Topic: Arduino Nes controller, Please Help! (Read 19584 times) previous topic - next topic
Craftee
Feb 01, 2013, 05:26 am Last Edit: Feb 01, 2013, 05:33 am by Craftee Reason: 1
So i came across this project i wanted to do, but i know nothing about code and im getting a bunch to errors. heres the original link
(i have Leonardo and im using 1.0.3)
http://www.instructables.com/id/USB-NES-controller-with-an-arduino/
And heres the code for the arduino
const int latch = 2;
const int clock = 3;
const int data  = 4;
#define latchlow digitalWrite(latch, LOW)
#define latchhigh digitalWrite(latch, HIGH)
#define clocklow digitalWrite(clock, LOW)
#define clockhigh digitalWrite(clock, HIGH)
#define dataread digitalRead(data)
#define wait delayMicroseconds(200)
byte output;
pinMode(latch, OUTPUT);
       pinMode(clock, OUTPUT);
       pinMode(data, INPUT);
 output = 0;
 ReadNESjoy();
 Serial.print(output, BYTE);
void ReadNESjoy() {
 latchlow;
 clocklow;
 latchhigh;
 wait;
 latchlow;
 for (int i = 0; i < 8; i++) {
    clockhigh;
    wait;
    output += dataread * (1 << i);
    clocklow;
    wait;
It says "BYTE" is no longer used
And heres the code for Processing, idk what it is. (first time using arduino, or any code for that matter and yes i did look around to find any solutions..... none)
import processing.serial.*;
import java.awt.*;
Serial arduino;
Robot VKey;
PImage bgImage;
char recvout;
char prevout;
char deltaout;
 size(434,180);
 frameRate(30);
 println(Serial.list());
 arduino = new Serial(this, Serial.list()[1], 9600); // ATTENTION!!!
 bgImage = loadImage("NEScontroller.jpg");
 try
   VKey = new Robot();
 catch(AWTException a){}
 prevout = 0;
void draw() {
 if (bgImage != null) { background(bgImage); }
 fill(255, 255, 0);
 serialRead();
 deltaout = (char)((int)recvout ^ (int)prevout);
 emulateKeyboard();
 prevout = recvout;
void serialRead() {
 while (arduino.available() > 0) {
   recvout = arduino.readChar();
void emulateKeyboard() {
 if ((deltaout & 1  ) == 1  ) { if ((recvout & 1  ) == 1  ) {VKey.keyPress(KeyEvent.VK_L);} else {VKey.keyRelease(KeyEvent.VK_L);}}
 if ((deltaout & 2  ) == 2  ) { if ((recvout & 2  ) == 2  ) {VKey.keyPress(KeyEvent.VK_K);} else {VKey.keyRelease(KeyEvent.VK_K);}}
 if ((deltaout & 4  ) == 4  ) { if ((recvout & 4  ) == 4  ) {VKey.keyPress(KeyEvent.VK_G);} else {VKey.keyRelease(KeyEvent.VK_G);}}
 if ((deltaout & 8  ) == 8  ) { if ((recvout & 8  ) == 8  ) {VKey.keyPress(KeyEvent.VK_H);} else {VKey.keyRelease(KeyEvent.VK_H);}}
 if ((deltaout & 16 ) == 16 ) { if ((recvout & 16 ) == 16 ) {VKey.keyPress(KeyEvent.VK_W);} else {VKey.keyRelease(KeyEvent.VK_W);}}
 if ((deltaout & 32 ) == 32 ) { if ((recvout & 32 ) == 32 ) {VKey.keyPress(KeyEvent.VK_S);} else {VKey.keyRelease(KeyEvent.VK_S);}}
 if ((deltaout & 64 ) == 64 ) { if ((recvout & 64 ) == 64 ) {VKey.keyPress(KeyEvent.VK_A);} else {VKey.keyRelease(KeyEvent.VK_A);}}
 if ((deltaout & 128) == 128) { if ((recvout & 128) == 128) {VKey.keyPress(KeyEvent.VK_D);} else {VKey.keyRelease(KeyEvent.VK_D);}}
It says "import" is not used or something like that
Here are the files where i got the code from
http://www.instructables.com/files/orig/F2U/W6FP/GVXHOG2Y/F2UW6FPGVXHOG2Y.zip
if you could help me, i would highly appreciate it
thanks to anyone who answers :D
Craftee
#1
Feb 01, 2013, 05:40 am Last Edit: Feb 01, 2013, 05:53 am by Craftee Reason: 1
const int data  = 4;
byte output;
 output = 0;
 ReadNESjoy();
void ReadNESjoy() {
 latchlow;
 clocklow;
 latchhigh;
 wait;
 latchlow;
    clockhigh;
    wait;
    clocklow;
    wait;
import java.awt.*;
Serial arduino;
Robot VKey;
PImage bgImage;
char recvout;
char prevout;
char deltaout;
 size(434,180);
 frameRate(30);
 try
   VKey = new Robot();
 prevout = 0;
void draw() {
 fill(255, 255, 0);
 serialRead();
 emulateKeyboard();
 prevout = recvout;
void serialRead() {
it says   'import' does not name a type
JimboZA
You're not going to get many responses to a question something like that
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
Craftee
It says exactly
PaulS
Are you trying to compile the Processing sketch in the Arduino IDE? That's exactly the error I get when I try that.
A visit to http://processing.org is in your future.
Nick Gammon
Please do not cross-post. This wastes time and resources as people attempt to answer your question on multiple threads.
Threads merged.
- Moderator
More info:
Craftee
Threads merged.
- Moderator
D: sorry, i wasnt getting any responses so i expanded my search :( forgive me
also, how do i fix the "BYTE" problem?(i have no clue as to what im doing)
Craftee
I downloaded it and rand the thing through processing, but now i get
cannot find anything named "KeyEvent.VK_L"
Craftee
so i have this old peice of code here, and i get an error saying "The 'BYTE' keyword is no longer supported" so what do i use instead? please help!
const int data  = 4;
byte output;
 output = 0;
 ReadNESjoy();
void ReadNESjoy() {
 latchlow;
 clocklow;
 latchhigh;
 wait;
 latchlow;
    clockhigh;
    wait;
    clocklow;
    wait;
AWOL
Topics merged.
Please don't start a new thread on the same subject.
Look up "Serial.write".
Craftee
Topics merged.
i did look it up, telling me "look up serial.write" doesnt tell me anything. i think as a moderator you could help? jeeze
Craftee
and i get an answer already? so i can move on with my life? seriously why do i have to wait so long for a legit response?
AWOL
Four minutes to a bump post?
How am I supposed to know that?
I saved you the embarrassment of having your cross-posting reported as a violation of forum rules, didn't I?
Craftee
... talk about policing, is this where i come to get help? or is it a place for forum moderators to do their job?
AWOL
I'm a janitor, not a policeman.
I clean up after untidy posters.
