Offline
Newbie
« on: February 01, 2013, 08:44:09 am » |
Hello, I am new to Arduino. I have a set up a project reading a MS5611 baro board. Everthing works fine on my Win7 installation, but when i connect the board to XP I get bad output on my serial monitor Win XP output: Temp:142767.2 Altitude:-14628628.0m Normdruck: 316851.90 bei 135.00m Win 7 output: Temp:24.5 Altitude:103.4m Normdruck: 1006.6 bei 135.00m
floating point numbers are wrong, string is OK. the connection Arduino to PC is done by cp210x usb-serial adapter. Everthing is setup equal on XP and Win7. Any idea what wrong here?
Logged
Switzerland
Offline
Faraday Member
« Reply #1 on: February 01, 2013, 02:09:10 pm » |
Haven't seen your Arduino code yet.
From Win7 to XP do you just pull the USB connector out of the Win 7 machine and into the XP machine? Or do you have two separate setups, one connected to a Win 7 machine and the other one to a XP machine?
Logged
UK
Offline
Tesla Member
« Reply #2 on: February 01, 2013, 04:24:09 pm » |
Suggest you post your code, and also write a test sketch that just prints out hard-coded values similar to the ones you're seeing here. At the moment it's not clear whether the problem is the sketch printing rubbish, or the valid output being scrambled (somehow very selectively) before it reaches the PC. Neither seems likely, so you need to simplify the test system and eliminate some assumptions.
Logged
Netherlands
Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
« Reply #3 on: February 01, 2013, 05:30:40 pm » |
Temp:142767.2 Altitude:-14628628.0m Normdruck: 316851.90 bei 135.00m Note: The arduino floating point has only 6 or 7 significant digits. check spec IEEE754. That means 10 digit numbers cannot be represented ... It looks to me like it wants to read doubles which are 8 bytes where float are 4 bytes. which terminal programs are you using?
Logged
Offline
Newbie
« Reply #4 on: February 04, 2013, 03:00:39 am » |
I have attached my code. I use a Arduino pro mini board, which is conneted to the PC by an CP210X USB2UART connector I have installed the latest driver on both machines (WIN7 and WIN XP) I use the Serial Monitor on both machines and I tried also with HTerm.exe (hyperterminal) which shows always the same, on WIN7 everything is OK, on Win XP floating numbers are wrong.
Logged
Netherlands
Offline
Tesla Member
« Reply #5 on: February 04, 2013, 12:42:26 pm » |
on WIN7 everything is OK, on Win XP floating numbers are wrong. Amazing! - do you upload the sketch again or just connect the Arduino? - which IDE version are on WIN7 / XP? - Can you try this sketch on both machines? (just upload it once) float pi=3.14159265;
void setup() { Serial.begin(115200);
for (int i = 0; i < 8; i++) { Serial.println(pi, i); } Serial.println(); }
void loop() { }
« Last Edit: February 04, 2013, 12:58:22 pm by robtillaart »
Logged
East Anglia (UK)
Offline
Edison Member
May all of your blinks be without delay
« Reply #6 on: February 04, 2013, 12:56:21 pm » |
Missing int in line 7 ?
Logged
Netherlands
Offline
Tesla Member
« Reply #7 on: February 04, 2013, 12:58:40 pm » |
fixed int,  thank you
Logged
East Anglia (UK)
Offline
Edison Member
« Reply #8 on: February 04, 2013, 01:01:56 pm » |
No problem. Nothing compared to some howlers that I have posted. Luckily I had a spare int here so was able to run the code and I can confirm that it works as expected for me.
Logged
Netherlands
Offline
Tesla Member
« Reply #9 on: February 04, 2013, 01:04:57 pm » |
I did not test it, just "spit out" the code in one stream, but thanks for confirming that it does what it should do.
These kind of minimal test sketches are useful when debugging the Arduino core
Logged
Offline
Newbie
« Reply #10 on: February 05, 2013, 07:08:34 am » |
Thank you for your hints. I took the above code into my sketch ( I put it into the "loop") compiled it on WIN XP: I get these results: 3 3.1 3.14 3.142 3.1416 3.14159 3.141593 3.1415927 3.14159274
TEMP= 142768.03 ALTITUDE= -14634452.00m 1-Normdruck= 318159.0 bei 135.00m
then I took the Arduino to WIN7: first I got the same strange results.... 3 3.1 3.14 3.142 3.1416 3.14159 3.141593 3.1415927 3.14159274
TEMP= 142770.59 ALTITUDE= -14627349.00m 1-Normdruck= 316493.2 bei 135.00m 3 3.1 3.14 3.142 3.1416 3.14159 3.141593 3.1415927 3.14159274
TEMP= 142770.70 ALTITUDE= -14626947.00m 1-Normdruck= 316399.8 bei 135.00m 3 3.1 3.14 3.142 3.1416 3.14159 3.141593 3.1415927 3.14159274
TEMP= 20.11 ALTITUDE= 167.00m 1-Normdruck= 1009.5 bei 135.00m 3 3.1 3.14 3.142 3.1416 3.14159 3.141593 3.1415927 3.14159274
TEMP= 20.22 ALTITUDE= 166.80m 1-Normdruck= 1009.5 bei 135.00m
but suddenly the serial out gave correct floating numbers this is absolutly strange! I did not compile the code again on WIN7 Could thes line be the problem Serial.print(getAltitude(Pressure, Temperature)); maybe the output is the pointer to the function?
Logged
Seattle, WA USA
Offline
Brattain Member
Seattle, WA USA
« Reply #11 on: February 05, 2013, 08:58:38 am » |
Could thes line be the problem Serial.print(getAltitude(Pressure, Temperature)); maybe the output is the pointer to the function? What does the getAltitude() function return? Does it make sense to be printing that without any prefix?
Logged
Switzerland
Offline
Faraday Member
« Reply #12 on: February 05, 2013, 10:05:40 am » |
I guess the print of a float is not the problem but the sensor is not working correctly on the XP machine. My guess is your XP machine is not delivering enough power to the USB for your circuit. Have you tried powering your Arduino with an external power supply?
Logged
Offline
Newbie
« Reply #13 on: March 28, 2013, 06:24:35 am » |
I had the same problem some time back and seem to remember that this was a code problem to do with not using bitshifting. Has the code been posted? I would be surprised if it was a hardware problem . Best Vanja
Logged
Offline
God Member
« Reply #14 on: March 28, 2013, 07:01:03 am » |
I got this sort of rubbish from my BMP085, which was working six month ago. After a lot of mucking around, I eventually came to the conclusion that I had someone ruined the chip, maybe connected 5V to it or something. The communication was working but the measurements were rubbish.
Logged
