Topic: Can't read Atlas Scientific colour detector (Read 12936 times) previous topic - next topic
summersgillb
I'm trying to read from the Atlas Scientific colour detector ENV-RGB, which is supposed to return a string.  Using the demo software I get nothing back.  I tweaked the software a little bit and it seems to be returning something, but just random characters rather than the "rrr, ggg, bbb" string that's in the spec.  Has anyone used this sensor?  Is it tricky?
AWOL
Quote
...but you didn't think to post it, or give any reference to the sensor?
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
summersgillb
Thank you so much.  Clearly friendliness is not one of the things you are moderating for.  I'm sorry I joined.
AWOL
#3
Feb 02, 2013, 07:27 pm Last Edit: Feb 02, 2013, 08:49 pm by AWOL Reason: 1
But still no code?
Quote
"My car wouldn't start this morning. It's a white car. What is wrong?".
See why we ask the questions we ask?
robtillaart
Quote
This might point to wrong communication setting or so. Is it a string of digits or a string of bytes (I have not read the datasheet) as typically every color would fit into one byte (and yes these may appear as the complete alphabet and more if interpreted as digits in a string.
I found the sensor after some googling here - http://atlas-scientific.com/product_pages/sensors/env-rgb.html -
Many questions pop up, the top 6:
What settings do you use in your code?
baud rate?
parity?
etc
Can you see the comma's appearing in the output?
Do you synchronize upon the <CR> character in your code?
Did you double check TX & RX?
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
phil88
I bought one of these sensors a week ago and struggling to get it working properly. The code they provided did not work.
Ive managed to get a reading through the serial, digital 0, 1 pins and then entering this code:
Code: [Select]
void setup() {}
void loop(){}
opening the serial reader and entering "C" to start taking a reading at 620ms. you should get something like this.
Code: [Select]
14,8,414,14,1410,10,1413,18,18
What I would like to know is how can you use soft serial and strings to be able to take a reading that arduino can then do something with.
robtillaart
From the specs I've seen, this should do a basic capture. Give it a try
Code: [Select]
#include <NewSoftSerial.h>
NewSoftSerial mySerial(2, 3);
  Serial.println("Start color sensor");
  // set the data rate for the NewSoftSerial port
  mySerial.begin(38400);
  mySerial.write('C');
  char c;
  if (mySerial.available())
    char c = mySerial.read()
    Serial.print(c);
    if (c == ',') Serial.println(); // split the R G and B
    if (c == 13) Serial.println(); // extra newline
Rob Tillaart
phil88
Thanks for that,
ive just tried verify this and get the following error:
'NewSoftSerial' does not name a type.
im running 1.0.3
Cheers,
Phil
AWOL
#8
Feb 03, 2013, 08:43 pm Last Edit: Feb 03, 2013, 08:46 pm by AWOL Reason: 1
Use "SoftwareSerial" instead.
Quote
I'm sorry I joined.
Quote
Members from IP (range) xx.xxx.xxx.xx
IP address    Display name
xx.xxx.xxx.xx    Summersgill, summersgillb
So sorry, you joined twice?
robtillaart
Sorry, retry
Code: [Select]
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2, 3);
  mySerial.print('C');
    char c = mySerial.read();
    Serial.print(c);
Rob Tillaart
phil88
thanks for that,
I open up the serial monitor and get this...
Code: [Select]
͹ÙL
(values change when i close and re-open the monitor) for example:
Code: [Select]
Ô»Ðó
Code: [Select]
ݽùÌ
robtillaart
that looks like some ascii code very promising (said the optimist)
Code: [Select]
    Serial.print(c, DEC);  // <<<<<<<<<<<<<<<<<<<<<<<<<<<<< line changed
can you give it a try?
Rob Tillaart
phil88
cool,
im getting a new reading roughly every second now...
Code: [Select]
ɵÁ\?Ё? p?aà°?ÁY` 1?aÿ?ðÉÜp?aàЁ?£ p?#à°???¡ p?#øÐÅ?£ p?#àðÉ??! p?øÌùñ 0?apÀ̹±?á cøÐÅ?£ p?#à°?ÁK°cà?Ùpcà
robtillaart
There are coming to much bytes, could also be a loose wire(!)
Have you try alternative baud rates?
9600, 19200, 38400 (already tested), 115200?
Rob Tillaart
summersgillb
Thanks, robtillaart.  I tried your code, too, but I still don't get anything back.
