Loading...
Pages: [1]   Go Down
Author Topic: can't complie CustomCharacter example sketch- totally unedited?  (Read 734 times)
South UK
Offline Offline
Sr. Member
View Profile
hi all, I am trying to create some custom characters, I could not get it to work in my code so to try and go back to square one I am trying out the built in example CustomCharacter but won't compile and comes up with the same error I used to get? Is there something wrong with my version of the arduino software or something?
Code..
Code:
  LiquidCrystal Library - Custom Characters
 Demonstrates how to add custom characters on an LCD  display.
 The LiquidCrystal library works with all LCD displays that are
 compatible with the  Hitachi HD44780 driver. There are many of
 them out there, and you can usually tell them by the 16-pin interface.
 This sketch prints "I <heart> Arduino!" and a little dancing man
 to the LCD.
  The circuit:
 * LCD RS pin to digital pin 12
 * LCD Enable pin to digital pin 11
 * LCD D4 pin to digital pin 5
 * LCD D5 pin to digital pin 4
 * LCD D6 pin to digital pin 3
 * LCD D7 pin to digital pin 2
 * LCD R/W pin to ground
 * 10K potentiometer:
 * ends to +5V and ground
 * wiper to LCD VO pin (pin 3)
 * 10K poterntiometer on pin A0
 created21 Mar 2011
 by Tom Igoe
 Based on Adafruit's example at
 https://github.com/adafruit/SPI_VFD/blob/master/examples/createChar/createChar.pde
 This example code is in the public domain.
 http://www.arduino.cc/en/Tutorial/LiquidCrystal
 Also useful:
 http://icontexto.com/charactercreator/
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
// make some custom characters:
byte heart[8] = {
  0b00000,
  0b01010,
  0b11111,
  0b11111,
  0b11111,
  0b01110,
  0b00100,
  0b00000
byte smiley[8] = {
  0b00000,
  0b00000,
  0b01010,
  0b00000,
  0b00000,
  0b10001,
  0b01110,
  0b00000
byte frownie[8] = {
  0b00000,
  0b00000,
  0b01010,
  0b00000,
  0b00000,
  0b00000,
  0b01110,
  0b10001
byte armsDown[8] = {
  0b00100,
  0b01010,
  0b00100,
  0b00100,
  0b01110,
  0b10101,
  0b00100,
  0b01010
byte armsUp[8] = {
  0b00100,
  0b01010,
  0b00100,
  0b10101,
  0b01110,
  0b00100,
  0b00100,
  0b01010
  // create a new character
  lcd.createChar(0, heart);
  lcd.createChar(1, smiley);
  lcd.createChar(2, frownie);
  lcd.createChar(3, armsDown);
  lcd.createChar(4, armsUp);
  // set up the lcd's number of columns and rows:
  lcd.begin(16, 2);
  // Print a message to the lcd.
  lcd.print("I ");
  lcd.write(0);
  lcd.print(" Arduino! ");
  lcd.write(1);
  // read the potentiometer on A0:
  int sensorReading = analogRead(A0);
  // map the result to 200 - 1000:
  int delayTime = map(sensorReading, 0, 1023, 200, 1000);
  // set the cursor to the bottom row, 5th position:
  lcd.setCursor(4, 1);
  // draw the little man, arms down:
  lcd.write(3);
  delay(delayTime);
  // draw him arms up:
  lcd.write(4);
  delay(delayTime);
errors...
Quote
CustomCharacter.cpp: In function 'void setup()':
CustomCharacter:114: error: call of overloaded 'write(int)' is ambiguous
K:\Arduino\arduino-1.0\libraries\LiquidCrystal/LiquidCrystal.h:82: note: candidates are: virtual size_t LiquidCrystal::write(uint8_t)
K:\Arduino\arduino-1.0\hardware\arduino\cores\arduino/Print.h:49: note:                 size_t Print::write(const char*)
« Last Edit: March 06, 2012, 08:10:09 pm by dtokez » Logged
Offline Offline
God Member
View Profile
I haven't used the lcd library and I don't know what the code is trying to do but try changing each occurrence of this kind of statement:
Code:
lcd.write(0);
to this:
Code:
lcd.write('0');
Pete
Logged
South UK
Offline Offline
Sr. Member
View Profile
Hi, that complies but just displays the actual number instead of the char i.e lcd.write('3'); just writes the number 3?
Maybe there is a problem with the example sketch?
Logged
Offline Offline
God Member
View Profile
AHA. Now I understand. The way around it is to use, for example,
Code:
lcd.write((uint8_t)0);
Pete
Logged
South UK
Offline Offline
Sr. Member
View Profile
Thanks I will try that later, surely the example sketch built into the Arduino IDE should work without any modification?
Logged
Offline Offline
God Member
View Profile
It may be caused by the difference between libraries and examples created for V0.23 or earlier and the V1.0 IDE.
Pete
Logged
South UK
Offline Offline
Sr. Member
View Profile
that's great it works fine now smiley
is there a way to tell the people in charge that the example sketch needs attention?
Logged
Deep South (Of England)
Offline Offline
Newbie
View Profile
Thanks so much for this info guys smiley
I have been pulling my hair out trying to fix this same issue.
Works perfectly now.
Cheers
Andy R (AKA G1UUP)
Logged
Offline Offline
Newbie
View Profile
Hi all,
I just had the same issue with that example...
I fixed by increasin 1 up the assigned numbers for each customized character, that means, leaving 0 unused.
So, first customized character in my case is 1.
Obviously, I had all refences changed to fit the proper character numbers.
Cheers,
Rafa.
Logged
Pages: [1]   Go Up
Print
Jump to:
