Author Topic: Case statement using array, help with syntax? #  (Read 143 times)
I'm making a line following program using an 8-sensor array, but I'm having trouble with this particular part of the program.
SAS is the sensor array status, and each value is either 1 or 0, corresponding to each sensor.
I know this code isn't really close to being correct, but i think it shows what I'm trying to do.
Is there a way to do this without comparing each element of the array individually and using a ton of &&s?
switch (SAS[0,1,2,3,4,5,6,7]) {
    case 10000000:
      leftServo.write(45);
      rightServo.write(180);
      break;
    case 01000000:
      leftServo.write(90);
      break;
    case 00100000:
      leftServo.write(135);
      break;
    case 00010000:
      leftServo.write(180);
      break;
    case 00001000:
      break;
    case 00000100:
      break;
    case 00000010:
      rightServo.write(90);
      break;
    case 00000001:
      rightServo.write(45);
      break;
Des Moines, WA - USA
Something along the lines of -
#define ENTRIES(ARRAY)  (sizeof(ARRAY)/ sizeof(ARRAY[0]))
int bits = 0;
for ( int i = ENTRIES(SAS); i--; )
    bits = ((bits << 1) | ((SAS[i]) ? 1 : 0));
switch ( bits )
    case 0b10000000: leftServo.write( 45); rightServo.write(180); break;
    case 0b01000000: leftServo.write( 90); rightServo.write(180); break;
    case 0b00100000: leftServo.write(135); rightServo.write(180); break;
    case 0b00010000: leftServo.write(180); rightServo.write(180); break;
    case 0b00001000: leftServo.write(180); rightServo.write(180); break;
    case 0b00000100: leftServo.write(180); rightServo.write(180); break;
    case 0b00000010: leftServo.write(180); rightServo.write( 90); break;
    case 0b00000001: leftServo.write(180); rightServo.write( 45); break;
« Last Edit: January 31, 2013, 03:55:17 pm by lloyddean » Logged
Looks good, I'm kind of new to C++ so it might take me a while to figure out exactly how that works, but i think it'll work.
Thanks for the help!
Sorry for the late reply, i understand all your code except for the line:
((SAS) ? 1 : 0))
I conceptually understand what it does but i don't understand how the "?1:0" works.
could you please explain it?
Netherlands
((SAS) ? 1 : 0))
this is identical to
if (SAS) then 1;
else 0;
Rob Tillaart
Gotcha, thanks!
Also, is it possible to have an 'or' within the case statement?
such as :
case 0b00010000 || 0b00001000:
i don't think this is correct though, because when i try it i get a duplicate case value error.
It apparently equals this one:
 case 0b00000001:
UK
You should use bitwise OR | , not logical OR ||
But that combine the values into 0b00011000, so now both 0b00010000 ans 0b00001000 are no longer defined if those happen to be the values.
Netherlands
case 0b00010000 || 0b00001000:  // logical OR
is allowed
case 0b00010000 | 0b00001000:  // bitwise OR
too
as long as it can be calculated compile time (it should be a constant-expression)
Rob Tillaart
UK
But the logical OR is the same case as 0b00001 (aka true), hence the identical case error.
'OR' better yet one case state can fall into the next -
case 0b00010000:
case 0b00001000:
    break;
cases statements need not be in numerical order.
« Last Edit: February 02, 2013, 01:39:06 pm by lloyddean » Logged
Netherlands
agree with lloydDean
+1
Rob Tillaart
brilliant, it worked!
Thanks mate  smiley-grin
