Topic: Arduino Nes controller, Please Help! (Read 20433 times) previous topic - next topic
Craftee
im just a kid that needs help, gosh!
If you think you are capable of solving this problem already with a little help, then you ought to be at least part way there on your own. Show us where you've got so far and which part you need help with, and no doubt there will be plenty of people willing to steer you round the problem.
If you simply don't know where to start, then put this project down and start with something simpler. It's best not to try to boil the ocean - learn things one step at a time.
well i wanna do a project that matters to me, not just some flop project i wont learn anything from, because more often than not, i find myself copying code. i know very little about code.
nickgammon
Please post technical questions on the forum, not by personal message. Thanks!
More info:
http://www.gammon.com.au/electronics
Craftee
Well, try something and post what you tried.
What have you tried?
Code: [Select]
const int latch = 2;
const int clock = 3;
const int data  = 4;
#define latchlow digitalWrite(latch, LOW)
#define latchhigh digitalWrite(latch, HIGH)
#define clocklow digitalWrite(clock, LOW)
#define clockhigh digitalWrite(clock, HIGH)
#define dataread digitalRead(data)
#define wait delayMicroseconds(200)
byte output;
        while (! Serial ) { }
pinMode(latch, OUTPUT);
        pinMode(clock, OUTPUT);
        pinMode(data, INPUT);
        Keyboard.begin();
  if(KeyboardSerial == 127)
  Keyboard.press(a)
    else ()
    Keyboard.release()
  if(KeyboardSerial == 126)
  Keyboard.press(b)
    else ()
    Keyboard.release()
  if(KeyboardSerial == 119)
  Keyboard.press(up_arrow)
    else ()
    Keyboard.release()
  if(KeyboardSerial == 111)
  Keyboard.press(down_arrow)
    else ()
    Keyboard.release()
  if(KeyboardSerial == 63)
  Keyboard.press(right_arrow)
    else ()
    Keyboard.release()
  if(KeyboardSerial == 95)
  Keyboard.press(left_arrow)
    else ()
    Keyboard.release()
  output = 0;
  ReadNESjoy();
// Serial.write(output);
  Serial.println ((unsigned int)output);
void ReadNESjoy()
  latchlow;
  clocklow;
  latchhigh;
  wait;
  latchlow;
  for (int i = 0; i < 8; i++) {
     clockhigh;
     wait;
     output += dataread * (1 << i);
     clocklow;
     wait;
nickgammon
You have to start thinking about what you are doing.
Code: [Select]
What is KeyboardSerial?
Previously you were displaying the value of output. So surely you want to test that?
Code: [Select]
  if(output == 127)
But, wait! You are testing it before you find out what it is.
How about:
Code: [Select]
  output = 0;
  ReadNESjoy();
  if(output == 127)
It's not magic. Think about what the variables mean and use them in a useful way.
More info:
Craftee
Code: [Select]
  output = 0;
  ReadNESjoy();
  if(output == 127)
  Keyboard.press('a')
    else ()
    Keyboard.release()
  if(output == 126)
  Keyboard.press('b')
    else ()
    Keyboard.release()
  if(output == 119)
  Keyboard.press('up_arrow')
    else ()
    Keyboard.release()
  if(output == 111)
  Keyboard.press('down_arrow')
    else ()
    Keyboard.release()
  if(output == 63)
  Keyboard.press('right_arrow')
    else ()
    Keyboard.release()
  if(output == 95)
  Keyboard.press('left_arrow')
    else ()
    Keyboard.release()
  if(output == 123)
  Keyboard.press('s')
    else ()
    Keyboard.release()
  if(output == 125)
  Keyboard.press('l')
    else ()
    Keyboard.release()
Craftee
it says ";" is expected before else, im not sure where to put it....
nickgammon
Find a book on programming in C. Read it.
Quote
You wanna learn? Start reading.
More info:
Craftee
Quote
i did, i even bought a huge book!. but im just not getting it. i figure since alot of people learn by just diving into it, i would try the same
Craftee
Code: [Select]
  if(output == 127)
  Keyboard.press('a');
    else ()
    Keyboard.release()
i fixed the ";" problem, but it says
"expected primary expression before ")"
Code: [Select]
    else ()
lloyddean
Code: [Select]
if ( output == 127 )
    Keyboard.release();
Craftee
Code: [Select]
    Keyboard.release();
hmm i tried that, and i got this error "no matching function for call to "Keyboard_::release()
Craftee
okay i fixed that error with
Code: [Select]
    Keyboard.release('a');
but now, it spams the "a" button. because for some reason when i serial monitor it, it spams 127 and not 0, im not sure why this is happening
JimboZA
Quote
Fair point...
But:
Quote
I thought you did copy the code, and I'd actually question what you're learning by getting the forum to debug it line by line.
Quote
An admirable approach except it's a way of drowning if you don't have a strong support group (read as: forum members patient enough to help while putting up with your impatience as in bumping posts when you don't get an instant response)
I suggest you work through tutorials like these or these
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
Craftee
Quote
Quote
actually, i have learned a lot from this thread. already i know 10x more than i did before i started.
Quote
Quote
An admirable approach except it's a way of drowning if you don't have a strong support group...
HI :P
nickgammon
@ Craftee
I'm sorry, but you haven't learnt the absolute basics, like how to write statements in C. I don't want to seem unhelpful, but you really need to learn a bit of that, before you start making something that sends keystrokes when buttons on an NES controller are pushed. You are trying to run, when you haven't learnt to crawl yet.
Statements in C end in a semicolon. Function calls have brackets. "if" and "else" are not function calls.
Things have to be done in sequence. You don't get out your raincoat, and then afterwards ask if it is raining.
Do some simpler examples, get the hang of programming, and it will reward you with being a lot less frustrating.
If you ask, on a line-by-line basis, how to fix things,  you aren't learning, are you? You are just posting code, asking what is wrong, applying a one-line fix, and then moving onto the next line.
More info:
