Topic: WQ730 Turbidity Sensor (Read 2638 times) previous topic - next topic
sabrine
Hello,
I need to implement a WQ730 Turbidity Sensor in the Arduino .
It's possible??
If no have you an idea about the turbidity sensor if is it compatible with Arduino??
Thank you in advance!!
michinyon
It outputs a "4-20 mA" output,   which is an old fashioned standard for engineering sensors.
You need to measure this output current and then scale the result according to the description
of the device.
This description may help
http://www.bapihvac.com/CatalogPDFs/I_App_Notes/Understanding_Current_Loops.pdf
What you need to do,  is feed the current from the device through a suitable resistor,  and then
measure the voltage across the resistor using the analog input pin of the Arduino.  A 100 ohm
resistor is probably going to work.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
