Loading...
Pages: [1]   Go Down
Author Topic: How to use BMA180 breakout board  (Read 116 times)
Offline Offline
Newbie
View Profile
Hey I am a beginner and i want to use BMA180 breakout board. There are other 5V devices which need to be used simultaneously along with it and BMA180 requires 3.3V signals.  Any help with wiring and code for getting orientation values will be helpful. I am not experienced in I2C either
Logged
Topsham, Vermont USA
Offline Offline
Edison Member
... in The Woods In Vermont
View Profile
WWW
Hi, If you will point to information on the board you want to use, people are much more likely to understand and answer...
More complete information about what you are trying to do is necessary for any accurate answers...
Logged
Regards, Terry King terry@yourduino.com  - Check great prices, devices and Arduino-related boards at http://YourDuino.com
HOW-TO: http://ArduinoInfo.Info
Offline Offline
Newbie
View Profile
I want to track the orientation of a small vehicle using bma180 and store the values over a period of time on a microsd card.
i am using-
https://www.sparkfun.com/products/544
http://www.fact4ward.com/blog/ic-if/bma180/
I have tried the cardinfo example an it is not being initialized. The one time it did initialize it said card format is not compatible. I used a formatted 1gb MMC
I used 1.8K and 3.3K voltage divder for converting signals to 3.3V for the MMC card breakout.
The wiring i followed for bma180 is
http://www.google.co.in/imgres?imgurl=http://static.rcgroups.net/forums/attachments/3/2/5/9/9/5/a4004401-29-BMA180-wiring.jpg%3Fd%3D1305130014&imgrefurl=http://www.rcgroups.com/forums/attachment.php?attachmentid%3D4004401&h=230&w=397&sz=21&tbnid=aRMF1eLkexf0NM:&tbnh=74&tbnw=128&zoom=1&usg=__PuaGZb0Pj-Hn2oph44SAjG1BDkA=&docid=PLeS3QvdEVW14M&sa=X&ei=g_4MUfS_Ho2rrAfFl4Ao&ved=0CDEQ9QEwAA&dur=
I used the code from
http://www.geeetech.com/wiki/index.php/BMA180_Triple_Axis_Accelerometer_Breakout
Logged
Pages: [1]   Go Up
Print
Jump to:
