Loading...
Pages: [1]   Go Down
Author Topic: EMI issue from Arduino  (Read 215 times)
USA
Offline Offline
Newbie
View Profile
I have an Arduino Uno that I have running that's fading a color RGB.  I noticed that when it's running my scanner picks up stray signals at times in the 70 cm band. Any suggestions on how to eliminate/reduce the interference?  I've also experienced the issue with even the blink example running.
Logged
Austin, TX
Offline Offline
Faraday Member
CMiYC
View Profile
WWW
Put the Arduino in a box.
What frequency range is that?
Logged
www.cmiyc.com - A guide to being an Enginerd
USA
Offline Offline
Newbie
View Profile
It's in the 420-450 MHz range.
Logged
USA
Offline Offline
Newbie
View Profile
I also experience the issue on my Mega 2650 (sainsmart clone).
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
Yes any digital processor will radiate. While the arduino is only 16MHz it is the harmonics in the edges of these signals go right up. The same goes for PWM. You can try putting a very small cap of about 100pF to take the edge off the PWM signal.
de G8HBR
Logged
USA
Offline Offline
Newbie
View Profile
Thanks for the suggestion, will get some of those caps. Stupid question, should those caps be placed in parallel or in series?
« Last Edit: February 04, 2013, 03:01:21 pm by Nicknml » Logged
Rapa Nui
Offline Offline
God Member
Pukao hats cleaning services
View Profile
An MCU is always a pain when combined with receivers circuits, as it generates a broad range of spectra, from zero to GHz.. The best way to learn how to tackle that is to download a service manual of a receiver or transceiver (ie. Icom, Yeasu, Kenwood) and simply have a look at the schematics.
Usually the main clock frequency is chosen such it does not fit into any filters, and, it does not mix with other oscillators used. Mind a traditional scanner might have 3-5mixers and several IF stages. So you have to tune the mcu main clock thus any spurious mixing products (all sums and differences of all frequencies with all their harmonics) inside the radio will not fit into any filter and in any band/channel used. That is very difficult.
Of course any digital signal with sharp edges generates a broad spectra by default, so low-pass filtering of any signal coming from the MCU is a must, where applicable.. And good shielding, grounding and decoupling helps as well.
« Last Edit: February 04, 2013, 03:08:25 pm by pito » Logged
Offline Offline
Brattain Member
View Profile
WWW
In parallel, across the LEDs
 You are better off trying to remove the source of the interference that trying to modify the receiver.
Logged
Pages: [1]   Go Up
Print
Jump to:
