Topic: Using Multiple Servos with Arduino (Read 75906 times) previous topic - next topic
Sluice
So, I have 8 servos that I want to drive with my Arduino. I know I shouldn't connect all the servos to the GND and +5v of Arduino. Somebody told me that servos when working pull about 2 amps each Is this correct? How should I hook an external battery with Arduino to my servos? I am told that I can hook up DC jack into Arduino, an external batteries GND to Arduino's GND, and the external batteries + to +5v on Arduino. Is this correct? Please help me out here.
JimboZA
Yep that's right. Have a look at my pic below, and go and read DuaneB's work, starting here. He has some test results for current draw.
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
zoomkat
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
Sluice
Thanks Zimbo for the tremendous help. I'm enjoying the website you linked to your post, it's very helpful. What I'm making is a 4 legged spider! (I really hope it works :)
Zoomkat, makes perfect sense. Thank you as well.
JimboZA
Quote
Thanks Zimbo
That's Jimbo  8), but you're welcome all the same.
Yep DuaneB seems to be the go-to-guy for servo know-how.
[zen]Is a 4-legged spider really a spider?[/zen]
aziz_wicaksono
oh it's so help me actually. Now, I use 5 servos in my project. Can anybody help me for give a little sketch ?  I am so confuse to start it.  :smiley-roll-sweat:
zoomkat
Several servo control code.
Code: [Select]
//zoomkat 11-22-12 simple delimited ',' string parse
//from serial port input (via serial monitor)
//and print result out serial port
//multi servos added
String readString;
#include <Servo.h>
Servo myservoa, myservob, myservoc, myservod;  // create servo object to control a servo
  //myservoa.writeMicroseconds(1500); //set initial servo position if desired
  myservoa.attach(6);  //the pin for the servoa control
  myservob.attach(7);  //the pin for the servob control
  myservoc.attach(8);  //the pin for the servoc control
  myservod.attach(9);  //the pin for the servod control
  Serial.println("multi-servo-delimit-test-dual-input-11-22-12"); // so I can keep track of what is loaded
  //expect single strings like 700a, or 1500c, or 2000d,
  //or like 30c, or 90a, or 180d,
  //or combined like 30c,180b,70a,120d,
  if (Serial.available())  {
    char c = Serial.read();  //gets one byte from serial buffer
    if (c == ',') {
      if (readString.length() >1) {
        Serial.println(readString); //prints string to serial port out
        int n = readString.toInt();  //convert readString into a number
        // auto select appropriate value, copied from someone elses code.
        if(n >= 500)
          Serial.print("writing Microseconds: ");
          Serial.println(n);
          if(readString.indexOf('a') >0) myservoa.writeMicroseconds(n);
          if(readString.indexOf('b') >0) myservob.writeMicroseconds(n);
          if(readString.indexOf('c') >0) myservoc.writeMicroseconds(n);
          if(readString.indexOf('d') >0) myservod.writeMicroseconds(n);
          Serial.print("writing Angle: ");
          Serial.println(n);
          if(readString.indexOf('a') >0) myservoa.write(n);
          if(readString.indexOf('b') >0) myservob.write(n);
          if(readString.indexOf('c') >0) myservoc.write(n);
          if(readString.indexOf('d') >0) myservod.write(n);
         readString=""; //clears variable for new input
    else {
      readString += c; //makes the string readString
jmichael26
#7
Jan 06, 2014, 09:33 am Last Edit: Jan 06, 2014, 09:45 am by jmichael26 Reason: 1
hi! how to program it if i'll be needing more than 2 servo motors? thanks
i'll be making snake robot and there is 14 servo motors included.
just like this http://www.youtube.com/watch?v=YKlCzcH8oWk&feature=c4-overview&list=UUWVNKVqwlDwOcAsUMM4TJnA
JimboZA
Zoomcat's code in reply #6 shows 4 servos already, on pins 6, 7, 8 and 9.
jmichael26
ahh but what if i'll be using 14 servos ?
JimboZA
Well you'll need an Arduino with 14 spare digital pins. Uno has 20 pins if you count the analogs, but lose 2 for Tx Rx leaves you a theoretical 18. Mega has dozens more .
I'm not sure if there's an absolute maximum that the servo library can handle though, sorry.
jmichael26
my friend told me that i need to use sevo drivers to accomodate those servos. but i'm just worried about its program . please help me
jmichael26
but how is the program if i'll be using 14 servos? just copy paste your #6 program? thanks
hoabantrang
Code: [Select]
String readString;
#include <Servo.h>
    if (c == ',') {
        if(n >= 500)
          Serial.println(n);
          Serial.println(n);
    else {
Sorry, i have an question for this code.
How these servo run, what is control it ? I found pins 6,7,8,9 in arduino connect to servo but I didn't find pin that receive order control servo from other part like varistor...
Thanks !
PaulS
Quote
You send data to the Arduino, from the Serial Monitor application, to control the servos:
Code: [Select]
