Loading...
Pages: [1]   Go Down
Author Topic: AM2302 (DHTT) : Could it really be this easy?  (Read 344 times)
Asnieres sur Seine - France
Offline Offline
Jr. Member
View Profile
WWW
I recently received a new AM2302 temperature / humidity sensor. It's a fully-assembled, wired, version of the DHT22. It seems to be almost too simple to implement. There are 4 wires: one for 5v power (connected to a built-in resistor), one for data and one for ground. There's a fourth wire, in between the 2nd and 4th, which is supposedly useless. But I've heard that it works better if that is also plugged in to ground.
I found the DHT library and example code, copied and pasted a few routines in to my basic code. I plugged the 4 wires in to my mini breadboard and then to my Arduino Uno.
In less than a half an hour I had a fully operational temperature / humidity display program running (hardware & software).
It just seems too easy. I must be missing something. I am counting on you experienced Arduino engineers to tell me what I have forgotten or not adjusted for.
My whole project is here:
http://fritzing.org/projects/arduino-am2302-on-a-mini-breadboard/
Logged
Offline Offline
God Member
View Profile
It should be that simple.  i am not sure what you are worried about.
The only trouble with those,  seems to be the inherently flaky method of measuring the
humidity.
Logged
Offline Offline
Jr. Member
View Profile
WWW
Thanks for the confirmation michinyon.
Is there any way to work around the "flaky humidity measurements"?
Is there a better, or more precise, humidity sensor?
Thanks.
Logged
Offline Offline
God Member
View Profile
As far as I know,  there is no "foolproof" method of detecting humidity in air.
There are four or five methods,  none of them are much good.
Logged
Netherlands
Online Online
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
There is a defined relation between the speed of sound, the temperature and the humidity. [defined != trivial]
I discussed that here - http://arduino.cc/forum/index.php/topic,65205.msg493120.html#msg493120 -
Code:
float sos =  331.45 * sqrt(1 + t/273) *  (100 + RH * 0.11  * power(1.82, ((t-273)/10)));  // t in Kelvin
That means if one measures the speed of sound and one knows the temperature one can derive the humidity.
Code:
RH = (sos / (331.45 * sqrt(1 + t/273)) - 100) / ( 0.11  * power(1.82, ((t-273)/10))));   // TODO check () and formula
Temperature can be measured with a DS18B20 as it has a 0.1 precission.
The speed of sound can be measured with an ultrasound sensors with a defined distance e.g. 50,0000 cm from a wall.
[not build myself but should not be too hard]
Give it a try
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Offline Offline
God Member
View Profile
At temperature around 20C,  the variation in the speed of sound over the range 0% to 100% relative humidity,
is less than one part in ten thousand,   which is likely to be beyond the resolution of your ultrasonic device.
Logged
Netherlands
Online Online
Tesla Member
View Profile
I know the diff is small but I did notinvestigate how small.
Logged
Rob Tillaart
Pages: [1]   Go Up
Print
Jump to:
