Topic: Using Multiple Servos with Arduino (Read 75907 times) previous topic - next topic
zoomkat
Quote
like varistor..
Can you explain just what the "varistor" is?
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
jack1992
Hello to everyone.I have 6 servos and Arduino Uno.The connection that i make is 3,5,6,9,10,11(all the PWM of Arduino).It will be a problem?Thanks in advance.
PaulS
Servos are NOT driven using PWM (the way Arduino does it), so there is no need to use just PWM pins.
jack1992
ok thank you sir
redbird
I am trying to use 2 servos but it is not working. When I connect only one servo, it works properly. When I connect the second servo, both servos get very erratic and after a few movements they drive to a limit and stay there. If I disconnect one servo control wire, the remaining servo acts normally again.
I initially tried this on a Diecemilia and thought maybe it was caused by an old board. I swapped out for an Uno but get the same result.
Servos are powered by an external 5V power supply; ground of power supply connected to Uno and servos.
The code is as simple as I could get, just trying to get the system to work.
Code: [Select]
#include <Servo.h>
Servo sideservo, forwardservo;  // create servo object to control a servo
  sideservo.attach(9);
  forwardservo.attach(10);
void loop() { // minimal movement to avoid damage to system
  sideservo.write(60);
  forwardservo.write(80);
  sideservo.write(90);
  forwardservo.write(100);
Any idea what is going on here?
PaulS
Quote
Without knowing how you powered the servos? No. I'd guess, though, that you are expecting the Arduino to power and control the servos. That is not going to happen. It can CONTROL the servos. It can NOT power the servos.
revolt_randy
Hi all, new to the forum here, 1st post and all that....
Being a noobie and all that, I was just messing with this last week.
Try disconnecting the ground of your power supply from the Uno. It really shouldn't matter, but I've had the same problems you're having.
My servos are connected to a power supply that's not connected to the arduino, the only connection with the arduino from the servos is the PWM wire. In my case, I'm using 4xAA batteries to power the servos, and a 9v battery to power the arduino.
When I powered one servo from an arduino, it worked fine. When I tried two, it became erratic. The main green LED on the arduino would dim, then the arduino would reboot.
Now that I have 2 power supplies, not connected in any way, it works.
Randy
goodinventor
When you set servos to go directly to certain positions the shaft is moving very quickly and so there can be a lot of skip ups (I know this because I've been messing with this myself recently). A better way of doing it without putting a lot of wear and tear on the servos is using a for loop to gradually get the servo to the position you want. In this way you don't get sudden jerks but a smooth transition to the angle you want.
outgoingbot
#23
Oct 15, 2016, 04:04 am Last Edit: Oct 15, 2016, 09:19 am by outgoingbot
*I posted this before I realized the code on page one already existed. this is a much less elegant solution.this program would be simpler if i used commas in the command protocol.
however, this program 'steps' to the commanded value. so the servo sweeps into position with +1 or -1 steps. this may smooth out the servo movement.
here is a program i have to control 4 servos simultaneously from the serial console. feel free to improve the code as you see fit.
Here is a video of it in action: https://www.youtube.com/watch?v=hAFv7o5cG2o
This is for use with the serial console or you can change values from an input device, sensor, etc
Code: [Select]
//This will control 4 servos using a single command.
//The command structure is a string of 12 characters Received on the serial port. DO NOT use line feed or carriage return (NL CR)
//if you send 000000000000 the motors will Detach and be free moving.
//3 Digits per servo * 4 Servos = 12 digits
//S1    S2   S3   S4
//000 000 000 000
//for example: 180180180180 would send EACH moter to move to 180. also, 001001001001 would send EACH motor to to 1.
//If you dont want a servo to change position send it a 000. so to move ServoB ONLY to 125 you would send 000125000000
// just change the PosX value to change position without serial command i.e. posA = 90 or posD = 1.
#include <Servo.h>
#define debug 1 //set debug to 0 if you dont want feedback. (Saves code space, increases program speed)
#define servoApin 2 //Hardware Configuration Servo Control Pin.
#define servoBpin 4
#define servoCpin 5
#define servoDpin 3
#define  posAstart 150 //estimated servo location on powerup
#define  posAmin 100 //minimum allowed 'angle' (must be at least 1)
#define  posAmax 180 //maximum allowed 'angle' (must be 180 max)
#define  posBstart 90
#define  posBmin 30
#define  posBmax 150
#define  posCstart 90
#define  posCmin 1
#define  posCmax 180
#define  posDstart 90
#define  posDmin 1
#define  posDmax 180
int servoACompleted = 1;
int servoBCompleted = 1;
int servoCCompleted = 1;
int servoDCompleted = 1;
String SreadString="";
String posAString, posBString, posCString, posDString;
int posA = posAstart;
int posB = posBstart;
int posC = posCstart;
int posD = posDstart;
int storedPosA = posAstart; //guestimate of rest
int storedPosB = posBstart; //guestimate of rest
int storedPosC = posCstart; //guestimate of rest
int storedPosD = posDstart; //guestimate of rest
Servo servoA;  // forward and backwards on pin 2
Servo servoB; //side to side on pin 4
Servo servoC; //blank on pin 5
Servo servoD;  //mouth on pin 3
ReadSerialPort();                //read the entire serial port buffer
CheckIfStopCommand();   //check if "000000000000" string was sent to DETACH ALL Servos
SerialdataToVariables();    //this has no error checking control so make sure you send the proper data
UpdateServos();                 //This function must be called as fast as possible.
Feedback();                       //this function can be removed if you dont need feedback. or changed for custom feedback
} //end loop
void ReadSerialPort(){
while (Serial.available()) { //builds up read string from serial buffer/ at this point its expects 12 digits
char c = Serial.read();  //gets one byte from serial buffer
SreadString += c; //makes the string SreadString
delay(2);  //slow looping to allow buffer to fill with next character
void CheckIfStopCommand(){
if(SreadString == "000000000000"){ // all servos DETACH
 if(debug ==1){
 Serial.println(SreadString); // DEBUGGING
 Serial.println("ALL Servos Detached"); // DEBUGGING
servoA.detach();  //
servoB.detach();  //
servoC.detach();  //
servoD.detach();  //
SreadString =""; //this clears the string
void SerialdataToVariables(){
if (SreadString.length() > 0) { //this is messy but it is a way to strip the ascii string from serial port to 4 seperate 3 digit values and remove any leading zeros
//protocol order is posA - posB - posC -posD
 posAString = SreadString;  //store the RXed string into 4 seperate strings
 posBString = SreadString;
 posCString = SreadString;
 posDString = SreadString;
 posAString.remove(3,9); //parse the desired 3 digits from each string
 posBString.remove(0,3);
 posBString.remove(3,6);
 posCString.remove(0,6);
 posCString.remove(3,3);
 posDString.remove(0,9);
 posA = posAString.toInt(); //convert to ints that have leading zeros ( 000 to 999 )
 posB = posBString.toInt();
 posC = posCString.toInt();
 posD = posDString.toInt();
 if(posA<100) posAString.remove(0,1); //remove the leading zeros
 if(posA<010) posAString.remove(0,1);
 if(posB<100) posBString.remove(0,1);
 if(posB<010) posBString.remove(0,1);
 if(posC<100) posCString.remove(0,1);
 if(posC<010) posCString.remove(0,1);
 if(posD<100) posDString.remove(0,1);
 if(posD<010) posDString.remove(0,1);
 posA = posAString.toInt(); //posX are now your integer command values (0 to 999)
 if(debug == 1){ //debug option
Serial.print("Data received: ");
Serial.print("Int posA: ");
Serial.println(posA); // DEBUGGING
Serial.print("Int posB: ");
Serial.println(posB); // DEBUGGING
Serial.print("Int posC: ");
Serial.println(posC); // DEBUGGING
Serial.print("Int posD: ");
Serial.println(posD); // DEBUGGING
SreadString=""; //empty for next input
void UpdateServos(){
 if(posA>posAmin-1 && posA<posAmax+1){ // if within min and max
 if(storedPosA>posA){ //if stored position is greater than commanded position
 servoACompleted = 0;
 storedPosA--;
 servoA.attach(servoApin);
 servoA.write(storedPosA);
 delay(1);
 if(storedPosA<posA){ //if stored position is less than commanded position
 storedPosA++;
 delay(1);
if(posB>posBmin-1 && posB<posBmax+1){
if(storedPosB>posB){ //if stored position is greater than commanded position
servoBCompleted = 0;
storedPosB--;
servoB.attach(servoBpin);
servoB.write(storedPosB);
delay(1);
if(storedPosB<posB){ //if stored position is less than commanded position
storedPosB++;
delay(1);
if(posC>posCmin-1 && posC<posCmax+1){
if(storedPosC>posC){ //if stored position is less than commanded position
servoCCompleted = 0;
storedPosC--;
servoC.attach(servoCpin);
servoC.write(storedPosC);
delay(1);
if(storedPosC<posC){ //if stored position is greater then commanded position
storedPosC++;
delay(1);
 if(posD>posDmin-1 && posD<posDmax+1){ // if within min and max
 if(storedPosD>posD){ //if stored position is greater than commanded position
 servoDCompleted = 0;
 storedPosD--;
 servoD.attach(servoDpin);
 servoD.write(storedPosD);
 delay(1);
 if(storedPosD<posD){ //if stored position is less than commanded position
 storedPosD++;
 delay(1);
void Feedback(){
if(debug == 1){
 if(storedPosA==posA && servoACompleted == 0){
 Serial.println("ServoA Done"); // DEBUGGING
 if(storedPosB==posB && servoBCompleted == 0){
   Serial.println("ServoB Done"); // DEBUGGING
 if(storedPosC==posC && servoCCompleted == 0){
  Serial.println("ServoC Done"); // DEBUGGING
 if(storedPosD==posD && servoDCompleted == 0){
  Serial.println("ServoD Done"); // DEBUGGING
mamunedt
im using flysky th9x reciver... i cant use 2 servo same time ...this srvo is for pen tilt camer ..only 1 servo working properly...
void Servo_Control1(){
 int Pos1;
 inputPina = pulseIn(42, HIGH, 25000); // /Servo 2
  Pos1 = map(inputPina, 1000, 2000,  0, 180); //center over zero
  Pos1 = constrain(Pos1, 0, 170);
totala = totala - readingsa[readIndexa];
readingsa[readIndexa] = Pos1;
totala = totala + readingsa[readIndexa];
readIndexa = readIndexa + 1;
if (readIndexa >= numReadingsa) {
    // ...wrap around to the beginning:
    readIndexa = 0;
  averagea = totala/ numReadingsa;
  Serial.println(averagea);
  myservo1.write(averagea);
  delay(1);
void Servo_Control2(){
 int Pos2;
 inputPinb = pulseIn(44, HIGH, 25000); // /Servo 2
  Pos2 = map(inputPinb, 1000, 2000,  0, 180); //center over zero
  Pos2 = constrain(Pos2, 0, 170);
totalb = totalb - readingsb[readIndexb];
readingsb[readIndexb] = Pos2;
totalb = totalb + readingsb[readIndexb];
readIndexb = readIndexb + 1;
if (readIndexb >= numReadingsb) {
    readIndexb = 0;
  averageb = totalb / numReadingsb;
  Serial.println(averageb);
  myservo2.write(averageb);
  delay(1);
PaulS
Quote
I do. Why can't you?
The snippet of code you posted does something, in addition to wasting code space. You only need ONE function. That function can take arguments, like which pin number to read from, which index into a 2D array (for the readings) and which Servo instance to write to.
You need to explain EXACTLY what the code does, EXACTLY how the servos are connected and powered, etc.
dessiebouy
I used the code from post 6 on this thread. My issue is I want to write an app in visual studio using a trackbar/scrollbar to control each servo.
here is my code on the trackbar:
private void val_trackBar_Scroll(object sender, EventArgs e)
            try
                myport.Write(val_trackBar.Value.ToString() + 'a');
                Degree_label.Text = "Degree = " + val_trackBar.Value.ToString();
            catch (Exception ex)
                MessageBox.Show(ex.Message, "Error");
In the previously posted code as far as I can understand, I must use the letter 'a' within my C# writeLine so the Arduino can pick up on which servo I am addressing and move it as requested....
It does not work :( I can get a single servo to work fine using a different sketch on the Arduino but I need to be able to use more than one.
any help would be much appreciated.
Here is the full c# code:
namespace Arduino_test
    public partial class frm_Robot : Form
        private SerialPort myport;
        public frm_Robot()
            InitializeComponent();
        private void start_btn_Click(object sender, EventArgs e)
            myport = new SerialPort();
            myport.BaudRate = 9600;
            myport.PortName = port_name_tb.Text;
            myport.Parity = Parity.None;
            myport.DataBits = 8;
            myport.StopBits = StopBits.One;
            try
                myport.Open();
                MessageBox.Show("Connected to Servo");
            if (myport.IsOpen)
                myport.WriteLine(val_trackBar.Value.ToString() + 'a');
        private void trackBar1_Scroll(object sender, EventArgs e)
            if (myport.IsOpen)
                myport.WriteLine(val_trackBar.Value.ToString() + 'b');
                Degree_label1.Text = "Degree = " + val_trackBar.Value.ToString();
        private void trackBar2_Scroll(object sender, EventArgs e)
            if (myport.IsOpen)
                myport.WriteLine(val_trackBar.Value.ToString() + 'c');
                Degree_label2.Text = "Degree = " + val_trackBar.Value.ToString();
        private void btn_stop_Click(object sender, EventArgs e)
            try
                myport.Close();
                MessageBox.Show("Disconnected From Servo");
                this.Close();
            catch (Exception ex2)
                MessageBox.Show(ex2.Message, "Error");
        private void port_name_tb_TextChanged(object sender, EventArgs e)
        private void frm_Robot_Load(object sender, EventArgs e)
            MessageBox.Show("Enter a port number (eg: COM1), click connect, dont forget to Click disconnect before closing the window.");
PaulS
The Arduino code in reply 6 does nothing until a comma is encountered. Where do you send a comma to the serial port?
Arunsai
Hii
Can any one send me MegaServo library to my mail .
Rocketscience.arun@gmail.com
     Thank you.
slipstick
#29
Jan 23, 2018, 05:24 pm Last Edit: Jan 23, 2018, 05:25 pm by slipstick
I believe MegaServo is really out of date. It's features are now incorporated in the standard Servo library so you probably already have whatever it is that you need.
Steve
