Topic: Shift Registers and PWM (Read 928 times) previous topic - next topic
Cynar
Hi all.
I'm trying to find a viable IC for a project, but all my searches are being bogged down in clutter.
I want to drive a couple of RGB LED strips via a serial type link. The annoyance is I need PWM on them and quite a few strips.
Effectively I need a shift register type IC with either (about) 3 or 6 outputs with PWM. I'm not worried current wise, since I am driving it through a darlington array IC.
The best I have found so far is the TLC5940 (http://www.mouser.com/ds/2/405/slvs515c-197949.pdf) at £2.29 ea this is massively overkill output wise though at 16.
I am considering ATtiny ICs with some custom firmware, but I am sure there is a prebuilt solution out there.
Does anyone know anything more cost effective?
fungus
You don't really need the TLC5940 for current regulation (it's built into the strips) so why not use the Arduino PWM? It has six channels.
No, I don't answer questions sent in private messages (but I do accept thank-you notes...)
Cynar
Quote
I'm not just using 1 chip. I need to control 17 RGB strips with full PWM. I'm planning my initial breadboarding to use a arduino mega to drive it, I suspect I might be pushing it's limit with it though, and I want it to do more than just talk to the lights (it will be talking to an ethernet chip and an SD card as well).
There is also very little space to hide cables, so running 68 cables around will look very ugly.
What I want to do is have a small sub-board for each strip (or 2), with just a 4 wire link to all of them, that way I can use a piece of CAT5 to make it look neat. This requires 3 or 6 PWM channels on each sub-board, 16 is overkill and racks up the price quite a bit (particularly if I scale up the numbers later)
fungus
Quote
There are chips with less outputs but they tend to be three outputs, not six. They're also surface mount so difficult to use at home (the DIP package is a big reason why the TLC5940 is so popular with hobbyists).
Ah, now the full specification starts to appear...
The TLC5940 isn't just a 4 wire link, it needs constant love from the CPU to keep the PWM running, you need at least six wires to the chip to make it work (SCLK, SIN, BLANK, XLAT, GSCLK and GND). Add power and that makes it seven.
If you want to do it with four wires then you'll have to put a microcontroller on your boards to do the communications, in which case you might as well do the PWM in software as well. You can use pre-built mini-Arduinos or put a Mega328 on a piece of perf-board. A Tiny84 would work too but will need much more programming work.
Cynar
Looks like I am using ATTiny85s then.
I'm quite surprised there is nothing like it on the market already though.
CrossRoads
How about WS2801 per strip, or one for every 3 strips?
http://www.adafruit.com/datasheets/WS2801.pdf
GoForSmoke
I try and see prices because to me bit-bang for the buck is a concern.
You can fit 3 Tiny85's on a 24-pin socket but even disabling reset you only have 6 pins free each.
The Tiny44's start with 14 pins. You might double the usable pins for less than 2x the $.
Nick Gammon on multitasking Arduinos:
1) http://gammon.com.au/blink
2) http://gammon.com.au/serial
3) http://gammon.com.au/interrupts
Cynar
That is EXACTLY what I was looking for! :D
Does 3 LEDs, and can drive a transistor, also available for £0.30 ea inc shipping :D
(http://www.ebay.co.uk/itm/30pcs-WS2801SO-WS2801-ORIGINAL-3-Channel-RGB-Constant-Current-PWM-LED-Driver-/261034394045#vi-content)
Your help is VERY much appreciated.
CrossRoads
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
