Topic: ADXL193 Accelerometer Assistance Needed! (Read 10987 times) previous topic - next topic
MRose_91
That depends on what the project is for. If the project to read the accelerometer IS part of your course work, then paying someone else to write the code is cheating, and we don't support that.
If the project to read the accelerometer data is a personal project that has nothing to do with school then post in Gigs and Collaboration to hire someone.
Ok, thanks for clearing that up. My project is to design and construct a new take on a folding Cycling helmet. Testing the impact resistance is one on many factors. I guess paying for code is like paying for a 3D printed part for a concept though - which is fine.
Thanks
MRose_91
Hello,
I have a 3rd year Product Design University project that requires the use of a 250g accelerometer for helmet testing.
I have the following kit:
Arduino UNO board
Breadboard
Jumpers
I need a code and any other supporting scripts to allow me to visually see the G-force the accelerometer is subjected to.
I am open to payment suggestions and I will pay via Paypal.
I look forward to hearing from you!
Thanks
Mike
JamesD3rd
Try this code out - it constantly checks for minimum and maximum recoil.
But it only displays once every second.  The more you display the smaller your sample rate becomes.
If the sample rate is too slow, you will miss the recoil event.
Code: [Select]
Recoil Viewer designed by AB9VH Electronics, James Douglas III - 2012
Sparkfun ADXL193 single axis accelerometer, 5v reference
X axis analog pin 0
Ground, black wire
+5v, red wire  (Vin: voltage input 5v)
ZERO G = 508  (calibration data)
int X = 0;                          // fresh data from accelerometer
int Xmax = 508;                     // maximim recoil data
int Xmin = 508;                     // minimum recoil data
int R = 0;                          // recoil reading in g force
unsigned long time = 0;             // time in millis of recoil event
  Serial.begin(9600);            // opens serial port for LCD shield
  Serial.println("Recoil Viewer by AB9VH Electronics");
  time = millis();               // time of recoil event
  X = analogRead(0);             // read analog input
  if (X < Xmin) Xmin = X;
  if (X > Xmax) Xmax = X;
  if (millis()-time >= 1000) {      // display every one second
    R = (Xmin-508)*.5;              // calculate maximum recoil
    Serial.print("Min recoil = ");
    Serial.print(R);
    Serial.print("g     ");
    R = (Xmax-508)*.5;              // calculate minimum recoil
    Serial.print("Max recoil = ");
    Serial.print(R);
    Serial.println("g");
MRose_91
I was not aware I crossposted, to be honest. This thread is asking for code for payment. This section of the forum was suggested to me by another forum user - I did not ask for a new code in that thread, as far as I'm concerned, I got my answer out of that thread.
If it needs to be merged, so be it, I had no intension of violating any forum rules. It's the last thing I want to do in my time of need.
nickgammon
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
nickgammon
This is the third thread I've found on this subject. I hope there aren't too many more.
Please do not cross-post. This wastes time and resources as people attempt to answer your question on multiple threads.
Threads merged.
- Moderator
MRose_91
Excellent, thank-you! It works! Well, as far as I know, I need to test this on a real on the market helmet to know for sure. I will let you know.
Where did you find the code? My only issue is it displays/scrolls just the maximum achieved G-load in the session, it doesn't reset to zero. Is there anyway of doing this? I would like to enter the results on to a chart at the desired intervals you see.
Oh, and Moderator, I am sorry that I appeared to be cross-posting. I thought I was OK because each thread was a different query i.e one was asking for coding help, one for basic what pin when help and the last was asking for paid assistance. But I can see how it could be seen/classified as cross-posting.
JamesD3rd
I wrote the sketch for detecting recoil with ADXL193.  I have used it with several projects.
Here is the original version that I had modified and posted earlier.
I wasn't sure what you were doing or needed to display.
Code: [Select]
Recoil Viewer designed by AB9VH Electronics James Douglas III - 2012
X axis analog pin 0
ZERO G = 508  (calibrated data)
int Xmax = 508;                     // max raw data, opposite of gravity
int Rmax = 0;                       // max recoil reading in g force
boolean lcd = false;                // okay to display info
  if (X > Xmax) {             // recoil event is opposite of gravity
    Xmax = X;
    time = millis();
    lcd = true;
  if ((lcd == true) && (millis()-time >= 1000)) {    // display 1 second after recoil
    Rmax = (508-Xmax)*.5;                // calculate max recoil
    Serial.print(Rmax);
    Serial.print("g   ");
    lcd = false;
  if (millis()-time >= 4000) Xmax = 508;  // reset max recoil after 4 seconds
