;
   float       array[N / 2];
public:
   debugClass() : halfarraySize(N / 2)
       for ( int i = halfarraySize; i--; )
           array[i] = 0;
const int arraySize = 118;
debugClass<arraySize> debug_object;
