Author Topic: LED brightness control  (Read 203 times)
Have just got the arduino and trying some simple things on it, here one of them;
I want to increase the brightness of the LED 20 unit each time I press the push button, quite simple.
However, It doesn't work, the LED light tremble and when I push the button it stops trembling.
Here's the code;
int but = 8;
int led = 9;
int val = 0;
  pinMode(but, INPUT);
  pinMode(led, OUTPUT);
  if(digitalRead(but) == 1)
    val = val + 20;
  analogWrite(led,val);
Queens, New York
"Of all the things I've ever lost, I miss my mind the most" -Ozzy Osbourne
I dont think it is actually trembling, I think it is just cycling so fast that it is hard to see anything. Look at the state change example, and debounce example, then try the LED.
UNO, MEGA, NANO, 4x4 keypad, micro servos, RF transceivers, bluetooth, ultrasonic sensor, 20x4 I2C LCD, 3.2 TFT touch screen, L298N Dual motor driver, Voice Recognition 15W, Gameduino
Arduino Tutorials, coming soon.
"If your doing nothing, it does not mean your lazy, it just means your open for anything that suits you" - Unknown
But at least at the beginning the led must not shine, right ?
However, it immediately starts trebling.
Queens, New York
Even without the button being pressed? Does your button have a pull down or up resistor?
This is looking for the button to be HIGH when pressed, so if you have a floating input (no pulling resistor), that would cause the flicker.
The button I have is that;
Lost Wages
Here's my try:
Connect a SPST N.O. momentary from pin 8 to GND with no resistor.
Connect an LED from pin 9 to an LED in series with a current-limiting resistor (220 to 330 ohm) to GND.
My code:
int but = 8;
int led = 9;
int val = 0;
  pinMode(but, INPUT_PULLUP);
  pinMode(led, OUTPUT);             // not needed, but I like to be explicit
  if(digitalRead(but) == LOW)
    //here: the button is pushed
     val += 20;                                 // increment the brightness of the LED by 1/24th
    val = min(val, 255);                     // maximum PWM value is 255
    //here: the button has been released
    val = 0;                                  // turn the LED OFF
  analogWrite(led,val);                 // adjust the PWM
  delay( 250 );                           // give yourself a chance to see the result
should take about 3 seconds from OFF to full brightness. If you need it to be quicker, adjust the delay time
the delay also tends to debounce the switch too
Queens, New York
Ok those need to be debounced to work properly. So even if you just press it once, being that it is not being debounce, it will put out a LOT of noise. Meaning even if YOU press it once, the arduino will see that it was pressed multiple times, because of that noise. Also did you include a pulling resistor?
Here's my try:
My code:
int but = 8;
int led = 9;
int val = 0;
Thank you, that one worked, but I didn't know input_pullup thing.
Don't know what pulling resistor is
What exactly is it ?
http://en.wikipedia.org/wiki/Pull-up_resistor
Lost Wages
look here:
http://arduino.cc/en/Tutorial/InputPullupSerial
Queens, New York
A "pulling" resistor is my terminology of a resistor being either a pull down or pull up resistor. Now being that most of the time (if not all the time) we don't know what your setup is, so we assume it is being pulled down when it could be pulling up. So by saying "pulling" it means either or.
Here's my try:
My code:
int but = 8;
int led = 9;
int val = 0;
After inspected the code, I realised that you also used "LOW" for if statement with buttons. Why is it so ?
I think if the button is not pushed it should be act as "LOW" and the led starts shining, but it doesn't and the code works pretty well.
But didn't get the idea underlying.
Here's my try:
My code:
int but = 8;
int led = 9;
int val = 0;
Suppose found my answer;
"Because the internal pull-up on pin 2 is active and connected to 5V, we read HIGH when the button is open"
Lost Wages
You got it!
