Loading...
Pages: [1]   Go Down
Author Topic: how to access "Input Capture Interrupt", Atmega328, USB Boarduino  (Read 133 times)
Offline Offline
Newbie
View Profile
pretty advanced question here:
I'm trying to detect a signal on the ICP1 (input capture pin D8 of the Atmega328 chip, USB Boarduino). I have Timer 1 set up to count with a prescaler of 1024 and if there is a rising edge on the ICP1 pin then the chip interrupts and in the ISR copies TCNT1 (timer counter1) to the ICR (Input Capture Register)... Then in the regular loop I'm just outputting the values serially.
I'm sending in a 60Hz 2% TTL signal to pin D8 (ICP1).
And so far all I get is a bunch of 0000.
Any tips, ideas, suggestions?
Thank you
Code:
#include "wiring_private.h" //need this to use sbi ,cbi commands
#include "Wire.h"
// variable here
byte inputCapture = 8;
volatile word period = 0;
//ISR here
ISR (TIMER1_CAPT_vect) //Timer1 capture vector
   cli();                    // deactivate other interrupts
   period = ICR1;      //copy Time Stamp
  TCNT1 = 0x0000;  //reset Timer1 counter.
   sei();               // reactivate other interrupts
  sbi(TCCR1B,CS12); //set prescaler to 1024 on Timer1
  cbi(TCCR1B,CS11);
  sbi(TCCR1B,CS10);
  cbi(TCCR1B,WGM13); // "waveform generation mode bit description"
  cbi(TCCR1B,WGM12); // normal counter mode
  cbi(TCCR1A,WGM11);
  cbi(TCCR1A,WGM10);
  sbi(TCCR1B,ICES1);      //trigger Input Capture on rising edge
  //sbi(TCCR1B,ICNC1);  //enable Capture Noise Canceler
  pinMode(inputCapture, INPUT);
  sbi(TIMSK1,ICIE1);  // Input Capture interrupt enable
  sbi(PRR,PRTIM1);    //enable Timer/Counter1 (extra redundancy)
  sei();                     //activate global interrupts (redundancy)
  Serial.print("period= ");
  Serial.print(period);
  Serial.print("\tTCNT1= ");
  Serial.println(TCNT1);
Logged
Offline Offline
Newbie
View Profile
Silly ME!! instead of redundantly Enabling the timer I disabled it!!
here's the fix
Code:
  cbi(PRR,PRTIM1);    //enable Timer/Counter1 (extra redundancy) <<<<<<<----------
Logged
Pages: [1]   Go Up
Print
Jump to:
