Topic: Magic numbers (Read 2770 times) previous topic - next topic
graynomad
We all know that so-called magic numbers are bad in a program. They are sometimes needed though and the usual technique is to create a human-readable #define so at least you know what the number represents, for example
if (x < 3600) do_something();
What the heck is 3600? But
#define SECONDS_PER_HOUR  3600
if (x < SECONDS_PER_HOUR) do_something();
Makes some sense. So I had call to revisit some old code for my digital speedo today and found this
#define PULSES_PER_K (2089 - 21)
#define PULSES_PER_100M (PULSES_PER_K / 10)
#define MAGIC_NUMBER (16604 * 1.12)
Lucky I had that last define or I'd never know that the heck (16604 * 1.12) represents.
______
Rob
John_Smith
Is that the number of magic mushrooms you can grow on your smallholding ?
(  its so nice to be able to talk of such things now I am not a God member anymore :-)  )
45 years of editing projects with a knife and soldering iron, then I found Arduino !
graynomad
If we had any mushrooms they would have been washed away in the floods. 450mm of rain the other day. No rain all year so our friends bought 10,000 litres, the truck was barely down the drive and the rain started. Life's a bitch.
_____
Rob
John_Smith
I hear the flood warnings are very worrying down the East Coast again, the pictures of the Bundaberg area are frightening.
Fresh water in the truck could be valuable in a flood ?  but no doubt they dumped it in his tank...
JChristensen
Ha! Love it. Just remember, nothing is ever a complete failure, it can always be used as a bad example ;)
retrolefty
______
Rob
What, no furlongs per fortnight factor macro?
Lefty
liuzengqiang
#6
Feb 01, 2013, 08:22 pm Last Edit: Feb 01, 2013, 10:15 pm by liudr Reason: 1
So my question is: if a programmer doesn't use MAGIC_NUMBER but (16604*1.12) instead, how highly do you rate him/her [edit] work[/edit]?
John_Smith
if a programmer doesn't use MAGIC_NUMBER but (16604*1.12) instead, how highly do you rate him/her?
18,596.48  ?
graynomad
Very true.
The speedo was for my truck which is not very fast, that may have been an appropriate measure but I didn't think of it at the time :)
Largest recorded flood ever in Bundy, we have land about 65k away up in the hills so don't worry about floods although I know the roads has washed away not far from us.
______
Rob
