Author Topic: HMC6352 compass converting degrees to direction problem?  (Read 331 times)
Sulaymaniyah-Kurdistan
hello everyone
i want to covert to the value of the degree to direction
//All this does is read the heading from HMC6352 and spit it out via serial
#include <Wire.h>
int HMC6352SlaveAddress = 0x42;
int HMC6352ReadAddress = 0x41; //"A" in hex, A command is:
int headingValue;
void setup(){
  // "The Wire library uses 7 bit addresses throughout.
  //If you have a datasheet or sample code that uses 8 bit address,
  //you'll want to drop the low bit (i.e. shift the value one bit to the right),
  //yielding an address between 0 and 127."
  HMC6352SlaveAddress = HMC6352SlaveAddress >> 1; // I know 0x42 is less than 127, but this is still required
  Wire.begin();
void loop(){
  //"Get Data. Compensate and Calculate New Heading"
  Wire.beginTransmission(HMC6352SlaveAddress);
  Wire.write(HMC6352ReadAddress);              // The "Get Data" command
  Wire.endTransmission();
  //time delays required by HMC6352 upon receipt of the command
  //Get Data. Compensate and Calculate New Heading : 6ms
  delay(6);
  Wire.requestFrom(HMC6352SlaveAddress, 2); //get the two data bytes, MSB and LSB
  //"The heading output data will be the value in tenths of degrees
  //from zero to 3599 and provided in binary format over the two bytes."
  byte MSB = Wire.read();
  byte LSB = Wire.read();
  int headingSum = (MSB << 8) + LSB; //(MSB / LSB sum)
  headingSum = headingSum / 10;
int value = headingSum ;
Serial.print(headingSum);
  if (value > 68 || value < 112) {
    Serial.println("E");
but the result are wrong  the if statement doesn't work
any one can help me?
thanks for replaying
Queens, New York
"Of all the things I've ever lost, I miss my mind the most" -Ozzy Osbourne
What does Serial.print(headingSum); put out?
UNO, MEGA, NANO, 4x4 keypad, micro servos, RF transceivers, bluetooth, ultrasonic sensor, 20x4 I2C LCD, 3.2 TFT touch screen, L298N Dual motor driver, Voice Recognition 15W, Gameduino
Arduino Tutorials, coming soon.
"If your doing nothing, it does not mean your lazy, it just means your open for anything that suits you" - Unknown
101E
101E
102E
98E
Finland
looks like a statement that is always true to me..
how about
if (value > 68 && value < 112)
Queens, New York
Ok, what should it say?
&& can't be if one if them true it will be true
thanks it is workings smiley
107E
107E
106E
106E
106E
100E
86E
69E
62503726208103336506377E
88E
94E
101E
103E
104E
112124135134134133134132133133132133132132134132132132132132132132132132132135
Queens, New York
Working?
107E
107E
106E
106E
106E
100E
86E
69E
88E
94E
101E
103E
104E
What changed, the &&?
if (value > 68 && value < 112) {
    if (value > 23 && value < 67) {
    Serial.println("NE");
   if (value > 338 && value < 22) {
    Serial.println("N");
   if (value > 293 && value < 337) {
    Serial.println("NW");
   if (value > 248 && value < 292) {
    Serial.println("W");
   if (value > 202 && value < 247) {
    Serial.println("SW");
   if (value > 158 && value < 201) {
    Serial.println("S");
   if (value > 113 && value < 157) {
    Serial.println("SE");
And i get
SE
SE
SE
SE
E
E
E
E
E
E
NE
NE
NE
NE
NW
Queens, New York
Ok Great.
How about a challenge, make it so that it only shows one direction at a time, until the direction is changed. Think you can do it?
li didn't understand . can u make it clearly?
Queens, New York
You get this
SE
SE
SE
SE
E
E
E
E
E
E
NE
NE
NE
NE
NW
make it so that you only get
SE
E
NE
NW
You don't have to, its your code, you can do whatever you want. Its just a suggestion to try.
thanks for the idea but i can't do it?
Netherlands
Online Online
you might like this thread - http://arduino.cc/forum/index.php/topic,94507.0.html - to convert degrees to direction
Rob Tillaart
