Loading...
Pages: [1]   Go Down
Author Topic: Potentiometer Send MIDI CC  (Read 571 times)
Lisbon
Offline Offline
Newbie
View Profile
Hello Everyone
I was wondering from the midi example that is available on Arduino Software
if its possible to send MIDI like that but with a potentiometer controlling both
Note and Velocity with different potentiometer's with serial.write
If there are examples available or someone that did something close to this
i would really appreciate your tips and solutions.
Thanks you very much
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
Quote
Yes it is almost trivial,
read the two pots into a variable and shift it 3 places to the right to scale it
Code:
vPot = analogRead(vPotPin) >> 3;
nPot = analogRead(nPotPin) >> 3;
// then do other stuff and final use these variables to send just after the note on
Logged
Collegno, Turin
Offline Offline
Newbie
Arduino lovers
View Profile
WWW
Hi i'm also trying to build up a controller with 8 pots using an arduino 2009 and a IC 4051 for multiplexing, i'm following this tutorial from littlescale
http://little-scale.blogspot.it/2008/07/eight-pots-to-midi-cc-data.html
don't know why (maybe the pots) for me this circuit don't go. After that I've tested another circuit and code here it is
http://arduino.cc/forum/index.php/topic,122378.0.html
With that code and circuit I can hook up 6 pots (or analog sensor) and read their value, no latency, great response etc...
the problem is the mapping, when you select your parameter e.g. in ableton, until they are two it works than everything start flickering and its hard to get the solution....
Logged
Collegno, Turin
Offline Offline
Newbie
Arduino lovers
View Profile
WWW
this the code I've modify
Quote
#include <MIDI.h>
#define MIDI_ENABLE 12
// Variables:
int cc = 0;
int AnalogValue = 0; // define variables for the controller data
int lastAnalogValue = 0; // define the "lastValue" variables
  //  launch MIDI
  MIDI.begin(4)
  AnalogValue = analogRead(0);
  //  convert to a range from 0 to 127:
  cc = AnalogValue/8;
  // check if analog input has changed
  if (lastAnalogValue != cc) {
    MIDI.sendControlChange(16,cc,1);
    // update lastAnalogValue variable
    lastAnalogValue = cc;
AnalogValue = analogRead(1);
  cc = AnalogValue/8;
    MIDI.sendControlChange(17,cc,1);
  }   //  endif
AnalogValue = analogRead(2);
  cc = AnalogValue/8;
    MIDI.sendControlChange(18,cc,1);
  }   //  endif
I'm not a programmer, i'm not an electronic guru, i'm just a poor musician with a few of nerd skills smiley
Logged
Offline Offline
Brattain Member
View Profile
WWW
On that first link, the code:-
Code:
if (filter[i] != data_send){ //if filter and data_send not equal then in theory this will only send midi data when a value is changes an not constantly.
Should be changed to:-
Code:
if (abs(filter[i] - data_send) > 1){ //if filter and data_send not equal then in theory this will only send midi data when a value is changes an not constantly.
This will allow a little bit of noise without constantly resending the MIDI
On that code you just posted you need a different variable for each analogue channel for both the value and the last value. As it is you are using the last value from the previous channel reading which is not going to work. While the code is rubbish change it to
Code:
AnalogValue0 = analogRead(0);
  cc = AnalogValue0/8;
  if (abs(lastAnalogValue0 - cc)>1 {
    // update lastAnalogValue zero variable
    lastAnalogValue0 = cc;
AnalogValue1 = analogRead(1);
  cc = AnalogValue1/8;
  if (abs(lastAnalogValue1 - cc)>1 {
    // update lastAnalogValue one variable
    lastAnalogValue1 = cc;
// and so on
Logged
Pages: [1]   Go Up
Print
Jump to:
