Topic: Help with Arduino Uno as UART-USB converter (Read 5200 times) previous topic - next topic
angelo_amadei
Hi everyone! I'm looking some help..
Recently I bought an Arduino Uno and for now, I need to use it as a UART-USB converter (just like the circuits with FT232R, creating a virtual serial port).
I try to use Serial Monitor connecting Tx and Rx of the Uno to the Rx and Tx of the other device, but when I send some ASCII caracters from my computer, they seem to go to the Uno and I want to send them to the device.
Can I use the Serial Monitor?
Do I need to use another software, like goSerial or ZTerm? (I have a macbook)
Do I need to remove the Uno's atmega?
I appreciate any help!! Thanks!
Greeting from Chile!
Coding Badly
Do you have a jumper connecting RESET to GND?
CrossRoads
You can use the Serial Monitor.
You need to remove the Uno's atmega.
Or connect Reset header pin to Gnd.
retrolefty
#3
Feb 01, 2013, 07:23 am Last Edit: Feb 01, 2013, 07:28 am by retrolefty Reason: 1
Used that way you must wire pin 0 to pin 0 and pin 1 to pin 1 between the two arduino boards, or if wiring to an external serial device, pin 0 goes to the devices rec input pin and pin 1 wires to the external devices tx output pin. Also you need to be sure to add a wire between the two arduino boards. And as CR said either remove the AVR chip or add a wire from ground to reset pin on the arduino being used as the USB bridge.
Lefty
angelo_amadei
It works!! xD
Thanks a lot for your help!!!
I'll sleep well today..
Greeting from Chile!!
