Topic: Case statement using array, help with syntax? # (Read 1 time) previous topic - next topic
kdade14
I'm making a line following program using an 8-sensor array, but I'm having trouble with this particular part of the program.
SAS is the sensor array status, and each value is either 1 or 0, corresponding to each sensor.
I know this code isn't really close to being correct, but i think it shows what I'm trying to do.
Is there a way to do this without comparing each element of the array individually and using a ton of &&s?
switch (SAS[0,1,2,3,4,5,6,7]) {
    case 10000000:
      leftServo.write(45);
      rightServo.write(180);
      break;
    case 01000000:
      leftServo.write(90);
      break;
    case 00100000:
      leftServo.write(135);
      break;
    case 00010000:
      leftServo.write(180);
      break;
    case 00001000:
      break;
    case 00000100:
      break;
    case 00000010:
      rightServo.write(90);
      break;
    case 00000001:
      rightServo.write(45);
      break;
lloyddean
#1
Jan 31, 2013, 09:53 pm Last Edit: Jan 31, 2013, 09:55 pm by lloyddean Reason: 1
Something along the lines of -
#define ENTRIES(ARRAY)  (sizeof(ARRAY)/ sizeof(ARRAY[0]))
int bits = 0;
for ( int i = ENTRIES(SAS); i--; )
   bits = ((bits << 1) | ((SAS[i]) ? 1 : 0));
switch ( bits )
   case 0b10000000: leftServo.write( 45); rightServo.write(180); break;
   case 0b01000000: leftServo.write( 90); rightServo.write(180); break;
   case 0b00100000: leftServo.write(135); rightServo.write(180); break;
   case 0b00010000: leftServo.write(180); rightServo.write(180); break;
   case 0b00001000: leftServo.write(180); rightServo.write(180); break;
   case 0b00000100: leftServo.write(180); rightServo.write(180); break;
   case 0b00000010: leftServo.write(180); rightServo.write( 90); break;
   case 0b00000001: leftServo.write(180); rightServo.write( 45); break;
kdade14
Looks good, I'm kind of new to C++ so it might take me a while to figure out exactly how that works, but i think it'll work.
Thanks for the help!
kdade14
Sorry for the late reply, i understand all your code except for the line:
((SAS) ? 1 : 0))
I conceptually understand what it does but i don't understand how the "?1:0" works.
could you please explain it?
robtillaart
((SAS) ? 1 : 0))
this is identical to
if (SAS) then 1;
else 0;
Rob Tillaart
kdade14
Also, is it possible to have an 'or' within the case statement?
such as :
case 0b00010000 || 0b00001000:
i don't think this is correct though, because when i try it i get a duplicate case value error.
It apparently equals this one:
case 0b00000001:
AWOL
You should use bitwise OR | , not logical OR ||
kdade14
But that combine the values into 0b00011000, so now both 0b00010000 ans 0b00001000 are no longer defined if those happen to be the values.
robtillaart
case 0b00010000 || 0b00001000:  // logical OR
is allowed
case 0b00010000 | 0b00001000:  // bitwise OR
too
as long as it can be calculated compile time (it should be a constant-expression)
Rob Tillaart
AWOL
But the logical OR is the same case as 0b00001 (aka true), hence the identical case error.
lloyddean
#11
Feb 02, 2013, 07:37 pm Last Edit: Feb 02, 2013, 07:39 pm by lloyddean Reason: 1
'OR' better yet one case state can fall into the next -
case 0b00010000:
case 0b00001000:
   break;
cases statements need not be in numerical order.
robtillaart
Rob Tillaart
kdade14
