Author Topic: sainsmart 3.2inch  (Read 375 times)
hey all.
The electronics side of arduino is so very easy for me but the C programming and all involved on that side is causing me isssues. I just suck at learning it. so my question is as follows.
I got a sainsmart 3.2" tft with touch and sd card with shield http://www.ebay.com.au/itm/SainSmart-Mega2560-3-2-LCD-TFT-Touch-Screen-SD-Reader-4-Arduino-UNO-R3-Robot-/261094891095
I also have a little rtc http://compare.ebay.com.au/like/281012548037?ltyp=AllFixedPriceItemTypes
My objective is to simply use the screen to display a jpeg with the time under it. anyone willing to help out?
the pictures won't be that big but there will be about 10 of them to cycle through.
Leeds, England
Quick, chuck it in the bin before the boss finds out...
Have you found the libraries to control this product? If not then download them from:
http://henningkarlsen.com/electronics/
The examples should help. As I see it the biggest problem is actually hooking up the RTC to the Arduino.
I got the libraries but none of them seem to work the example code for the graph seems odd
#include <Wire.h>
// ITDB02_Graph16_Demo (C)2011 Henning Karlsen
// web: http://www.henningkarlsen.com/electronics
// This program is a demo of how to use most of the functions
// of the library with a supported 16bit display module.
// This demo was not made for the widescreen modules. Use
// ITDB02_Graph16_Demo_Widescreen instead.
// This program requires the ITDB02_Graph16 library.
#include <ITDB02_Graph16.h>
// Declare which fonts we will be using
extern uint8_t SmallFont[];
//myGLCD(RS,WR,CS,RST,ALE,mode);
ITDB02 myGLCD(A1,A2,A0,A4,A5,2);   //
  //randomSeed(analogRead(0));
  //Serial.begin(9600);
// Setup the LCD
  myGLCD.InitLCD();
  myGLCD.setFont(SmallFont);
void loop1()
  myGLCD.LCD_Writ_Bus(0x55,0xaa);
  delay(10);
  myGLCD.LCD_Writ_Bus(0xaa,0x55);
  delay(10);
  //Serial.println("write bus");
  myGLCD.clrScr();
  int buf[238];
  int x, x2;
  int y, y2;
  int r;
// Clear the screen and draw the frame
  myGLCD.clrScr();
  myGLCD.setColor(255, 0, 0);
  myGLCD.fillRect(0, 0, 239, 13);
  myGLCD.setColor(64, 64, 64);
  myGLCD.fillRect(0, 306, 239, 319);
  myGLCD.setColor(255, 255, 255);
  myGLCD.setBackColor(255, 0, 0);
  myGLCD.print("QVGA TFT 240x320 Color Display", CENTER, 1);
  myGLCD.setColor(255, 128, 128);
  myGLCD.setBackColor(64, 64, 64);
  myGLCD.print("H.Karlsen", LEFT, 307);
  myGLCD.print("(C)2011", RIGHT, 307);
  myGLCD.setColor(255,255,0);
  myGLCD.print("Portrait", CENTER, 307);
  myGLCD.setColor(0, 0, 255);
  myGLCD.drawLine(0, 14, 239, 14);
  myGLCD.drawLine(0, 14, 0, 305);
  myGLCD.drawLine(239, 14, 239, 305);
  myGLCD.drawLine(0, 305, 239, 305);
// Draw crosshairs
  myGLCD.setBackColor(0, 0, 0);
  myGLCD.drawLine(119, 15, 119, 304);
  myGLCD.drawLine(1, 159, 238, 159);
  for (int i=9; i<240; i+=10)
    myGLCD.drawLine(i, 157, i, 161);
  for (int i=19; i<300; i+=10)
    myGLCD.drawLine(117, i, 121, i);
// Draw sin-, cos- and tan-lines
  myGLCD.setColor(0,255,255);
  myGLCD.print("Sin", 5, 15);
  for (int i=1; i<238; i++)
    myGLCD.drawPixel(i,159+(sin(((i*1.51)*3.14)/180)*100));
  myGLCD.setColor(255,0,0);
  myGLCD.print("Cos", 5, 27);
    myGLCD.drawPixel(i,159+(cos(((i*1.51)*3.14)/180)*100));
  myGLCD.print("Tan", 5, 39);
    myGLCD.drawPixel(i,159+(tan(((i*1.51)*3.14)/180)));
  delay(2000);
  myGLCD.setColor(0,0,0);
  myGLCD.fillRect(1,15,238,304);
// Draw a moving sinewave
  x=1;
  for (int i=1; i<6902; i++)
    x++;
    if (x==239)
      x=1;
    if (i>239)
      if ((x==119)||(buf[x-1]==159))
        myGLCD.setColor(0,0,255);
      myGLCD.drawPixel(x,buf[x-1]);
    y=159+(sin(((i*1.4)*3.14)/180)*(100-(i / 100)));
    myGLCD.drawPixel(x,y);
    buf[x-1]=y;
  delay(2000);
// Draw some filled rectangles
  for (int i=1; i<6; i++)
    switch (i)
      case 1:
        myGLCD.setColor(255,0,255);
        break;
      case 2:
        break;
      case 3:
        myGLCD.setColor(0,255,0);
        break;
      case 4:
        break;
      case 5:
        break;
    myGLCD.fillRect(30+(i*20), 70+(i*20), 90+(i*20), 130+(i*20));
  delay(2000);
// Draw some filled, rounded rectangles
    switch (i)
      case 1:
        break;
      case 2:
        break;
      case 3:
        break;
      case 4:
        break;
      case 5:
        break;
    myGLCD.fillRoundRect(150-(i*20),70+(i*20), 210-(i*20), 130+(i*20));
  delay(2000);
// Draw some filled circles
    switch (i)
      case 1:
        break;
      case 2:
        break;
      case 3:
        break;
      case 4:
        break;
      case 5:
        break;
    myGLCD.fillCircle(60+(i*20),100+(i*20), 30);
  delay(2000);
// Draw some lines in a pattern
  myGLCD.setColor (255,0,0);
  for (int i=15; i<304; i+=5)
    myGLCD.drawLine(1, i, (i/1.22)-10, 304);
  for (int i=304; i>15; i-=5)
    myGLCD.drawLine(238, i, (i/1.22)-11, 15);
  myGLCD.setColor (0,255,255);
    myGLCD.drawLine(1, i, 251-(i/1.22), 15);
    myGLCD.drawLine(238, i, 250-(i/1.22), 304);
  delay(2000);
// Draw some random circles
  for (int i=0; i<100; i++)
    myGLCD.setColor(random(255), random(255), random(255));
    x=32+random(175);
    y=45+random(212);
    r=random(30);
    myGLCD.drawCircle(x, y, r);
  delay(2000);
// Draw some random rectangles
    x=2+random(236);
    y=16+random(287);
    x2=2+random(236);
    y2=16+random(287);
    myGLCD.drawRect(x, y, x2, y2);
  delay(2000);
// Draw some random rounded rectangles
    x=2+random(236);
    y=16+random(287);
    x2=2+random(236);
    y2=16+random(287);
    myGLCD.drawRoundRect(x, y, x2, y2);
  delay(2000);
  myGLCD.fillRect(2,16,238,304);
    x=2+random(236);
    y=16+random(289);
    x2=2+random(236);
    y2=16+random(289);
    myGLCD.drawLine(x, y, x2, y2);
  delay(2000);
  for (int i=0; i<10000; i++)
    myGLCD.drawPixel(2+random(236), 16+random(289));
  delay(2000);
  myGLCD.fillScr(0, 0, 255);
  myGLCD.fillRoundRect(30, 100, 209, 219);
  myGLCD.print("That's it!", CENTER, 133);
  myGLCD.print("Restarting in a", CENTER, 159);
  myGLCD.print("few seconds...", CENTER, 172);
  myGLCD.setColor(0, 0, 0);
  myGLCD.setBackColor(0, 0, 255);
  myGLCD.print("Runtime: (msecs)", CENTER, 290);
  myGLCD.printNumI(millis(), CENTER, 305);
  delay (10000);
that line is weird cos there is nothing connected to the analog pins with the shield. is this just an example of bad programming or am I missing something?
Anaheim CA.
Experienced old Whitebeard with a Full head of Hair...
Use the libs from here: http://henningkarlsen.com/electronics/library.php?id=52
They work well with the SainSmart product. I have 5 working, 1 a 4.3" with those libraries. Read the tutorials all is explained fairly well and all the libs are easy to use. The ITDB stuff is several years old and usually difficult to use where the new UTFT libs... Are New.
Bob
“The solution of every problem is another problem.” -Johann Wolfgang von Goethe
does that give me full function of the device? its touch screen AND SD card too?
also I really suck at programming most of my mates are just into electronics I find it hard to program as it takes so long to get responses I lose my train of thought and get no where
