Topic: invalid device signature on attiny85 (Read 787 times) previous topic - next topic
hilukasz
Feb 23, 2013, 09:04 pm Last Edit: Feb 23, 2013, 09:33 pm by hilukasz Reason: 1
I've no idea why I get this error:
Code: [Select]
avrdude: Yikes!  Invalid device signature.
        Double check connections and try again, or use -F to override
        this check.
I've checked all the connections using a continuity test, so I am a bit confused. I have ISP sketch uploaded to board correct bored selected (attiny85) and arduino set as ISP. anyone know what else might cause this? It was working perfectly yesterday...
wasn't either of these as well: http://arduino.cc/en/Guide/troubleshooting
for(i = 0, i < 820480075, i++){ Design(); Code(); delay(1000); } // hellowoo.com
johnwasser
If you turn on verbose upload logging you will get to see the the signature that is read and the signature that is expected.
If the signature being read is 0x000000 or 0xFFFFFF then something isn't working in the SPI interface.  Perhaps the chip fuses have been set to disable reset, disable serial programing, or require an external crystal for the system clock.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
hilukasz
reseting the fuses seemed to have worked. thanks!
