Topic: Cant stop code from being run after reset (Read 8911 times) previous topic - next topic
wildbill
Try using a global boolean variable to keep track of whether the clock is running. Check for a button press. When you detect one, check for whether the clock is running. If it is, show the elapsed time, otherwise note millis. In both cases, set the boolean appropriately for the new situation. You should be able to make the whole thing much simpler this way.
HazardsMind
#16
Feb 01, 2013, 02:10 pm Last Edit: Feb 01, 2013, 02:20 pm by HazardsMind Reason: 1
What exactly should it be showing? With your code as of now, when the button is pressed, you see the change in time. However when I took out the " ; " in this line "elapsedTime =   millis(); - startTime;" and when I just press the button, I get a readout of between 0.064 - 0.083. BUT, if I hold the button, the counter continues to accumulate and I get +3.250 when held for 3 seconds.
Which one is correct?
Added: change the println to just print for the last line, println(fractional) => print(fractional).
println gives you junk on the end.
My GitHub:
https://github.com/AndrewMascolo?tab=repositories
GoForSmoke
I want the sketch to stop and wait for a button press.
The simplest way to do that is to put a loop in setup() that reads the switch state repeatedly until the button press is detected.
But that would work and it's -much- too simple.
1) http://gammon.com.au/blink  <-- tasking Arduino 1-2-3
2) http://gammon.com.au/serial <-- techniques howto
Tasking: techniques make the trees, the sketch is the woods.
See the woods and the trees, comment both.
Webca
HazardsMind-
It has to be like this " elapsedTime =   millis(); - startTime; ".
It is supposed to be a regular timer that works in the "background" and when i press the button i get a readout of how far it has come
kf2qd
These variables -
int lastButtonState;                // variable to store last button state  probably should be  int lastButtonState = 0;
byte lastbuttonState2 = 0;     // new global variable - I think you created this one, and thought you used it when you really just wanted to initialize lastButtonState.
byte buttonState1 = 0;
byte buttonState2 = 0;
and this little bit of code  -
buttonState1 = digitalRead(buttonPin);  // so the button isn't pressed here
delay(20);
buttonState2 = digitalRead(buttonPin);  // and the button isn't pressed here
  if(buttonState1 == buttonState2) {      // then this is true because not pressed == not pressed
    if(buttonState2 != lastButtonState) {   // and since lastButtonState was never initialized we don't know what it might be so this can be true also.
     activate();                                         // and activate() runs because every condition passed.
     lastButtonState = buttonState2;
HazardsMind
Ok, so when the button is pressed, it starts the timer and continiously shows it on the screen? Because right now your code starts timing as soon as it resets, that is going to happen. But if you want it to appear to start when you press the button, then that is different.
My GitHub:
Webca
That is correct, i want it to appear to start when i press the button..
What do i have to do to the code to get it working as it should?
PeterH
Remind me exactly what behaviour you're trying to achieve? Your initial post sounded trivially simple and I don't follow the need for all this timing and state handling code.
HazardsMind
#23
Feb 01, 2013, 08:06 pm Last Edit: Feb 01, 2013, 08:10 pm by HazardsMind Reason: 1
Ok then, I got this.
Change the LCD I2C stuff back to your LCD setup.
#include <Wire.h>         //MINE
#include <LiquidCrystal_I2C.h> //MINE
LiquidCrystal_I2C lcd(0x20,20,4); //MINE
#define ledPin  13                  // LED connected to digital pin 13
#define buttonPin 9                 // button on pin 4
int value = LOW;                    // previous value of the LED
int buttonState;                    // variable to store button state
long interval = 100;                // blink interval - change to suit
long previousMillis = 0;            // variable to store last time LED was updated
long startTime ;                    // start time for stop watch
long elapsedTime ;                  // elapsed time for stop watch
int fractional;// variable used to store fractional part of time
boolean start = false;
  lcd.begin(16, 2);
  // Print a message to the LCD.
  lcd.print("Test");
  pinMode(ledPin, OUTPUT);         // sets the digital pin as output
  pinMode(buttonPin, INPUT);       // not really necessary, pins default to INPUT anyway
  digitalWrite(buttonPin, HIGH);   // turn on pullup resistors. Wire button so that press shorts pin to ground.
  lcd.init();                      // initialize the lcd  MINE
  lcd.backlight();              // MINE
  delay(20);
    if(buttonState2 == HIGH){
      start = true;
      startTime = millis();
  if(start == true){
  elapsedTime =   millis() - startTime;              // store elapsed time
    lastButtonState = buttonState;                     // store buttonState in lastButtonState, to compare next time
    lcd.setCursor(0,1);
    lcd.print("   ");
    // routine to report elapsed time
    lcd.print( (int)(elapsedTime / 1000UL));         // divide by 1000 to convert to seconds - then cast to an int to print
    lcd.print(".");
    fractional = (int)(elapsedTime % 1000UL);
    if (fractional == 0)
      lcd.print("000");
    else if (fractional < 10)
      lcd.print("00");
    else if (fractional < 100)
      lcd.print("0");
    lcd.print(fractional);  // print fractional part of time
I took everything out of the activate() function, just to test it without the use of any other functions.
Now what this does is it waits for the button to be pressed, in my case buttonState2 = HIGH (yours might be LOW) then starts the timer at 0.000 and counts. It will reset the timer every time the button is pressed.
My GitHub:
Webca
I am trying your sketch and what happens is it shows the counter in the display and when i click the button it resets the counter.
I want the counter to run in the background (not visible in the display) and when i click on the button after for example 5 seconds it shows 5.000 in the display and if i then click the button after 2 seconds again i want it to show 7.000 in the display.
I feel we are getting close though, and i really appreciate you sticking with me on this HazardsMind:)
HazardsMind
Ok, now I see what you want to do. The way you had it the first time, kinda work, but it started the count as soon as the arduino started up. So now all you need to do is make it so that,
*You press the button once, starts timer in the background.
*Press same button again, and it shows the time.
For this look at what PeterH wrote,
In which case you would use a while loop to check the state of the button, if it is pressed then you store the current millis and pass it on to the loop function.
In the loop function, you then check the button state again, and if that is pressed, you show the time. Using this method, it will NOT reset the timer until the arduino itself is reset.
Im sure you can do this on your own, so give it a try, and if not post what you have.
My GitHub:
HazardsMind
#26
Feb 01, 2013, 10:05 pm Last Edit: Feb 01, 2013, 10:10 pm by HazardsMind Reason: 1
Update, you dont need to use PeterH's suggestion (No offense Peter), I got it to work on my end with just a single new IF/ELSE and boolean statement.
Hint!
Add the new boolean statement (globally false) before the "start = true" line (that exact line) with the same boolean inside the IF statement set to true (The lockout). Then add a button check to "start == true", button check AND start == true. After that IF statement's closing bracket, put the ELSE statement to clear the screen.
Its that easy.
Also you can get rid of buttonstate 1 == buttonstate2 and just have buttonState2 == HIGH. No debounce needed.
My GitHub:
GoForSmoke
HazardsMind
Yes, I'm the one who put it in his code.
My GitHub:
GoForSmoke
You've got a delay(20) in there. Your minimum response is over 20 ms....
It'd be smoother to loop while ( now - startPress > 10 ) true after 10 ms continuous contact, Arduino can check that button 8000 times in 10 ms so why have it do nothing for 20 ms?
