Topic: 1602a 16X2 LCD is blank (Read 35855 times) previous topic - next topic
afremont
It looks like Vss is not connected in the picture.  There doesn't appear to be a jumper in the hole above the pin on the display board.  Even before doing any initialization, the OP should be seeing rows of black squares if the power is ok and the the contrast is good.
Experience, it's what you get when you were expecting something else.
floresta
#16
Feb 02, 2013, 09:59 pm Last Edit: Feb 02, 2013, 10:05 pm by floresta Reason: 1
Quote
That's due to what I mentioned about parallax and the reason for the recommendation to use a long lens.
Quote
I wish I had thought of that.
Don
afremont
Quote
Quote
Don
Ok, you caught me.  I didn't read it all carefully, I see now where you mentioned the boxes and contrast.
ttexan
I just read all of this thread and I am having the same problem.  I can get the squares and adjust them to very light.  However, I do not get any signals (words).
See attached picture.
floresta
Quote
That looks like a unique display.  Can you give us more information about it?
We can't really verify that your connections are correct without being able to unambiguously follow each wire from one end to the other.
Don
ttexan
As far as I know it is a standard display.  I have attached a photo of the back as well as a better picture of the overall setup and a close up of the LCD wiring.
floresta
It looks like you may have now have pin 5 of the LCD (R/W) connected to +5 instead of GND.  It appeared to be correctly connected in your original photograph.
Don
ttexan
You are absolutely right.  I must have switched it when I cleaned it up for the last photos.
OK, I put 5 to GND, but nothing changed.  If I look really hard at the display I can almost see some movement where the letters should be.  This may just be my imagination as I cannot bring it out with any changes in contrast.
I know the last thing to suspect is always the hardware, but I am beginning to think that the LCD might have a problem.
Dan
ttexan
My face is red!  I thought of one more thing so I checked my software and discovered I had it set up for Arduino Uno and not Arduino Mega.  I had switched to another project and forgot to change back.
LCD is now working.
A real NOVICE error but then again that's exactly what I am.
Thanks for the help.
Dan
AJITnayak
I am also having same Problem , any one solve issue for above
AMPS
floresta
Quote
I thought he did solve his problem as reply #23 states "LCD is now working".
Start a new thread for your problem since this one is almost a year old and is solved.  Be sure to indicate exactly which display you are using, include your program code, and provide a photograph of your setup if possible and you will get all kinds of help.
Don
jmsl100
Hello, you are powering the circuit only with 3.3 Volts, try in 5 volts and it works fine.
Other problem was your solderings, try to appear bright and smooth like D5 pin in the LCD, do not permit the holes, you just need to use a small quantity of soldering paste at the tip of the iron. And try to mantain the iron tip clean.
And by the way the code was pretty good. Simple and efective...
joprysko1
I had a similar issue at first with just getting a backlight, not realizing that the pot was actually the contrast control.  Sometimes it's the simplest things that cause the most complex seeming errors.
lagunacomputer
#28
Jan 22, 2015, 04:06 am Last Edit: Jan 22, 2015, 04:08 am by lagunacomputer
Hello I was having the same problem with the same LCD board i bought off ebay.  I thought the pinout was reversed, but it was not.   Wire it up just like in the picture in the start of this post.  Also i added +5v and GND to pins 15/16, the ones labeled LED+ and LED-.
also, since i did not have a 10k pot handy, i substituted for a 1 or 2k resistor (RRRG)and took it to ground.  The other end of the resistor i put on the 3rd pin Vo, and my screen instantly gave me the right contrast with the row of solid boxes on the top line.
From there it was just a matter of getting my pins contacted on my breadboard with more solid connections.
if i had a loose wire, i would get all kinds of garbage and refreshes on the screen.  Once i locked down the connections more solidly, everything worked right by hitting the arduino reset button.
tuskiomi
same problem
note: yellow = data
orange = Anode
Blue = ground
white = ground (couldn't get another blue)
pic:
