Author Topic: SOLVED! Looking for a 5x8 LCD extended ASCII font — characters 32-255  (Read 573 times)
France
Hi!
I'm looking for a 6x8 font which includes the extended ASCII characters as described at http://www.ascii-code.com
Languages like French and Spanish use many letters with accents which are in the extended ASCII characters set.
The extended ASCII codes (character code 128-255)
There are several different variations of the 8-bit ASCII table. The table below is according to ISO 8859-1, also called ISO Latin-1. Codes 129-159 contain the Microsoft® Windows Latin-1 extended characters.
I've tried different solutions:
  • using MikroElectronica free font generator and importing a Windows font. The Terminal font doesn't include the extended ASCII characters and the other fonts don't feature a 6x8 size.
  • reducing 8x8 to 6x8 with the same tool. Too many letters are impossible to read.
  • looking for a fixed-sized Windows font with 6x8 size. Google throws too many false-positive results.
  • designing the characters from 128 to 255. But it's slow and requires a lot of time!
Thank you for your help.
« Last Edit: February 08, 2013, 09:57:49 am by avenue33 » Logged
avenue33
Boston area, metrowest
Like Nike says: Just Do It!
Norfolk UK
Maybe the software does not support extended character set as it's in my Terminal font.
Germany
If you believe something is right, you won't see what's wrong (David Straker).
For my Arduino graphics lib "u8glib" i have include several 100 fonts. Most of them with extended chars.
http://code.google.com/p/u8glib/wiki/fontsize
I decided to derive the internal font format from the plain text font format "bdf".
http://en.wikipedia.org/wiki/Glyph_Bitmap_Distribution_Format
BDF is not that common, but still a lot of fonts are available and BDF can also be derived from TTF.
U8glib includes a bdf converter and bdf font procedures.
All in all u8glib can display any glyph from unicode space.
Oliver
France
...what's the ASCII code for the swash?  smiley
avenue33
France
@Oliver
Thank you for the useful links!
avenue33
Germany
u8glib is distributed under the BSD license. So all the code could be used in other projects also. Just take over the code from here:
http://code.google.com/p/u8glib/source/browse/csrc/u8g_font.c
Then you could use any existing u8glib font.
Oliver
Nike swoosh, for 8x8 font smiley-cool
1e, 3f, 7f, cf, 0f,0e, 1c, 38
France
Finally, it took the last solution,
with MikroElectronica free font generator
Actually, there are only 64 additional characters to define, 0xA0 to 0xFF on the ISO-8859-1 tablea.
I'm not using the Arduino IDE, so the characters are coded in UTF8 and need to be translated into ISO-8859-1.
Thanks for your help, links and ideas!
avenue33
