Topic: Motor stop (Read 2370 times) previous topic - next topic
Arduino001
I use ATMega 2560. I use the default program sweep for servo. I want my servo to to 0 to 180 non stop in loop. So it works but only for 5 minutes and I want it like for ever. What's wrong please ? Thank you
// Sweep
// by BARRAGAN <http://barraganstudio.com>
// This example code is in the public domain.
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
                // a maximum of eight servo objects can be created
int pos = 0;    // variable to store the servo position
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
  for(pos = 0; pos < 180; pos += 1)  // goes from 0 degrees to 180 degrees
  {                                  // in steps of 1 degree
    myservo.write(pos);              // tell servo to go to position in variable 'pos'
    delay(6);                       // waits 15ms for the servo to reach the position
  for(pos = 180; pos>=1; pos-=1)     // goes from 180 degrees to 0 degrees
PaulS
How is your servo wired? How is your servo powered? How is your Arduino powered?
There is nothing wrong with the code, so it must be a hardware problem.
Arduino001
Servo is wired with the servo wire (3pin female) directly on a ShieldV4 on my board. So the servo is powered with the board. The board is powered trought the usb port of my laptop.
PaulS
No idea what a ShieldV4 is. A link would be useful.
Servos can take a lot of current - more than a USB port can supply. The computer is protecting itself turning off power to the Arduino.
Arduino001
This is the shield V4 for arduino :
http://www.ebay.ca/itm/Arduino-UNO-MEGA-Duemilanove-Sensor-Shield-V4-Digital-Analog-Module-Servo-Motor-/181014763507?pt=LH_DefaultDomain_0&hash=item2a255217f3
There is still led on when the servo stop. Does the laptop still send a little power ?
PaulS
Which LED?
RuiSantos
you should post the schematics or your circuit for anyone understand and can help you...
which servo are you using?
For some Awesome Arduino Projects  click -> www.randomnerdtutorials.com
