Pages: [1] 2 3   Go Down
Author Topic: Label related compiler error  (Read 467 times)
Been looking around, and I didn't find it... Is there a way to prototype a label in C/C++ for Arduino? For some reason Arduino will only "goto" to a label that is formerly declared (higher in the code). It throws errors when you try to goto a later place.
This works:
LABEL:
goto LABEL;
This does not work:
goto LABEL;
LABEL:
Program:
void setup(){
void loop(){
  goto LABEL;
  LABEL:
Compiler errors:
Program.ino: In function 'void loop()':
Program:9: error: expected primary-expression before '}' token
Program:9: error: expected `;' before '}' token
And please do not talk about why labels are bad, or why I should not be using them.
Seattle, WA USA
Seattle, WA USA
Why not? I've been programming in C and C++ for 30 years, with 100s of 1000s of lines of code, and not a single goto in any of that. The number of legitimate uses of goto in the whole lot of C code can probably be counted on one hand. Maybe two. I seriously doubt that anything you are doing on the Arduino NEEDS goto.
Because I don't want this thread to be about the pros and cons of labels and gotos. I want to be able to use them, and I'd like to know why it doesn't work.
Melbourne, Australia
Shannon Member
Lua rocks!
The error message was pretty explicit:
Try inserting a ';' before the '}'
Also, try to not use goto. (Couldn't resist, sorry).
Shannon Member
Lua rocks!
One finger, I suggest.
Thanks, that does compile, but why would I need to do that (put a semi-colon after the colon)?
goto LABEL;
LABEL:;
Other than the file name, function name, and line number, the Arduino error messages are almost always useless, so I tend to disregard them.
Seattle, WA USA
Seattle, WA USA
Because a label introduces a block of code. You've got to have a block of code after the label. The block can be one line, which can have nothing but a semicolon on it.
Now, why, given that goto is not necessary, do you think you need to use it?
Okay, I guess that makes sense.
I don't think I need to use it. I was simply playing around, and ran into the error.
UK
They are bad, and you should not be using them.
As an aside, labels have to be associated with a statement and cannot be used in isolation; in your failing examples, there's no statement after the label.
I know that they aren't necessary, but sometimes it's fun to play around with them.
 smiley-roll this is turning into what I explicitly stated I didn't want it to...
Ayer, Massachusetts, USA
Picking nits, a labeled statement is a statement preceded by a label name and colon (or the 'case' keyword followed by an integer constant and then a colon or the 'default' keyword followed by a colon).  Since a labeled statement is one of the statement types, you can have multiple labels that ultimately precede a normal statement.  If the statement isn't a compound statement or loop, you need a ';' at the end.  A ';' by itself is an empty statement.  In the ISO C 99 standard this is in section 6.8.1 of the standard.  I don't have an online copy of the C++ standard, so I don't know the chapter and verse in C++, but C++ follows similar rules.
Shannon Member
Lua rocks!
I know, but sometimes people ask how to do things, like "how to I turn interrupts off because of blah" and it turns out that the "real" solution is to dissuade them from the thing they were attempting in the first place.
It would be like going to a car manufacturer and asking how to disable the airbags.
"But that's not a good idea," they would say.
"But I want to," you reply.
"But why?" they ask.
"I just want to experiment," you reply. "It will be fun to drive around with them disabled."
It's not too hard to actually read the error message.
Then I'd say "Fine, I'll just pull the fuse" << smiley-lol ... or more likely go online and ask someone who will (hopefully) cut to the chase and actually tell me the answer to what I am asking, instead of telling me all the reasons it's so bad to do it.
Seattle, WA USA
Seattle, WA USA
OK. Let's try this. Go ahead. Load your code up with impossible to follow goto statements and labels. Then, when you have a problem with it not performing as expected:
goto someplaceElseForHelp:
Pages: [1] 2 3   Go Up
