Pages: [1] 2 3   Go Down
Author Topic: Cant stop code from being run after reset  (Read 839 times)
Hey,
My project:
Make a simple timer that starts at the click of a button. My sketch works, but it starts immediately after reset.
I want the sketch to stop and wait for a button press.
If anyone could help, i would be very grateful:)
Here is my code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
#define ledPin  13                  // LED connected to digital pin 13
#define buttonPin 8                 // button on pin 4
int value = LOW;                    // previous value of the LED
int buttonState;                    // variable to store button state
int lastButtonState;                // variable to store last button state
//int blinking;                       // condition for blinking - timer is timing
long interval = 100;                // blink interval - change to suit
long previousMillis = 0;            // variable to store last time LED was updated
long startTime ;                    // start time for stop watch
long elapsedTime ;                  // elapsed time for stop watch
int fractional;                     // variable used to store fractional part of time
      lcd.begin(16, 2);
  // Print a message to the LCD.
  lcd.print("Test");
    pinMode(ledPin, OUTPUT);
    pinMode(buttonPin, INPUT);
    digitalWrite(buttonPin, HIGH);
  if (buttonState == HIGH) {
    activate();
  else {
    digitalWrite(13, HIGH);
void activate()
    if (buttonPin == HIGH){
       // if true then found a new button press while clock is not running - start the clock
       startTime = millis();                                   // store the start time
       delay(5);                                               // short delay to debounce switch
       lastButtonState = buttonState;                          // store buttonState in lastButtonState, to compare next time
    else if (lastButtonState == HIGH){
       // if true then found a new button press while clock is running - stop the clock and report
         elapsedTime =   millis(); //- startTime;              // store elapsed time
  lcd.setCursor(0,1);
  lcd.print("   ");
        // routine to report elapsed time
         lcd.print( (int)(elapsedTime / 1000L));         // divide by 1000 to convert to seconds - then cast to an int to print
         lcd.print(".");                             // print decimal point
        fractional = (int)(elapsedTime % 1000L);
        if (fractional == 0)
           lcd.print("000");
        else if (fractional < 10)
           lcd.print("00");
        else if (fractional < 100)
           lcd.print("0");
        lcd.println(fractional);  // print fractional part of time
    else{
Queens, New York
"Of all the things I've ever lost, I miss my mind the most" -Ozzy Osbourne
Does your button have a pull down resistor? That is not the proper way to debounce a button, look at the debounce example. Also you never turn the LED off.
« Last Edit: January 31, 2013, 03:21:42 pm by HazardsMind » Logged
UNO, MEGA, NANO, 4x4 keypad, micro servos, RF transceivers, bluetooth, ultrasonic sensor, 20x4 I2C LCD, 3.2 TFT touch screen, L298N Dual motor driver, Voice Recognition 15W, Gameduino
Arduino Tutorials, coming soon.
"If your doing nothing, it does not mean your lazy, it just means your open for anything that suits you" - Unknown
Yes it has a pulldown resistor.
The led part of the sketch is obsolete, and will be removed.
It might not be the right way to debounce, but the code in the activate() function works.
Its the part in the void loop() that wont stop the activate() function that is bothering me...
Queens, New York
Well if it keeps going to the activate function, then it is seeing that the button is high, otherwise it will not do that if statement. Check your wiring again just to be sure.
You where correct. The butten is HIGH when not pressed and LOW when pressed.
I changed the code to:
  if (buttonState == LOW) {
    activate();
  else {
But it still wont stop the code from being run...
Lost Wages
Did you change the button logic in activate() as well?
Please re-pot your entire code.
Queens, New York
I noticed that your not using a latch. It is possible that if you press the button the first time, your not giving it time to go back HIGH, so it is carring over to the activate function.
How can i implement a latch?
Queens, New York
byte lastbuttonState = 0; // new global variable
// normal debounce code here
  if(buttonState != lastbuttonState) {
    activate();
    lastbuttonState = buttonState;
Alternative:
byte buttonState2 = 0;
buttonState1 = digitalRead(buttonPin);
delay(20);
buttonState2 = digitalRead(buttonPin);
  if(buttonState1 == buttonState2) {
    if(buttonState2 != lastbuttonState) {
     activate();
     lastbuttonState = buttonState2;
dont forget the setup()
UK
The simplest way to do that is to put a loop in setup() that reads the switch state repeatedly until the button press is detected.
HazardsMind
I ill try that tomorrow, and i will let you know how it goes..
And thanks for all your help:)
Lost Wages
Your new initialization code:
initializes to the button being pressed in the new scheme, yes?
Please post your entire code...
Queens, New York
My code? It's just a snippet from his code that I made. Just replace his loop function with one of mine.
Lost Wages
No, I meant Webca.
I didnt get it to work smiley-sad
Here is my code:
#define buttonPin 9                 // button on pin 4
byte lastbuttonState2 = 0; // new global variable
byte buttonState1 = 0;
      lcd.begin(16, 2);
  lcd.print("Test");
    pinMode(ledPin, OUTPUT);         // sets the digital pin as output
    pinMode(buttonPin, INPUT);       // not really necessary, pins default to INPUT anyway
    digitalWrite(buttonPin, HIGH);   // turn on pullup resistors. Wire button so that press shorts pin to ground.
delay(20);
    if(buttonState2 != lastButtonState) {
     activate();
     lastButtonState = buttonState2;
void activate()
    buttonState = digitalRead(buttonPin);                   // read the button state and store
    if (buttonState == HIGH){
    else if (buttonState == LOW){
         elapsedTime =   millis(); - startTime;              // store elapsed time
  lcd.setCursor(0,1);
  lcd.print("   ");
         lcd.print(".");
           lcd.print("000");
           lcd.print("00");
           lcd.print("0");
    else{
Pages: [1] 2 3   Go Up
