Pages: [1] 2   Go Down
Author Topic: Can't read Atlas Scientific colour detector  (Read 1063 times)
I'm trying to read from the Atlas Scientific colour detector ENV-RGB, which is supposed to return a string.  Using the demo software I get nothing back.  I tweaked the software a little bit and it seems to be returning something, but just random characters rather than the "rrr, ggg, bbb" string that's in the spec.  Has anyone used this sensor?  Is it tricky?
UK
...but you didn't think to post it, or give any reference to the sensor?
Thank you so much.  Clearly friendliness is not one of the things you are moderating for.  I'm sorry I joined.
UK
But still no code?
"My car wouldn't start this morning. It's a white car. What is wrong?".
See why we ask the questions we ask?
« Last Edit: February 02, 2013, 02:49:15 pm by AWOL » Logged
Netherlands
Online Online
This might point to wrong communication setting or so. Is it a string of digits or a string of bytes (I have not read the datasheet) as typically every color would fit into one byte (and yes these may appear as the complete alphabet and more if interpreted as digits in a string.
I found the sensor after some googling here - http://atlas-scientific.com/product_pages/sensors/env-rgb.html -
Many questions pop up, the top 6:
What settings do you use in your code?
baud rate?
parity?
etc
Can you see the comma's appearing in the output?
Do you synchronize upon the <CR> character in your code?
Did you double check TX & RX?
Rob Tillaart
I bought one of these sensors a week ago and struggling to get it working properly. The code they provided did not work.
Ive managed to get a reading through the serial, digital 0, 1 pins and then entering this code:
void setup() {}
void loop(){}
opening the serial reader and entering "C" to start taking a reading at 620ms. you should get something like this.
14,8,414,14,1410,10,1413,18,18
What I would like to know is how can you use soft serial and strings to be able to take a reading that arduino can then do something with.
Netherlands
Online Online
From the specs I've seen, this should do a basic capture. Give it a try
#include <NewSoftSerial.h>
NewSoftSerial mySerial(2, 3);
  Serial.println("Start color sensor");
  // set the data rate for the NewSoftSerial port
  mySerial.begin(38400);
  mySerial.write('C');
  char c;
  if (mySerial.available())
    char c = mySerial.read()
    Serial.print(c);
    if (c == ',') Serial.println(); // split the R G and B
    if (c == 13) Serial.println(); // extra newline
Rob Tillaart
Thanks for that,
ive just tried verify this and get the following error:
'NewSoftSerial' does not name a type.
im running 1.0.3
Cheers,
Phil
UK
Use "SoftwareSerial" instead.
I'm sorry I joined.
Members from IP (range) xx.xxx.xxx.xx
IP address    Display name
xx.xxx.xxx.xx    Summersgill, summersgillb
So sorry, you joined twice?
« Last Edit: February 03, 2013, 02:46:31 pm by AWOL » Logged
Netherlands
Online Online
Sorry, retry
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2, 3);
  mySerial.print('C');
    char c = mySerial.read();
    Serial.print(c);
Rob Tillaart
thanks for that,
I open up the serial monitor and get this...
͹ÙL
(values change when i close and re-open the monitor) for example:
Ô»Ðó
ݽùÌ
Netherlands
Online Online
that looks like some ascii code very promising (said the optimist)
    Serial.print(c, DEC);  // <<<<<<<<<<<<<<<<<<<<<<<<<<<<< line changed
can you give it a try?
Rob Tillaart
cool,
im getting a new reading roughly every second now...
ɵÁ\•Ё‚ p€aఉÁY` 1€aÿ‰ðÉÜp€aàЁ‰£ p€#ఉ‘‹¡ p€#øÐʼn£ p€#àðɑ‹! p€øÌùñ 0€apÀ̹±‹á cøÐʼn£ p€#ఙÁK°cà‚Ùpcà
Netherlands
Online Online
There are coming to much bytes, could also be a loose wire(!)
Have you try alternative baud rates?
9600, 19200, 38400 (already tested), 115200?
Rob Tillaart
Thanks, robtillaart.  I tried your code, too, but I still don't get anything back.
Pages: [1] 2   Go Up
